after careful inspection of my sunroof i found out the solution.
if you look from the top with the sunroof open you'll see 2 holes on left and right close to the windshield.
these holes connects to tubes and runs all way down.
they are clogged!
i suggest you take a powerful vacuum and suck all dust out,then push air in,then you can try to clean with a metal wire.
check if the water going through by pouring water in the hole from a bottle
they are clogged!
SUVs and Smart Shopper
The "service engine soon" light comes on and will blink about when the car reaches 1500rpm in 5th gear but sometimes will quit blinking when I decelerate to 2000rpm (this is about 35 mph and 40 mph.
I don't know if the loss of power and gas millage and cruise control is related (I am told that the cruise control if dependent on engine vacuum and I know that this can affect performance) but it sure seemed to be related as they happened at exactly the same time.
Any suggestions?
LJSch
BTW - the cruise isn't necessarily dependent on engine vacuum - its all electric
Would the misfire also be caused by old plugs and wires? I have suspected this as well. Quite frankly, I am from the old school of mechanics with points and rotors etc and I can not say for certain even where the spark plugs are located. I suspect directly on top of the engine, but I can not find any diagrams or evidence that they are there. lol In order to get to where I think they are, I have to take off the air ducts and then there are several bolts holding in a plate that "seals" the middle of the top of the engine block. The is an electric unit on the driver side of this plate (built into this plate,or maybe better described as a cover) I have not tried to get into this as yet, I would like to know what it under it before I do all of that just to see. I don't want to open it up and see valve lifters or the inside of the engine if they are located some place else.
BTW, just because of the cause and effect coincendence of the cruise control and the loss of power is so strong and you choice of the phrase "necessarily dependent" on engine vacuum: IS there a possible connection to this unit and if you know where the cruise control unit is located, I would like to at least look at it and see if there is anything obvious that might cause it to stop working. (our roads here in the city are extremely bumpy. I saw better roads in Kathmandu and I would not be surprised if something had been shaken loose.
Thanks for the reply and I do know a mechanic that I sort of trust with the Vue (he did an excellent job on my AC unit and at 1/3 to 1/2 of the estimates I got from the dealearships. I will try to get him to look this weekend.
LJSch
When your speedometer says one speed and your cruise control setting is a different speed, the computer figures out whether to increase or decrease the throttle. Since its all electric, your gas pedal doesn't move like in the days gone by and no engine vacuum is required to move the plunger that used to pull on the throttle cable.
I say "not necessarily" because if you have a vacuum issue, your cruise control could have trouble keeping your speed constant. But to be clear, the operation of having the computer adjust the throttle to maintain a certain speed is not at all controlled by or limited by engine vacuum.
The spark plugs are under the black cover in the middle of the top of the valve covers. There are no wires. On the top to the right is the ignition control module, it could also be a source of a misfire and its more likely than the plugs IMO.
I hope I explained it well - good luck...I'll check back if you have any other questions. :shades:
1 - gas pedal position sensor
2 - electrically controlled throttle actuator
3 - wiring in between
P0378-Timing reference high resolution Signal B intermitent erratic pulse
P0778-Pressure control solenoid B electrical
B0387-Crankshaft position sensor B circuit low
Also there are so other codes which the computer sais-undefined.
Can you email me directly? I would like to work with you to find someone who can assist you in repairs on your vehicle.
Christina
GM Customer Service
Have you taken your vehicle into a dealer to have this addressed? If not, I would recommend doing so. Please feel free to email me with any questions comments or concerns.
Christina
GM Customer Service
Do you
The 4 cyl is better known as the L61
The V6 is known by Honda as the J35
1 - Body control module is failing
2- Body control Module grounds are corroded causing it to act funny.
Most likely the 1st. Its not an uncommon failure in the Vue - Dealer only repair, about $ 700.00
Does anyone have any inspiration or thoughts? Of course I have a 2.4K business road trip coming up in Oct. and this was to be the designated hauler. So I'm nervous and I'd like to know if it's worth it or if going new is really the best answer.
The engine and trans in your Vue were built by Honda and are the same that were used in the Honda Odyssey. Bring your Vue to a Honda dealer and get their opinion. They work on them all the time and have a bunch of experience with them. Its likely something that many of them do and they have likely seen the issue many times before. It may be something very minor.
While there are plenty of "Saturn authorized service centers" at GM dealers that do a reputable job repairing Saturns, I think a Honda dealer will have much more experience with your drivetrain.
Good Luck.....
If I pull over, turn the car off, and wait a while, I can start the car up and it will allow me to drive. Sometimes I can get to my destination, sometimes, it happens again before I get there. I've noticed that that the problem is more pronounced on very warm days or if the car has been in operation for longer than 30 minutes. Also, when I put on the turn signal, the high beams come on for a couple of seconds..not sure if the issue is related. Yesterday, it looks like there was a little smoke coming out of the steering column. I've seen others post similar comments; I would appreciate any guidance you can provide.
I had the exact problem. :-(
The steering column is bad. You have to take the car to a Saturn dealer and have it replaced as it is dangerous to keep driving the car with this problem.
Not the cheapest fix as it will run close to or just over 2gees. However worth it if you plan to keep driving the car.
You were right on target. The Saturn dealer said it was the automatic steering motor or something to that affect. I asked if it could be individually replaced, he said in the 2003 model, it came in one piece so you have to replace the entire steering column.
You are right on target.
Sound like what might have happened to you..
regards,
kyfdx
(old enough to have owned cars without power steering.. )
I apologize for the issues you are experiencing with your vehicle. If you would like to visit the dealership, I would be happy to locate the nearest dealership for you if you would like.
Thank you,
Caron, GM Customer Service
Any thoughts would be appreciated.
That worked!!
1 - You mention that you have kept up on all of the maintenance and that is good...when was the last time you changed the trans fluid? Many Honda powered Vue owners change the trans fluid every 25-30000 miles as its really sensitive to having clean fluid.
2 - Mine is a 4 cyl but there was a recall recently for the Vue torque converter, I believe that they reprogrammed the trans to shift at different points and in some cases they replaced the torque converter. I wish I had more info about it but do a little searching and I'm sure you will find information.
Here's a little info: link title
Some will change the fluid 3x over the course of a month as you never really drain out all of it. So by changing 3x over a short period of time you get a lot of new fluid in there. Apparently the Honda trans is sensitive to clean fluid. Also, you can't change the filter unless you open up the trans so just change the fluid. And DON'T get it flushed - the fluid they flush it with will not be Honda Z1 and will likely cause more harm than good.
I don't own one so I can't give too many tips but I bet a quick internet search or 2 will give you all the info that you need.
