I have owned over 144 automobiles in my life, and this is the first time I have encountered this problem. What do you think it is.
brought it back to the dealer, they checked it out and said it was likely caused from overfill at the manufacturer...they cleaned it up and said should be fine
that was 3 weeks ago....
just checked it again...and found more fluid dripping on the crossmember...appears to be leaking from the top of the transmission...any ideas?
Ray in Virginia
What did you find out about this problem?
Ray In Virginia
Thanks, Tx_tim1 in Texas
My problem (which sounds like yours also) turned out to be the master and slave cylinders.....changed both, less than 100.00 - never a problem again. Ran like a top. Since, I've traded the truck for a 07 tacoma - to be honest, wish I still had my 01. Hope this helps
I have a 2002 Tacoma Xtra Cab 2.7 4WD SR5 that I purchased new and now has 92K miles. It has always shifted flawlessly. Yesterday, I got in it to go to work and on my way out of the neighborhood I missed 3rd (this never happens). Then I got out on the street and missed 3rd again and then missed 4th!. I can get it to go into gear (3rd and 4th) only if I am deliberate about my shifting. 1st,2nd,5th,and reverse seem unchanged but 3rd and fourth feel totally different through the stick and it seems like the throw is shorter than normal. I haven't crawled under the truck yet to take a look but this did not occur from snow, mud, impact, or anything else. It was driving perfectly, I parked it overnight, and now it is different. I am curious to look at the linkage this weekend and see if I can see anything obvious but I was wondering if anyone else had experienced this and might know what has happened.
It has all the mounting harware I am just not sure where it all goes. Does anyone have the instruction, I would sure be greatful. Thanks
Now I seem to be missing 1st gear for a few seconds about half the time, especially if I am making a turn (uphill from a stop sign into traffic of course). I'm heading back to AutoZone tomorrow to see if they can illuminate me on this subject. Does anyone have a clue for me before I go spend a months salary on a new tranny? Thanks.
Has anyone ever experienced this clunking, or problems downshifting to low with an auto transmission??
This first gear problem stopped when I decided to hold first gear in gear with my hand while driving. In other words, first gear was fine as long as I applied pressure to the gear stick while it was in gear. In the 5th week, third gear began acting up. Basically, when shifting to third, the gearbox would grind loudly and kick the gear stick out of gear. It felt as if the gear box was refusing to accept third gear. The following week (week 6) first gear was fine but I could not shift into third gear. The gear box refused to accept third gear. In response, I bypassed third gear for 2 weeks and shifted from second gear to fourth gear without any problems. At this point all of my gears were working fine except for third gear. In week 8 (which was 3 days ago) while carrying a heavy load in my truck bed, I decided to try out third gear once again. This time third gear worked fine.
I have been using third gear for 3 days now and it feels fine except for one thing: it still does not feel like it is completely locking into gear. In other words, it feels a little spongy. Currently, I am driving my Tacoma with all 5 gears plus reverse. They are all working fine for now, but I am puzzled about this gear box issue.
Any help would be greatly appreciated :confuse: <img src="
ManN
What kind of response did you get from Toyota to your slipping transmission?
I also am experiencing some whistiling too. they said that was the seal around the windshield needing to be fixed. other tacoma's are having same problem...
not work right. I need to go to the next step
and this is one response I received:
"As for the slipping you mention... I doubt it. The transmission in this truck is controlled by the computer. It doesn't have vacuum modulators or governors like the old school stuff you are used to. What happens is that you tell the computer what you want, and it tries to figure out the best way to do it. It does this by keeping a record of what you have done in the past, and what turned out to be the best response to your input.
The computer in this truck controls throttle opening, fuel delivery, spark advance, cam timing, gear position, and just about every thing else that makes the truck go.
If you are not smooth and predictable with your input to the computer, you can confuse it. it's trying to keep up with your requests, but it has to change it's response because you changed your input.
Try being smooth with the gas pedal (It's not a gas pedal, it's only hooked to the computer) and let the computer learn your habits. it will get better about responding to your driving style quickly.
Yes, the truck downshifts when you are slowing down, and yes you can feel it. Sorry your nissan didn't do that, but the old school nissan tranny's faults don't mean the Toyota has a problem. After a while you and the truck will get used to each other and things will be fine.
That "Fly by wire" system in your Tacoma is an amazing thing. When you get the hang of operating it, you will love it."
I am saving every documented instance of this to a folder, in case I need to show proof to Toyota some day that other are having the same problem.
TL
I have the same issue with my transmission. 2009 Tacoma Prerunner V6 auto with about 20 miles. After turning a corner and accelerating, the transmission seems to have shifted into to low a gear making the engine rev and then an immediate hard shift. I don't call it slipping, though. It also sounds like a problem that hasn't been reported enough for Toyota to acknowledge it.
Toyota needs to back up there cars/trucks. or they might end up like GM,FORD & DODGE.
I'm going to talk with toyota when my scheduled service is due, and let them know what I think of this.
I'm going to read up on the lemon law, :
Toyota sent me to the dealer I got it from 45 mins drive to Georgia. They tested it and stated, "normal for the model" on my ticket. They reset the "learn code" and told me off the record that other Toyota cars had this problem in the past - Toyota fixed it with a new software/firmware release, but we just don't have a software fix for the 09 Tacoma".
I sent another email to Toyota last week but they are not responding to it.
I should have stayed with Nissan - not one single problem in 24K miles with the Nisan.
Very disappointed ...
Ben
http://www-odi.nhtsa.dot.gov/ivoq/index.cfm
Today on my way home my trans took a long time before it went into over-drive,. it stayed in a lower gear. not sure what happened there. it never did that before. I'm now around the 700 mile mark, My truck works just like everyone else 's
Try this, Put your truck into Neutral at idle, hold the brake, release brake. then put into drive and then give it gas, mine will have a delay before it moves forward then excells fast. I don't think this is right??
This could be a safety issue for these vehicles?
