Borgenson
and here:
Summit Racing
I had opted for the $50 replacement figuring I could always opt for the $200 later if needed. So far after 3 years no clunking. If you are to attempt the change yourself you would need a special tool to lock the steering wheel in place so that it is in the correct position after the shaft change. If not an old time mechanic would probably use the seatbelt to secure the steering wheel. Changing the shaft took approximately 15 minutes.
I had ordered the replacement shaft at gmpartsdirect.com and after checking there noticed that it is still $50.
gmpartsdirect
Truck 1999 GMC 2500 - 125,000 MILES
Front end alignment -Recent
Tire Rotation & balance recent.
Frt bearing Replacement 2 yrs ago
Both Tie rod ends replaced 1 yr ago
Adjusted Steering Gear Box Gland hex Nut 5/8" with 3/16" allen hex screw.
Took care of the problem!!!
Based on what I have read this has been a problem for since the mid 90's, some post say its not a big deal less than 1 hour labor & $50-60 for the part. Mine 1999 GMC 250, must have the steering column linkage disassembled and the part cost is $80-$90. This was/is not just a problem on truck it is also on a dozens of other vehicles. see link below.
EVO - ELECTRONIC VHECILE ORFICE - SENSOR
http://www.gm-trucks.com/forums/index.php?showtopic=81519
Service Information 7-15-2008
1998 GMC Truck GMC C Pickup - 2WD | Chevy Pickup, GMC Pickup, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 1911096 #07-02-32-001: Reduced Steering Effort (Diagnose/Replace Steering Wheel Position Sensor) - (Feb 27, 2007)
I encourage everybody to contact NHTSA at 1-888-327-4236 or www.nhtsa.dot.gov/cars/problems/voq_form.html
Were you planning on having your vehicle looked at by the dealership? Please keep me posted.
Thank you,
Caron, GM Customer Service
