I know that, but the auto makers usually try to protect you from yourself. Case in point my 98 Olds 88 was limited to 107 and I know it had more. I looked at the stock tires and they "s" rated. Now my friend's Grand Prix with the same engine and different stock tires would run quite a bit past that.
The only reason I backed off on the factory tires was the car got really floaty around 120 and I wasn't willing to risk loss of control. With the 'Z' rated high performance tires...it was a totally different experience. Very solid feel at the high speed. While the Azera is no BMW in any stretch, it is not a sloth either.
I am not in denial and I know that for example Avalon/camry can beat me 0-60 as well as SRT charger . Now in reference to Azera - you mean an old dude beats me in Azera? This is the reason i surveyed members in re to car/driver/ age. Now my car weighs 3432 lb, about 200 lb lighter then Azera so unless you weigh 0 and I way over 200 lb it will be an unfair competition. 2005 Maxima's power to weight ratio is 13.45 under new power ratings. Azera is 13.7984. You don't have to be a genius to see that which car will be faster.
Maxima has longer wheelbase ( more space to passengers), wider tires and in SE form sport suspension.
In theory...
But as we know, having a longer wheelbase does not translate into bigger interior:
Observe:
Maxima: http://www.nissannews.com/nissan/2007vehicles/maxima/specs.shtml
Azera: http://www.hyundainews.com/Media_Kits/2007_Models/Azera/Specifications.asp
Rear Headroom: Maxima 37.3 | Azera 38.2
Rear Legroom: Maxima 36.5 | Azera 38.2
Rear Shoulder room: Maxima 56.5 | Azera 57.1
Rear Hip room: Maxima 54.8 | Azera 55.1
That's 0 for 4 by my count!!
You can quote power to weight ratios and 0-60 times all you want, until you get behind the wheel and go head to head with an Azera driver...you're blowing hot air! You ever watch the show 'Pinks!'??? Yeah, okay...how many times does the so called "obvious" winner not win???
Longer wheel base does NOT always equate to more passenger room, because it depends on how that space is used. The wheel base on the Maxima is almost 2" longer and yet, the Maxima gives way to every comparable number when it comes to interior space.
Maxima / Azera
Front head room - 39.7 / 40.2
Front shoulder room - 57.9 / 57.9
Front hip room - 53.5 / 55.5
Front leg room - 43.6 / 43.7
Rear head room - 37.1 / 38.2
Rear shoulder room - 56.5 / 57.1
Rear hip room - 54.8 / 55.1
Rear leg room - 36.5 / 38.2
Luggage capacity - 15.5 / 16.6
The above numbers are based on exterior measurements of...
Wheelbase - 111.2 / 109.4
Length - 193.5 / 192.7
Width - 71.7 / 72.5
Height - 58.3 / 58.7
Now you tell me which maker used their space more efficiently! :P Not only did they provide more space for passengers, they also squeezed in a slightly bigger engine AND gave it more luggage space as well.
The numbers speak for themselves. Next time you want to make a statement...please do a little research before you post anything that'll make you look, well... :confuse: !
Once again, I will STATE...your Maxima will NOT blow the doors off of an Azera. I know that you would like to believe it so you won't lose any sleep at night. Heaven forbid a Hyundai product that can keep up with your precious Maxima. By the way...is that SE or SL?
Another crazy thing...the Maxima has 2 more ponies under the hood and is about 200 lbs. lighter and yet...their fuel economy is almost identicle. How's that for ironic! LMAO
I think the Maxima / Altima situation is a good case of little brother finally beating big brother!
For the life of me, I've wondered too why the Max is still being made with the come up of the Altima. Only thing I can think of...they have plans for the Maxima to boast a nice 300 hp powerplant. Then it would be running with the likes of the Magnum/Charger R/T or the 300 C.
I never said you did... just was stating it so I didn't get flamed, lol.
Of course there is... you've got to check out the cup holders!
Nissan would do well to base a new Max on Infiniti M, put in a nice V8 and rear wheel drive, than it would be a real "Maximum" Nissan.
The Altima is a great alternative to Accord/Camry. :shades:
Amen Brother!
Those 0-60 dicussions just seem so out of place in this board...
The land is pretty flat. Do any Phoenix area members agree or disagree?
And, as someone said, the speeding charges applied against a Sonata which is about 30HP less than the Azera.
http://www.caranddriver.com/carnews/12563/the-147-mph-hyundai-sonata.html
Wow...your Maxima is probably governed around 130 mph, so that means a Sonata can go faster than your Max! LOL
I've done that kind of thing in my Azera on a couple of occassions and I have not ended up in the pokey as some guys girlfriend and I'm still a contributor to this forum.
Please note, I do not engage in such activity to often, however I feel it necessary for the sake of knowing my car. I do this with every car I've owned, push it to find out just what it's capable of doing. You never know when you'll need to push it and there's nothing wrong with knowing in advance just how far you can.
Now...just because you may not do it, don't care to do it or just too scared...that's your personal issue. However, the way YOU personally feel isn't going to stop someone else from living!
Allmet, I propose that you "STILL" don't know what your car is capable of doing. Perhaps you should take her out again and push it till she breaks. THEN, you will know what she is capable of...
You said the Azera does not have a limiter, and to which I said you may be right. Please re-read my post.
"The Azera has a four-wheel independent suspension (multi-link in the rear) and uses the company's new 3.8 L Lambda V6, which produces 263 hp (196 kW). The power is sent to the front wheels through a five-speed automatic transmission with "Shiftronic" manual gear selection. Hyundai claims 6.0 s to accelerate to 60 mph (97 km/h) and a top speed of 157 mph (252 km/h)." Found in Wikipedia.
I have had mine to 141, with more available but backed off due to an upcoming curve and traffic. I was not having any "stability issues". I have driven BMW's and Audi's to limited 155mph sustained periods on the autobahn on several occasions and the Azera felt very solid to me. NOT saying its designed for continuous high speed like the Bimmers or Audi's, but it will certainly get up there and run on a decent road. And NO, I don't intend to race any Maxima's, those days are behind me.(But then so would be the Maxima's)
Why would anybody, in the right state of mind, driving a large sedan, whether it's the Avalon, Azera or Maxima, to 140+ mph? I have no problem with people trying to kill themselves but if other folks are endangered in the process then I do. Reckless driving, and I consider driving at 140 mph as one, is as stupid as DUI.
I will admit to having my Avalon up to slightly over 100 mph, a speed that the car was still solid and still pulling strongly, 140 is entirely something else - it was irresponsible enough for me to be driving the thing at even the 100! 75 or 80 seems to work fine!
Knowing that it can attain those speeds doesn't mean I plan on driving it at those speeds on a regular basis.
Everyone really needs to calm down, I mean seriously. Just because half of you are getting ready to be over the hill (if not there already), doesn't mean that there aren't some of us that aren't. There are those of us that can and will do the very things you all did when you were younger and adventurous.
Oh...and when I did reach 130 mph, there was no loss of stability or control. With the aftermarket wheels and tires, the car felt even more stable than with the factory ones. There was no floatiness and the car tracked more confidently. As far as loss of control, ummmmm...er, uh....obviously I was able to maintain control as I'm here to type about it today.
Have you tested any of the cars in this discussion to know what they are capable of?
Don't worry captain...we all do irresponsible things every day of our lives. Driving your car slightly over 100 isn't unforgivable by any stretch. I mean...it just shows you're human and that you're ALIVE!!! However, before you jump on your soap box, driving at 15-20 mph over any speed limit would be considered irresponsible as well. I guess you're justification is that everyone else around is doing it, so it's okay, huh? :P
