My problems started back 2 1/2 years ago when my transmission started having trouble staying in overdrive. The problem was pretty rare and when my father offered to pay (and allow me to pay him back) to have it rebuilt I took the offer.
Following the rebuild the problem intensified. It started to shift extremely hard into gears, never shift out of 1st, or after it shift out of 1st it would shift immediately into 3rd. Of course I took it back to the repair shop instantly. After two more weeks they claimed they couldn't find the problem even after replacing the TPS sensor, a speed sensor in the rear axle, and scanning the computer for error codes nearly 15 times (or so they claim!)
To cut a long story short, even after transmission flushes, filter changes, a new torque converter the problem still persists. It remains very very random. Some days it operates without a hiccup and others you can't get out of the driveway without cursing it! The truck is a second vehicle and due to money restrains this problem remains unsolved. The more I read up on common problems with this transmission I'm led to believe the original shop incorrectly rebuilt it or perhaps it is a computer issue. A current option I plan to explore is adjusting the steering column shifter and the shift linkage on the transmission (this process is in my Haynes repair manual I just can't recall the exact name of the components). I am also concerned with perhaps the shift interlock? I am very unfamiliar with this feature of the drive train and the thought occurred to me after the engine stalled after the transmission shifted up .
Has anyone ever heard of such an illusive tranny ghost problem or is the real part to blame in front of me this entire time?
My 1990 ford f350 transmission is acting up. First let me give some history. The truck is only used 15-20 time a year. Has slipping problem about 15 months ago. Had trans rebuilt. After about 1 year seemed to be having problems when shifting mainly from 2nd to 3rd took back to trans shop. They said mid shift bearing and rear axel bearings were bad. Had repairs done. Used truck locally several times and shifted great. Went on longer trip and noticed some delay when shifting from 2nd – 3rd. took back and they replaced trans vacuum (cant remember name of part) on engine with vacuum hose going to trans.
Still shifting problem 2nd – 3rd also noise when down shifting.
Ford test drove and said seemed ok. (at this time I had not realized it was not happening until truck got warmed up)
Realized on last trip that it does not start until truck is run for an hour or so.
Shifts great when cool but after warms up there is sort of a delay when shifting from 2nd – 3rd. (when it shifts you get bounced back in seat, kind of like delay in shifting. Makes noise when downshifting )
I am afraid to go back to original trans shop after 2-3 visits they have only replaced more parts
Jim
Just last week it began giving me trouble when I put it in reverse. I have to push the accelerator to the floor before it finally moves.
The two mechanics that I have brought the truck to have suggested replacing the transmission or rebuilding. One other mechanic said that it might be the speed sensor. I'd like to hope that it is something a little less expensive than a rebuild or new tranny. Do you have an thoughts or suggestions? Thanks.
Thurman Wilder
Montpelier, VT
If you are plowing and have a Dump bed on it and it's never been replaced or rebuilt I am shocked the Transmission has lasted that long. I put a post last week about where to go for Ford Diesel Parts and even a Guy here in Denver, Colorado about having our Trannys rebuilt, the shipping cost for you to ship yours here and get one back might cost a little more than the 300.00 total round since you live way up in Vermont, lol. Damn dude I just Mapquest Montpilier Vt. and you are not near any place of Size, you don't seem to far from Burlington though, the only reason I know that place is that my wife used to fly in there for US Airways when she was working out Indiana, lol. If you are near any race tracks in your area you might want to contact them and find you a good Transmission guy there. I have not called Dwayne in a while but I can double check on what it would cost to ship one out. Just the Tranny & New Torgue Converter is around 2250.00 but it is a very well built Tranny. With the Shipping you are probably looking around 2500 to 2700 depending on what kind of deal he or maybe even you could get. Might have to Ship and pick it up out of Burlington. Let me know if you want me ask him or if you want to check around you. The reason I said Race tracks is that usually they have people that rebuild Trannys and that for the same price as dealers but build them to actually last.
Tony
Same goes for when it downshifts. When cool it makes no noise. When warmed up it makes a clunking sound when downshifting.
This has been going on for a while now. It has not gotten worse or better. (put about 2000 miles on since problem started.)
p.s. I changed fluid and both filters. This made no difference.
Jim
I've got a '94 7.3 with a 5 spd manual transmission. It goes into reverse one time is about 4. Sometimes the first time, sometimes the 8th time.
Average is about 4 tries.
I had it torn down by a supposedly good transmission guy. I pulled it, he rebuilt it; and now he has re-pulled it, in his shop, because he didn't fix it.
He replaced a bushing, (looked like a synchronizer to me) that the collar slides over to go from reverse to 5th gear and back. He also replaced my forks, saying they were worn. (257k miles) He also replaced all synchronizers. When I put the unit back in the truck, it still had the same exact problem.
He doesn't seem to really know what to do; and he's been dragging his feet getting it back together. (He obviously puts paying customers in front of warranty.)
He said that on the bench, it shifted perfectly, every time. Maybe the teeth aren't meshing totally? There was no damage on any of the gears evident. The problem has existed for over 20k miles.
Anyhow, he said he's replacing the the reverse gear, which looked perfect to me.
Have you had this situation before?
E-mail me at Simsworks@aol.com, if you want to.
Colorado springs Co.
May I ask what you found on your truck and approximate $$$$$ involved. Of course, we are not covered under warranty and can only find that we were covered by the powertrain warrantly until 3 years/36,000 miles. The truck is only 4 years old and has less than 49,000 miles on it. This is just sickening.
Thank you for any information you are willing to share with me.
My transmission had an awful grinding noise when engaged. This after 28,000 miles and 6 days past the 3 year mark. After the dealer told me I would have to pay half the cost I went to the Ford factory "customer service" line to ask for assistance - but they kept pushing me back to the dealer. I had no choice but to pay $2,200 for a rebuilt tranny after telling them I'd never buy another Ford product.
I really tried to be diplomatic through the entire ordeal, and it was like talking to deaf mutes. They even sent me the customer service pre-curser wanting to make sure I was completely satisfied and to call them first before filling out my report card.
I'm also on my 3rd set of warped rotors. I don't tow anything with the truck and have had it maintained per the service book - usually at Ford.
The noise didn't return for 30 - 40 miles. It sounds like metal rubbing against metal. In a matter of 30 miles it has happened 3 other times and it seems to occur between 25 MPH - 40 MPH. As I slow to 5 MPH - 10 MPH (or stop), the scraping noise disappears when something seems to engage (clunk/pop into place). The truck drives fine otherwise--goes into reverse, accelerates, etc.
I'm hoping for the best but prepared for the worst. Any help would be appreciated. Of course, my warranty has expired.
I have an automatic 2004 Ford F150 Lariat with 25,000 miles on it that I recently purchased. While driving it today I heard a noise that sounded like I was dragging something underneath it--think shopping cart or exhaust system. I pulled over and everything appeared fine.
The noise didn't return for 30 - 40 miles. It sounds like metal rubbing against metal. In a matter of 30 miles it has happened 3 other times and it seems to occur between 25 MPH - 40 MPH. As I slow to 5 MPH - 10 MPH (or stop), the scraping noise disappears when something seems to engage (clunk/pop into place). The truck drives fine (as of now)--goes into reverse, shifts, accelerates, etc.
I'm hoping for the best but prepared for the worst. Any help would be appreciated. Of course, the warranty has expired.
Thanks in advance.
I sure thank you
please e-mail me at bellaseri@aol.com --I sure thank you
Do you have my number or email addy ?
I originally posted my transmission problem about a month ago. Since then we have gotten the truck fixed by an independent transmission mechanic and ran to the tune of $2000 before all was said and done.
The mechanic said that the back side of the transmission was basically "gone". All of the gears were destroyed, especially reverse, it had sheared off completely. He has no explanation why a truck this new with this low mileage is having issues like this already. He did say the Ford tranmission gears are as thin as a penny and break very easily.
I have been looking today at the replies we have received to our problem. It looks to be about 6 of us with 2004 F-150 having the same issue, around the same miles. I have done research to see what needs to be done to have this problem listed as a recall. Apparently, we all need to file complaints with the NRTSA. If there is enough reason, they will begin an investigation on parts sold with Ford and autopart manufacturers to see if there is reason to begin a recall. If a recall is issued, you must also be reimbursed for the out of pocket expense you have put into you vehicle to have this problem fixed.
I think we all need to get on board and write our letters of complaint and see what comes of it...worse case, we are still out of pocket on the repairs. But we may get our money back and right now, I think we could all use that.
I will be writing my letter today and getting it out tomorrow. I hope all of you will do the same.
Did you mean 'NHTSA'? I can't find anything under 'NRTSA'
thanks for the suggestion. I am happy to write to NHTSA to see if together we can find some compensation for our transmission failures.
I will scan some other car forums to see if I can't find some others who have encountered the same problems.
I believe this is a defective part (an expensive one) that Ford needs to step up to the plate on. I had only 28,000 miles on my well maintained truck before the tranny completely failed.
can you help me understand your post?
