Mainstream Large Sedans Comparison
1117118120122123134
  • 7milehi7milehi Member Posts: 28
    I forgot to mention I put about 30k miles a year on a vehicle and try to get 225k miles on it before a new one. I wonder how the Azera vs. Taurus will be when they get 150k+ miles on them? How about 225k+ miles? My Volvo S70 now has 223k miles on it and has never had any major problem. I would get another Volvo but need more room than a S60 has, and from what I hear and read the Volvo S80 turns into a maintenance hog above 100k miles.
  • captain2captain2 Member Posts: 3,971
    Then I check out intellichoice.com and it shows the Azera with a poor value rating,
    you might want to research this a bit more - it appears that Intellichoice' s TCO is based on a $27320.00 purchase price. I'm hearing a number of claims of actual purchase prices in the $23-$24 range (Limiteds). If this is the case that 'value' rating may be skewed by $3 or 4 k (plus the costs of financing that extra money).
    This kinda thing happens when a car with a questionable resale value history is a slow seller and therefore picks up some more discounts as time passes - it's generally not so good for those that did spend the higher price, but can have a significant impact on TCO depending on what numbers are used to determine those costs.
    The thing that would surprise me is why the Taurus isn't effected in the same way - it too is not selling terribly well (nothing really is right now) and apparently can also be bought at a bigger discount.
    any car with 225k on it won't be worth much when you are done with it - why would you care about a 'value rating' that is largely determined by resale values?
  • plektoplekto Member Posts: 3,738
    Well, if we add the 3.6 to the discussion, it's a whole new ballgame. That engine in the LaCrosse CXS is awesome. It's the same engine as in the Cadillac CTS, just they geared it for torque and not HP. And it moves much quicker at lower speeds - like a small block V8.(max torque is at significantly lower rpms than on the CTS)
    Note - this is for the non DI version, naturally.
    But these engines are fantastic. I test drove an Avalon and it felt like a larger 3800. there wasn't the maximum power at any speed like the GM 3.6. Basically if you are gong over 10-15mph, it's already at that long plateau/near maximum torque. Most of all, though, even in overdrive at 65mph, you're *this* close to it as well. There's no throttle lag at all, which is why it doesn't feel like a "Buick". :P
  • louisweilouiswei Member Posts: 3,715
    LaCrosse CXS:
    Horsepower: 240 @ 6000 RPM
    Torque (lb-ft): 225 @ 2000 RPM
    Avalon:
    Horsepower: 268 @ 6200 RPM
    Torque (lb-ft): 248 @ 4700 RPM
    Ah yes, you are right indeed... :confuse:
    I don't know what kind of magical thing you were smoking when you went to test drive the Avalon but based on your experience, whatever you drove is not an Avalon. Also, cruising at 65 mph, torque really doesn't matter anymore. If you want to pass at that speed all you need to do is step hard on the gas and the engine will downshift with RPM jump to around 4k, at that point, you'll have all the torque you need.
    By the way, comments like "I test drove an Avalon and it felt like a larger 3800" isn't really helping the credibility of your post at all.
  • allmet33allmet33 Member Posts: 3,557
    Well..with regular care and maintenance, my '02 Sonata went 105K miles in 4 years with no problems at all. It's still ticking somewhere, but don't know where as I traded it for my '06 Azera.
    So...if you're turning 30K miles a year, it might even be in your best interest to pay the extra money for the extended warranty that bumps all the other main warranties up to the same 10yr/100k miles as the power-train. Not sure if that's something you can do with a Taurus. Also, not sure about the build of the 3.5 in the Taurus, but I know for a fact that the 3.8 in the Azera uses a timing chain, so that's one aspect you don't have to worry about (like I did with my '02 Sonata).
    Huh? The 3.6 HF GM engine is almost exactly the same engine as the other better V6s available here - only that it is not quite (almost) as 'advanced' as the Toyota engine. This is the engine a number of us have been saying all along 'belongs' in the Lucerne.
    gearing BTW has very little to do with anything in this context - the reason why that 'fantastic' 3.6 moves quicker at lower speeds is all about HP the product of your precious torque and the ability of that particular engine to increase engine speed freely - the same thing you'll find in the Toyota 2GR, the Nissan VQ, and FTM the Hyundai 3.8.
    Reread post 6090 and maybe you'll understand that torque is worthless (it's a STATIC measurement) without an engine's ability to turn it into HP. The engines in this group that you can (and do) efficiently use the torque they produce include your 3.6, the Toyota and Nissan 3.5s and the Hyundai 3.8 (among others) - the engines that don't are things like your 3.8 liter dinosaur along with some slightly more recent pushrod v6s found in Impalas.
  • tjc78tjc78 Member Posts: 17,292
    That is just where the 2GR becomes really sweet! :)
  • cdmuilecdmuile Member Posts: 152
    I've had my Azera Limited Ultimate for over 2 years now. This is the first new car I have ever had that has not been back to the dealer (but once...chipped steering wheel trim) for warrentee work. It's really an incredible vehicle. Couldn't be happier.
  • cobrazeracobrazera Member Posts: 352
    According to the Buick website, there are 3 versions of the LaCrosse now. The two lower trim models are CX and CXL, which both amble on with the antiquated 200HP pushrod 3.8.
    The top model is the " Super " which comes with the 300HP pushrod 5.3. If you drove the " Super " it's no wonder it felt like a small block V8 - it is one.
    Apparently GM has allocated only one camshaft per LaCrosse, so the 4 cam, 3.6L V6 is gone.
  • scwmcanscwmcan Member Posts: 399
    I would guess you Volvo comment might have some impact on the Taurus direction, sincde it is basically a Volvo platform with a ford body and drivetrain. I guess I would have to say,(as others have) figure out what you need out of the car and buy the one that best fits your needs. You may find that hyundai parts (out of warrenty which is a fairly long time of course) may be higher priced than the ford ones (you will need to check this out yourself, I haven't looked in a long time, I just know that the prices of hyundai parts used to be fairly high, this may no longer be the case, and of course you have a longer time before you need to buy any so it could even out). I would say get the car you like best and don't let anyone change your mind, you are the one that will be driving it for a long time. I think with proper care either one will meet you requirements.
    Scott
  • busirisbusiris Member Posts: 3,490
    If you actually put 225K miles on it, you are correct. However, if you get in an accident and the car is totalled, then residual value may become very relevant....
    When I was much younger, I purchased a car that would have been perfect for me, except that I was hit 5 months afterward, totaling the car. Since it was a model with a high up-front devaluation (similar to Hundai's and Kia's at this stage in their development in the USA market), I wound up being upside down in the loan after payoff. It was a financially difficult time, when to me, a nickel was the size of a Conestoga wagon wheel.
    Not any disagreement here, but just one more thing to consider when buying a car...
    True enough - but an odd perspective - worrying about a car's value just in case it is totalled. In this case I would guess that you would have a 'value' problem almost regardless of what you bought, Ford or Hyundai, or even had you 'sprung' for the more expensive Avalon with usually higher resale values.
    When I bought my Avalon (with a substantial (5 figure) down payment) and financed the rest - the dealer was 'disappointed' that he couldn't justify selling me some additional 'upside down' insurance - something that covers the difference between a car's market value and what you might owe on it. The point being that it is possible to insure yourself against the 'upside down' stuff, and while it may be more likely to happen on cars with traditionally higher depreciation, it also happens to the Toyotas of the world. Some added peace of mind I guess in that unlikely event that you total a new car.
    Well, that's a shame, then. The 3.6 was their best engine by far.
    The maximum torque for the 3.6 is roughly 2000rpm, but that is literally 2-5% higher - a slight blip - than the rest of the torque curve. ie - you get roughly 200 lb-ft at 1600rpm. That's right where the thing is in overdrive at 65-70mph. You don't need to drop a gear to pass someone.
    LaCrosse CXS:
    Horsepower: 240 6000 RPM
    Torque (lb-ft): 225 2000 RPM(roughly 200 or so at 1600, and stays above 200 until redline)
    Avalon:
    Horsepower: 268 6200 RPM
    Torque (lb-ft): 248 4700 RPM (1600 rpm is closer to 150lb-ft)
    You have to rev it really hard to get that power. The problem is that with its mega-speed transmission, it has two modes. Grandmother and drop down several gears to pass. Getting it to do a normal roll-on from 40-60mph is not something that it wants to do without down-shifting. GM's mating the older CXS with the 3.6 and their 4 speed transmission means it will stay in a gear to utilize that power for longer.
    It really does drive much better in city traffic as a result. Other than it being FWD, it actually was better than the CTS 3.6 as well. Oh, and it had the same basic suspension as the last generation CTS.(2007 CTS base vs CXS = about the same)
    Why they dropped that sweet engine/trans combination I just don't know. The V8 is front-heavy, gets poor gas mileage, and doesn't drive really much differently due to it being an old pushrod they yanked from their truck division. Maybe it pulls a little harder than the 3.6, but in traffic, power comes on much slower.
    Do you have the torque curve to back that up? Last I checked the 2GR has a rather flat torque curve so I would say 1600 rpm is probably more likely to be 200 lb-ft. Also, what's wrong with down-shifting when I have the taller gear at cruise which returns better FE than that ancient 4-speed?
    do you know that or just guessing ? Not that GM is above some 'gearing tricks' (they've done that for years and years with the 3.8) - it is really low (the Avalon turns 2100 at 70) It would figure that the EPA highway mileage would be better than it is if your 1600 rpm is right. :confuse:
    Buick has just announced the prices for the Lucerne Super and CXL special edition and here are the summaries:
    Lucerne Super:
    - 4.6L Northstar V-8
    - 292 horsepower
    - 288 lb.-ft. of torque
    - MSRP: $39,395 (including a $765 destination freight charge)
    Lucerne CXL Special Edition V-6:
    - 3.8L V-6
    - 197 horsepower
    - 227 lb.-ft. of torque
    - MSRP: $32,150 (including a $765 destination freight charge)
    Lucerne CXL Special Edition V-8:
    - Northstar 4.6L V-8
    - 275 horsepower
    - 295 lb.-ft. of torque
    - MSRP: $33,850 (including a $765 destination freight charge)
    Source: Buick Lucerne Super finally arrives, brings CXL Special Edition with it
    $40k for a Buick? $32k for a Buick with an ancient V6 that produces less than 200hp? What the heck are they thinking? To be honest, at $34k the V8 CXL Special Edition is not that bad of a deal if one is into V8 American land yachts but that brings up the question: Who the heck is going to buy the Super given that the CXL Special Edition has similar performance with $6k less? :confuse:
    If Buick is tired of selling sedans they should just tell us...
    It really seems like Buick is really getting the shaft when it comes to powerplant technology. The sad thing is...GM has a V-6 that's capable of producing the same numbers as the 4.6 in the CXL Special Edition. That's sad, truly sad!!!
    In all fairness there is a $1500 rebate on all Lucernes and the dealer will sell at probably a couple hundred above invoice... so that puts the price more in line. However, at MSRP I truly see your point. You know whats even funnier? The Lacrosse Super has more power than the Lucerne Super. I know the Northstar in the Lucerne is certainly more refined than the 5.3 in the Lacrosse, but still how does your flagship have less power than its baby brother?
    Its amazing the thinking that goes on over at Buick.
    What thinking? :surprise:
    Welcome to the wonderful world of General Motors management and planning!
    You really have to wonder what's going on (or maybe not going on) in the minds of GM's corporate planning management division...
  • alexstorealexstore Member Posts: 264
    What about Ford Taurus having more HP than Lincoln Town Car? Similar thinking still exists at Ford.
    I see your point, but, the TC/GM/CV have one foot in the grave already. I would say without fleet sales they would be gone. The TC in its current form dates back to 1990 with only sheet metal changes. The "panther" platform I believe goes back to 1980! Still they are surpisingly good driving/riding cars other than being totally uncompetitive in their respective classes.
    The Town Car having less HP than a Taurus can simply be the thinking that the Town Car is aimed at older retirees who just want solid transportation and don't need all the HP found in the likes of the Avalon, Maxima, Azera, ect. I'm not saying all retirees think like that, but there is a great many that do as evidenced by the number of "old" folks you see driving Town Cars, Grand Marquis and Crown Vics.
  • kdshapirokdshapiro Member Posts: 5,751
    In my town the "old" folks drive 750s, AMG 500s, etc. :surprise So I don't have a basis of "comparison".
    actually that V6 (with DI the 3.6 can exceed 300hp) is also capable of matching the V8 in the Super - $40k for a Buick is OK because nobody who actually buys the things expects to pay even 'invoice' for it. Kinda of a Catch-22 for a number of manufacturers these days and not limited to just GM/Buick - but the pricing theory does work, overprice something that you intend on discounting heavily and the customers somehow think they got something for nothing when, in fact, they only got exactly what they were willing to pay for. Does wreak havoc with those resale values though, and a jewelry/furniture store type of philosophy that only proves PT Barnum's adage?
    The only reason that the platform is even around is because of the fleets. Ask any NY cabbie and many law enforcement personnel what the vehicle of choice is. The cars can take a beating. The TC survives because they are making the CV anyway. IF Ford wanted to they could have dropped in the 4.6L DOHC from the Mark VIII anytime they wanted.
    I see your point about older people driving them... heck my Grandfather has had nothing but TCs/ or GMs my whole life. I tried to get him into an Avalon last time and got laughed at. Although he does like my Avalon at 80 its hard to change his mind. V8 and RWD the only way for him!
    thought that the CV was only available thru the fleet dept.? but the GM and TC could still be had - even if the TC sets depreciation records every time one is driven off the lots.
    There is, however, something that can be said for these heaving, space and fuel inefficient dinosaurs - most any 'shade tree' mechanic can repair them easily from parts available in the salvage yards.
    Does anyone know where manufactures of vehicles on this forum post demographics about people purchasing their cars. It will be interesting to know average age for large mainstream sedans buyer on this forum.
    the previous version (04 and earlier) Avalon was a median age of 64 - a bit different then 'average' age but also something that has gone down a few years since the 05 came out.
    Would suggest to you that this particular vehicle type - large sedan and given the fact that they are generally the more expensive 'top of the line' models would lend itself quite naturally to an Avalon-type demographic. The Maxima and possibly the 300/Charger would likely be more appealing to those younger folks but still have an 'older' owner then most other vehicles.
    Haven't been on a Ford lot in while, but last time I was there were a few CVs for purchase. Nicer ones w/leather and the toys. I did a search of our local Linc/Merc dealer and they had all of 1 TC in their new inventory. Funny, when I drive by it there appears to be many late model TCs probably all "program" cars. You would have to be a little off your rocker to spend 45K+ on a new one when you can get a one year old low mileage example under 30K.
    I have a soft spot for full size Fords. My first car was a GM and I had a mint '89 TC that I sold a few years back. I do like them, however I would never have one as a daily driver. My Solara handled the duties when I had that car, and there are even better choices now!
    relative to original sticker price the best 'deal' out there might just be that 1 year old GM or TC. Heck, a Town Car can have a MSRP of $50k pretty easily and then be bought a year later for about half of that (or less)!
    I too drove a sequence of CVs (company cars) for many years and while they might have been somewhat unremarkable in most respects, they were reliable and they did provide what they were supposed to - comfortable transportation for me and whoever I was taking to lunch.
    What I find funny is how much roomier our Avalons (Azera, Taurus, Lucerne, also) are. You would think with the overall size difference that they would have bigger back seats. I guess FWD layouts are good for something.
    Guess they are - and for many folks FWD cars are safer for them to drive.
    I believe that these spiraling gas prices will put a hold on all these HP increases we've been seeing lately so that the TS problems that come with high HP and FWD will become less of an issue and that FE problems may also slow down this movement that seems to be catching on towards RWD. Furthermore I would think that these higher HP V8s will become a tough sell even if it is something as powerful and apparently as capable as the G8 GT. Time will tell, of course, but I'd rather be selling my Avalon right now than trying to get my money out of a 300C, for example.
    Looks like there is hope in the Ford camp...
    Source: Inside Line
    sure does minimize some of that Volvo boxiness, and thankfully gets rid of that gawd awful razor blade grill (now it looks more like the current Avy grill) - guessing there are minimal drivetrain changes, if any - but a better (and more aggressive looking) car in any case.
    Take a nameplate that typically has low resale then add a gas hog V8 and it just gets worse. I can't imagine the poor people trying to trade in Tahoes and Expeditions, must be getting killed.
    Not bad at all I must say!
  • tonycdtonycd Member Posts: 223
    If they finally upgrade the concrete door panels and cheapo gauge cluster inside, they'll really have something. I have no clue why they didn't do that in the '07 rename/freshening.
    I'd like to buy American, but c'mon guys -- benchmark Avalon and Azera, not your own previous model or the Impala.
    Aside from the gauge cluster I never really had a problem with the interior. Its pretty well made and comfortable. Not quite in the Avalon/Azera class but better than the Impala or Charger.
    the 500/Taurus interior impressed me as well - thought the fit/finish was decidedly non-Ford-like. Space efficiency is phenomenal of course, I guess the 3.5 addresses the power problem (maybe not the refinement problem), but at the expense of a very unremarkably conservative exterior. Currently. just plain dull and ugly IMO. The 'new' one looks better or we could wait for the RWD Australian Ford 'Falcon' which appears to be the G8 revisited. That one we'll just have to waiot and see - Ford seemingly has lots of problems getting new (and competitive) products to market.
    That is what happens when you have no development $$$ because you put all your eggs into trucks and SUVs before the days of $3.50 gas. IMO the last thing they need is a G8 clone (heck I don't think Pontiac needs it either). Improve on what you already have in the Taurus and try to create a car people want not something they think is a deal because they bought it 2K under invoice.
    there seems to be a movement afoot that is going to bring back the 'traditional' American RWD sedan- independently suspended (and unrelated to the GMs/TCs etc.) and probably with some sort of 'trick' DOD system so at least the EPA thinks it does all right on a gallon of gas. While this may eliminate some of those problems with these higher HP FWD sedans, it will create a few for those that have never seen or really driven a RWD car - those folks that learned on a circa 1980 car or later - meanign most of us. I agree though that if I can get 25 mpg (overall) on a car this size and still have something that will pull me to 60 mph in less than 7 seconds , why then do I even want anything more especially when that alternative is going to cost me more than a few mpgs. Most drivers of the cars in this category probably couldn't tell you where the drive wheels are, and certainly don't drive in a manner that they could care.
    As far as Ford is concerned, they are unfortunately largely controlled by bean counters and seem destined to take a position as a second (or third) tier car manufacturer - if they survive. Read somewhere that they now have such a large debt load that they will not be able to service that debt out of all these profits they don't make - one of the reasons for the 'junk' bond status.
    This (Ford's future) would have to have some influence on any decision I might make to spend $20k+ on anything Ford makes regardless of how good it may or may not be. Chrysler seems to be a bit closer to 'Armageddon' but GM seems to making an effort at righting the ship. OR they may just end up as a truck manufacturers, which might be just what they need to do - heaven knows that an awful lot of very high profit PUs are sold, despite those ridiculous discounts etc. that they are sold at right now.
    And although the Taurus is priced as a viable alternative to things like Impalas/Azeras/Chargers , you are absolutely right - many times the 'best deal' out there has little to do with discounts or even initial cost- something that applies to a lot more than just cars.
    In my opinion, the MBA's (of which I am one, sorry to say) have taken over the Big 3 in the USA. Their inability to look at the long-term is the main thing that has hurt them in the past, as well as now. They appear to be so focused on the present quartily profit picture (as, I might add, many US companies do as well) that they lose sight of the big picture.
    That is one reason that you see them introduce cars at the strangest times. For example, the introduction of high performance gas eating vehicles just at the time gas prices are increasing.
    Chrysler is by far the best example, hiring Nardelli from Home Depot fame...What were they thinking??? Exactly what auto manufacturing experience does he bring to the table?
    Remember Henry Ford II??? "Small cars mean small profits!"...And GM seems to me to have a total disconnect between its design/marketing arm and its manufacturing division...a great example is no stand-alone NAV system in the Malibu, but competing against everyone else in that segment that has it as an offering. I'm sorry, but On-Star navigational aid isn't the same...
    I think you might be right...I don't see the US auto industry surviving in its current form. I don't know what it will develope into, maybe trucks, maybe consolidation/mergering.
    It will be interesting to watch TATA Motors and see how it handles Jaguar...maybe that will give us a clue.
    I was really, really disappointed that Hyundai didn't come through and buy Jaguar. It would have been a perfect marriage. What Jaguar needs is not a $110,000 Portfolio model, but a $40,000 sports car that goes out to LeMans and other venues and kicks a**.
    My compliments, though it's too late. Yes, that would have been a truly outstanding idea.
    Thinking outside the lines, I see Mercedes is about to give up on Maybach. Wonder if they'd sell the name to Hyundai for a nickel?
  • snaglepussnaglepus Member Posts: 160
    " . . . that Hyundai didn't come through and buy Jaguar."
    That proves Hyundai does think properly at times! ;)
    Can you imagine what it would be like to try and get a Hyundai-Jag fixed
    at the dealership with all the problems they might have? :lemon:
    :D
    Aren't they all? Its just a shame, they have no money to make better cars. I think Ford had the right idea with the Fusion and Taurus.. but obviously the public didn't because its rebate central with both of them.
    I couldn't agree more!
    good good post - I guess it can be said is thet the worst thing that happened to the "big 3" is the cheaper gas prices/truck-SUV craze of the 90s.
    go along with this as well - what does Hyundai need right now - how about a 'luxury' brand like Jaguar - even though that brand has lost some of its luster under Ford? I think the Genesis, for example, as a Jaguar might have a whole lot of a better chance of acceptance and success with that label. Producing a car that mght 'kick a**' as you suggest might be easier for a Co. like Hyundai to do, than it might be to get folks to look at it seriously.
