I have a 99 V10 and on a good day get 10 - 12 mpg. These BIG BLOCK motors do drink a lot of gas. I got ours to pull our 10,000 lb travel trailer with and it doesn't even cough going uphill. Even though it drinks a ton of gas, I love my V10! I just had to have my motor replaced because the person who had it before me didn't do oil changes on a regular basis and sludge blew up the top end .
Dusty
Thanks, Berry :confuse:
k i have a 04 1500 ram and it just stoped working the other day had it to to a lokel shop and they said my pistons are shot need new moter my truck has only 104 k on it i go and get the oil changed regularly i have not called dodge yet would like to get some more info first so if any one has had there truck just die please let me no what happend to you ty
The 3.7 and 4.7 motors are almost invincible. I have yet to even hear of one that developed a major problem requiring serious engine repair or replacement that wasn't caused by operator abuse or neglect. I actually have only heard of one failure anyways.
I am aware of one 5.7 Hemi that had developed a knock which later was attributed to badly worn main bearings. However, there was suspicion that this engine had been run out of oil intentionally (this was a warrantee situation). I know of one other that had the top end apart for a valve problem.
However, bad Dodge truck engines are extremely rare. I know of none that have had a failure like yours. Its hard to judge what is meant by "bad pistons," Did this engine seize? If it did, was the engine overheated? If you lost the oil pump then that could explain "bad pistons." We need more detail on how this engine failed.
Dusty
ok it is a 5.7 and it is fully maintained all the time i take it in all the time and as for not hearing of any other i heard about 300 so far but they where all oil sludge in the engine resulting in engine failure my oil is clean so its not that so i did not miss use my turk i never drove over the seed limit. as far as i can tell you is my husband was driving so i dont no all the deatals on that all i no is 3 of the pistons are seized thats what the guy at the shop i had it towed to said now you have to under stand i love that truck it was the first thing i ever bought for my self and i am devastated about ben crying non stop i never let my husband drive it and i had to let him he was taking me to the hospatil so as you can so i dont remember much about gauges i just am hopeing it is still covered under warenty was hopeing to hear some happy stories
Also resently the oil pressure gage dips and says check gages. It has used about a quart every 4000 miles and I believe that is the cause. Ok anyone got any suggestions?
Corkscrew
Thanks, ,
I baby this truck. I have a 2001 Dodge Ram 4x4, 360 motor, 5.9 with 46RE, I think. Automatic Tranny. I have 180,000 miles on the truck and motor. I replaced the tranny with a Jasper about 90,000 miles ago.
About 30,000 miles ago I had the tranny flushed by a machine. The tranny started shifting funny a few weeks ago. I would give it the gas and it would shift up normally then sometimes it would not shift up, without letting off the gas a bit. I could sometimes take it easy and it would shift fine through the gears. Sometimes I could stand on it, and it would shift fine.
The other day it started as normal and will not shift up past 1st gear. I can go in reverse too without a problem. I can put the shifter into 1 and 2 and D and the truck will go but not past 1st gear.
I get NO codes but "P doNe."
"My first tranny went out with NO notice or acting funny at all. It just quit and the engine kept winding."
For the last year or so...If my truck would sit for a day or so, when I went to start it up, the transmission would have to build up pressure for a few seconds before it would finally grab hold and go after putting it in drive...I was told this was normal and not harmful.
I was told to change the filter and fluid, along with the governor pressure solenoid and sensor
Does this sound right? When I get the pan off can I do anything else that needs to be done like band adjustment, and to what spec? Taking into consideration the pan is not filled with debris. I guess a CLEAN pan is a GOOD pan. Can I tell if the right fluid has been used in it?
Thanks for any help you can give
Doing the On-Off-On-Off-On test I get no codes other than "P doNe."
Can I use another type of scanner and get codes...OR is this way of getting codes the same?
Thanks, Cwiseguy
Corkscrew
I had the Governor solenoid and Governor sensor replaced...I had the fluid and filter changed and the bands adjusted...
It did not fix anything...$400 and the same problem...
The tranny guy said I had the normal stuff in the pan for 80,000 miles and a little more than the average...
Does anyone have any other ideas...
My next one will be a manual tranny...
Thanks, Cwise
I checked the relays (the old fashioned way: turn the ignition to "run", pull the relay out and push back in, feel it click in your fingers). The ASD relay makes and breaks fine (feel it and hear it engage/disengage). The fuel system relay does not. Take the fuel system relay and plug it in to the ASD relay slot, it worked. I put the relay from the ASD slot into the fuel system relay slot, did not work.
Here is what I know:
ASD Relay works.
Good Spark to the plugs.
Volts at the fuel pump connector.
Fuel pump fuse is good.
No fuel pressure at the injector rack bleed/test valve.
The fuel system relay does not make with the key in the "run" position.
Before I blow 250 on a fuel pump module and spend the day dropping the gas tank, I want to make sure the fuel system relay is working properly. I do not have schematics for the system. If anyone knows how the control voltage gets to the fuel system relay (even if the answer is the truck has to be running for it to come on) I would appreciate it.
Gus-truck
