Visitor Agreement.
I feel I need to update my post. Car was repaired. Loose bolts on the drivers side wheel arm. Is that not scary? I have owned many cars and never had anything like that.
I am experiencing the increased jolting (accleration) that others are mentioning. Nearly kissed a brick wall.
The latest has been the service at the dealer. I can tell you about choice. My next vehicle can be the biggest piece of crap out there but I BETTER get GOOD dealer service. Yes, I want someone to call me to let me know my car is ready so I don't have to find out that it has been ready for two days and someone neglected to call me. In addition, let me know that parts are available for the car in the first few hours. Don't make me call three days later to find out parts are on order.
The latest is the car just went dead on the freeway in heavy traffic. Was able to coast to the side of the road. No idea what this is. I am having flash backs to the '89 Thunderbirds that just went dead for no real reason. I am afraid Ford still has that bug circulating around. I will update on this one as soon as I have a solution.
Ford has so much potential and they blow it at the dealerships.
As for the resale value. I have always been happy that I could go get a great used that cost $25k new for around $3500. One that is less that five years old. My mistake. I bought one new. Boo hoo for me. I will drive this one if it still runs until I have to put in a 1968 V-8 and replace the vin number to a pre smog car. The body and frame are fine. There is something else amiss in the mechanics.
Good luck to you lucky ones who got the Tuesday through Thursday cars off the assembly line.
Had the rear brake pad issue at 22K miles.
Now, 46K miles, and I'm getting the sudden acceleration/bolting now. VERY SCARY! Had it to dealer, and they "re-timed the transmission" 500 miles ago, but still doing it.
Anyone have a fix for this?????
It started after the dealer had to replace the A/C compressor (extended warranty, fortunately).
Any info would be greatly appreciated....
TSB 05-17-5
09/05/05
ENGINE RPM FLUCTUATION AT HIGHWAY CRUISING
SPEEDS - VEHICLES BUILT PRIOR TO 8/2/2005
Poor argument, and I hate it when "car" people use it. My car cost $28K and my new computer $550, which I expect to replace every couple of years. Not so with my car. When I can buy a new car for $550, then tell me to expect less than I deserve.
I will never have another Ford!!! I liked this car and it has been through a lot, and I have taken it to Ford everytime for whatever problems have popped up, and within a couple of years, the same problem recurs. Tells me they never fixed it correctly to begin with. Their service STINKS!!! I even told Ford that, and I did not receive any reaction at all from them. They could care less!!!
If you could help, please let me know.
good luck
sboyenger: I have sprayed white grease up into the trunk latch which helps to unlatch the trunk. I use to have to press the trunk release several times to get to unlatch, now when it acts up I just spray the white grease and it works for several months. The lift is another story and I have thought about replacing the lift cylinders but have never done it. I just lift the lid up once released and make sure it is up all the way as I have hit my head a couple times... it finally sunk in my head to make sure the lid is up all the way.
Under the dash....way in there there are two electrical wires. These two wires are to have a wrapping on both wires on them. Well, after a while, they rub raw, just from driving...and the movement of the car. So, you have to take it in...and they will rewrap those wires so they don't touch each other anymore. This stopped mine.....See, each time the wires touched each other , it would buck. Hopefully this helps you!
Thanks. :sick: :lemon:
i have the same problem with my 2007 five hundred, it has been doing it for a while and i call my local Ford dealer and they claim that they have not seen anything like it , i guess nothing is going to happen until someone gets kill or if we are lucky just ran over , i am afraid to get it into the dealer and they will put tons of hours and turn around and charge me for every minute. i got this phone number to call NHTSA (National Highway Traffic Safety Administration) at 1-888-327-4236 or online at www.nhtsa.dot.gov and we may be able to do something .
My only issue is the mileage. How long will this car last? I put 60 miles a day on my vehicle and I dont want to buy something that isnt going to be around in 60-70000 more miles
:P
Please don't let this go. Contact me for any help I can offer. I have my Ford Complaint number if you need it.
My Ford dealer said he tried to get Ford to side with us, he had me come in and take extensive pictures to show them.
Thanks for sharing!
I have and need others to join in to get this going.
Ford's TSB 06-17-9, which supersedes the TSB 06-6-2 describes the issues as "very temporary intermittent condition". HARDLY! Reading the myriad of postings from Ford Five Hundred and Mercury Montego owners both here and at the NHTSA site http://www-odi.nhtsa.dot.gov/complaints/index.cfm- this is a well documented, common issue affecting the safety and finances of many FORD/MERCURY owners. I would love to see a recall on these cars because of this is a widespread issue and is a common defect.
in my Five Hundred, i had the FWD one so i just had the 6 speed auto and i found it to be very reliable. didnt have engine problems until 150k miles and then i traded it in for my current car. I miss the Five Hundred every day though
Did you find out the cause???
