Visitor Agreement.
pmaggan, let us know how your Volant intake & scoop install goes. I have been seriously looking at this system primarily for the benefit of providing a cool air source plus maybe some benefits of the ram air effect.
Regrading the benefits of StabiliTrak, it is only operational on the front wheels, so it is not a true Active Handling system like what is available for the Corvette. I do not know if you are getting that much in a front-wheel only system. You really do need the ability to selectively brake all four wheels to be able to fight a spin.
Bill
That makes a lot of sense......I was hoping someone would reply that the setup was already there and all we needed was a hose...thanks.
Last tank of gas: 15.6mpg calculated/15.4ampg DIC - 36.7amph in mixed driving.
I love this big beast.
The Stabilitrak system on the Denali can brake any of the four wheels, not just the fronts that avolvofan claimed.
StabiliTrak®:
Standard on the Yukon Denali and the Yukon XL Denali, the system senses your steering wheel position, vehicle speed, brake pressure, lateral acceleration, and turning rate to adjust the engine speed and brake pressure to the front wheels to help keep you on your intended path.
I imagine that all of the readers of this forum would appreciate any factual information on StabiliTrak. If there is information that is published by GM that confirms a four wheel brake pressure adjustment, then please post it.
I bought a used 02 the 1st of Feb. Cold weather mpg (manual calc) was running 12.8 - 13.4 daily driving, 50/50 mix. I've been using 87 octane and have switched to Mobil 1.
Most recently, just for giggles, I decided to try 89 octane. My results from the one tank I've run are;
Eliminated momentary hesitation at startup from stopped position.
Slight improvement in smoothness of engine at idle.
Sense of increased power.
MPG up to 15 or about 10% vs cost of fuel increase @ .10/gal or about 7%.
I don't know how some are able to achieve 17 - 18 mpg on the 6.0 engine.
Given the EPA 12/15 rating for the 2002 model I drive, I'm quite satisfied with my results. My fuel economy is equal to if not slightly better than the 2000 Ford Conversion van (5.4 V8) I was driving.
I really like this buggy and it has the makings of being the best vehicle I've ever had. My wife drives a Seville STS and she has no reservations about driving the YD. She loves the large exterior mirrors, high driving position, visibility, ride, and handling. She's not found anything she dislikes.
On the address line of your browser enter 'Stabilitrak' and '2003' or 'Denali'. Either will do. Then press 'Enter'.
You should see the following links amongst the list. They aren't exactly difficult to find, the first one of these links was the second hit from Yahoo.
http://media.gm.com/division/2003_prodinfo/03_gmc/03_yukon_denali- - /pr.html
http://www.automotivetrends.com/2003gmcyukondenalireview.htm
http://www.canadiandriver.com/news/020315-1.htm
http://media.gm.com/news/releases/020314_safety.html
http://www.gm.com/company/news_events/events/02chicago/truck_over- - view.htm
http://autos.en.msn.ca/Vip/Description/GMC/Yukon%20Denali/2003.as- - p
http://autos.msn.com/advice/windowshop.aspx?contentid=2908&sr- - c=windowshopping
Also there is a Truck Trend magazine, July/August 2002 with an article on page 54 titled Traction Tech detailing and reviewing the four channel system standard on Escalade and Denali for 2003.
One page of the review can be seen at:
http://www.trucktrend.com/features/tech/163_0208_stab/index1.html
I hope that all of the readers of this forum appreciate this factual information on StabiliTrak and can ignore the non-factual comments (GM dropping the ball? - well someone did but not GM!). GM should take some of the blame though for not checking their own web site.
For those who are interested, the pull to the left still exists, but no new Denalis at the dealer, so we are still waiting.
Of course, I am assuming you are not planning to do anything extreme like having the whole engine rebuilt by Lingenfelter or something of that nature....
Whats bad about the high copper and lead? It shows wear on the bearings. We will see on the next analysis if this trend continues.
Was mainly looking at YXL's but wanted autoride and a few other features which drove a new one up to about 44k.
hda
iskowitz, 37.9 sounds reasonable, although you may be able to do a little better. Shop around until you feel comfortable you are getting the cleanest vehicle for the best price: then enjoy!
The second oil change at 4700 was when I switched to Mobil1 synthetic and of course changed again with Mobil1 at 8700 miles.
I own a '00 Silverado with the 5.3 and have done numerous oil tests. None of which turned up the results like that on the Denali. The 5.3 and 6.0 are pretty much identical except for the bore and stroke. The next oil sampling will give me more info.
Regarding the break in period, I've heard it could be anywhere up to 10k miles. What I haven't heard before was high content of bearing material showing in any of the tests.
