Dodge Ram Gasoline Engine Questions
Discuss the Magnum V6/V8/V10, the Hemi, and all the other engines that run on unleaded (and if it's old enough, leaded).
kcram - Pickups Host
I have taken me RAM truck to 2 dealers and after spending hundreds of dollars the problem still exists. Oh, you want to no the problem.? How about on cold starts the truck will backfire through the intake manual until it warms up. Ok, lets see the dealers replaced the purge valve, O2 sensor, fual pump, and FPCM. The truck only does it once in the morning and does not product error codes. The dealers are stumped. Any idea who may know what the problem is or has anyone experienced this problem before?
Dusty
As far as the dips, you might be realizing some accelerator pedal oscillation due to the abrupt movement of your body, meaning your foot is applying more pressure on the pedal as the vehicle body jostles your body. I get that sometimes myself.
Dusty
Dusty
2004 Quad Cab Laramie, Sport, Hemi, LSD, Towing. 50,100 miles now and getting 22+/1 highway and 17+/- city.
Thanks for any imput.
ahasher
Help pleze
Several things can cause this...most common being either a bad fuel cap or not tightening it properly after refueling. I would make sure that the fuel cap is properly tightened and then if the light doesn't go off after a few miles I would inspect the vacumn lines between the tank and the purge canister. If they are all ok then get a new gas cap.
I have a question about a truck that I just Bought it is a 2500 4x4 ext cab with a V10. here is my question this motor when it sits there at an idle it will make a big poof noise then blow the dip stick out. and it seems to be burning oil. is this an indication of a faulty pvc valve or does this engine have one . This is my first V10 so not sure about anything on it still learning.
Thanks Doug
PS is there anything that I should keep an eye on with this engine?
The truck is a RAM 1500 2001 4WD 5.9 Litre V8
Dusty
No fix.
I shut it off as I roll into the gas pumps, or at a drive-up window, so I can't hear the clatter.
acdelco
Know on napa rebulids
I'm in serious need of some help. I own a 03 Dodge Ram 1500. It has been a great truck but just in the last 6 months I've had some problems.
First the engine light came on, so I took it to a car place and they told me I had a evac system problem, but he didn't know where it was. He said that i needed to get the fule injector cleaner thing done, so I did. about a week later, the light comes on again. So I take it back and he turns the light off.
Well, after a few weeks the light comes back on, so my firend sent me to her auto shop, and they tested it and said that one of the hoses was cracked and chaged me $20 to fix it!! What a difference.
Fast forward a few weeks and now the tach it surging up. It started with me just sitting at a light at it would rev to 2 or 3 thousand. Then jump around 1,000, and then just die. So the tech can;t figure outs what's wrong. Things were going okay, then it started doing it again while at idle AND while I was driving. I took it back and they did a compression check and said that the cylinders were averaging 70-85 PSI when it should be 140-180. He didn't know how to fix it.
I then took it to a dodge dealer, (since the place I bought it closed). They checked it outr and said that they didn't think that was the problem, but did say that I should get a tune up and replace the spark plugs. So I did. I even went on a test drive. It acted a littel funny, but the tech didn't think it was a problem.
So I get it back just this past Thursday and its working fine. Then Friday, it starting doing th surging thing again. I called the service department and told him that I had the air on this time and it started again. I can't remember the other times if the air was on or not. He said that he still doesn't know what would cause the surging.
Oh I alsomt forgot, while I'm driving it'll rev up like I accelerated, but I hadn't even toughed the gas.
Well, if anyone could get me some adivse on what I should do or what they think the problem is I would be so greatful!!
Marsha
What type of oil are you using and how's the oil pressure?
Dusty
Cracked vacuum hoses can also cause this problem.
My bet is, however, that the Idle Speed Solenoid plunger is sticking, not an uncommon problem on engines that are starting to get up in mileage.
Best regards,
Dusty
I got the truck towed to the dealer it was bought from and they said yes the motor is toast. One of the spark plugs detonated in the engine. Sorry about your luck, they said, we told you to change the plugs 3 months ago and you didn't. They will not cover this failure at all. We have only put 23,000 kms on this truck since we bought it. Although they "recommended" we change the plugs, there was no urgency on our part as the truck is driven very little and we assumed the plugs had been changed when we bought it. I have the plugs removed from the truck, and other than a little carbon build up they don't look too bad. Except for the one missing an end!The truck had been running fine, up til that point. No pinging or sluggish behaviour, which would have told me to get the plugs done! Any comments, suggetions, would be greatly appreciated,
Kymmiecat
If it were me, I'd do two things. One, publish the dealer's name here and everywhere else I could so they might feel the pain of treating a customer like this. Two, I would contact a nice attorney to "write them a letter" at the very least. They are either feeding you a line of crud about the spark plug so that they don't have to pay for repairs, or they just don't want to and are telling you it's not a "covered failure". Either way, you should "push back" and hard!
I bought my first Dodge truck, an 06 CTD MEga cab. I can tell you I am happy with the truck. But I bought it when my Toyota couldn't keep up with my tow load. If I get any kind of treatment from Dodge or my dealer like what you describe, I'll leave the company in a hearbeat never to return.
You need to share the Dealer's Name!....Thanks.
The other Dusty
