I have taken it to a mechanic and he told me my transmission is fine, joints are fine. He thinks its a motor problem. He does not know what it is because when he plugs the reader into the computer there are no misfires or issues reported.
I had him change the Air Filter, Fuel Filter, Spark Plugs , Oil, add fuel injector cleaner . Still no luck. Someone please help.
any info would greatly be appreciated
Did you find out what these test results mean? Please let me know.
Anybody else had this problem??
I had the same type of problem on my 4.9L. It kept quiting on me and missing. I found that it wasn't getting a good connection (electrical) at the tank. It kept burning the connector and pigtail. After burning a couple of pig tails, I finally put Kearney's on the connector posts. It stopped the problem at the tank but I also found that the wires going to the collision switch (driver side firewall under dash) were corroded, thus not sending adequate power to the pump. I renewed the connection and haven't had any problems since. (This problem haunted me for about a year). I suggest that you pick up a Haynes manual #36058 if you don't already have one. The fuel system is in Chapter 4. It has good trouble shooting and test procedures. Mike 9408
Mike9408
Thanks for any help.
Thanks Notlob
We have a 2000 Ford F250 crew cab, short box. It has the 6.8 liter V10, and man does this thing have power. Low end torque is through the roof for a 3/4 ton truck, especially for a gas engine. And it tows like no other. We once pulled a stuck 32 foot motorhome, with a 22 foot Malibu wakeboarding boat ataached off of a gravel boat launch. The truck crawled right out of it.
The gas mileage is about 10-12, but if you want a gas truck that can tow this is it. It pulls our 3500 pound boat around like its not even there.
The four door crew cab is great. 3 people in my family are over 6 feet tall, and we can all ride comfortably on long trips together.
The truck now has 86,000 miles on it, and we have never experienced a problem, but as said before, it is maintained very well. Overall i would highly reccomend this truck.
Newby here who just bought a 2006 F-150 Supercrew with 5.4 Triton motor about six months ago. It's got around 50K miles on it now. AFTER I bought it, there appeared several signs in the service dept claiming that "owners of 5.4 Triton motors between 2004 and 2006 should speak with service manager".
The service manager told me that they were aware that if you wait until 100K (the normal service interval for a plug change) that the plugs could seize or break in the heads, causing VERY expensive procedures to be done. He offered to change my plugs for $170.00
His recommendation was to replace them before 60K, thus preventing the problem. I have looked around the web and seen multiple horror stories of people with this motor having plugs blow out of the heads, break, etc. and now am paranoid about the whole situation.
My wife wants to go visit family in Maine from here in Texas in the truck this summer.
My question is this.......should I go ahead and have the plugs changed NOW and hope they follow correct procedures from TSB 08-7-6 which clearly shows how to remove the plugs without breakage, and hope that they can do this without screwing up and ending up charging me for plug inserts, or at worse, new heads? Or should I just keep trucking, and hope the spark plugs don't pop out on this long trip?
Any and all advice appreciated.
Mike Selvey
Nacogdoches, TX
I suggest you start using Lucas Fuel treatment with each fill up. This will burn off most of the carbon build up on the stems of the spark plugs. My service manager advised that the carbon build up is the source of the breaking/stripped plug problem. I bought the truck with 60k on it and had been using the Lucas to boost fuel mileage. When they changed my plugs (the $170 is just the labor, the plugs are another $80) only one broke off. In discussing this with the service manager, after the fact, he stated that the Lucas is probably why they only had a problem with one plug. I would suggest you take your trip, using the Lucas, and have the plugs changed when you get back.
Beware, they also "sold" me on a fuel filter and injector cleaning, bumping my tab over $600, but on the trip to Daytona from W. Ky., right after the plugs and "cleaning" I got 21 mpg, loaded with 4 passengers and the bed filled to the brim, with my wife and her bff doing the driving. Both of them were hammer down all the way down and back. Good luck.
You already replaced the EGR so that wasn't it. If it is an electrical problem, ouch very hard to diagnose.
Other causes and most common are DPFE (Differential Presure Fedback EGR sensor) or EVR (Electronic vaccum Regulator to EGR) I know a real mouth full.
1st: If you are not experiencing weird idle changes along with this trouble code, it is unlikely that the EVR is malfuctioning. It could be not working at all and not opening the EGR with vaccum. This is the cheaper sensor too. About $35
2nd: On your exhuast manifold are 2 tubes one bigger than the other leading up to the DPFE. This sensor reads back pressure changes in the exhuast when the EGR is told to open. If the signal is not correct, bingo....t-code. Check to see if the tubes are clogged up or if one of the hoses came off the DPFE sensor. This sensor isnt cheap! If you have an exhuast leak, fix it. Insufficient back pressure in the exhuast can throw this sensor off also.
You seem like a smart guy. After each test repair reset PCM and test drive. Keep track of what you have eliminated as the cause such as the EGR. This may take some time to figure out. I do this for a living and this t-code can be a [non-permissible content removed] sometimes. One way of testing the EVR is to temporarely install a vaccum guage inline with a vaccum tee to your EGR and put the guage so you can see it. Drive and look for vaccum being applied and changing by the system while your driving around..
Get back to me if you want me detail how to test the DPFE. I have the right equipment, but it can be tested other ways, its just hard that way. Good luck.
