Visitor Agreement.
My mechanic has replaced the cam and crank sensors and cleared the computer. This work was initially due to a stalling condition where the car wouldn't start again (the engine would turn over but not catch) and had to be towed in for service. Since then, the van seemed to run OK for a week or so but now has started to stall frequently under the above conditions. I've had it into the shop again but no codes are registering. The mechanic cleaned the throttle but can find nothing wrong.
This particular problem seems a little different from others in this string. Recently, I'm always getting the failure at exactly the same spot on my morning commute - the route involves a stop at a stop sign, then again at a light, up a small hill then while waiting for a light the stall. I'm open to suggestions as to how to isolate this problem. If I purchase an OBDC reader and attach it, am I likely to get any useful information when the failure occurs?
After successfully starting none of the instrument panel indicators work, speedometer, fuel, revs etc.
the turn indicator does not function
Take vehicle carefully for a run
return, park, switch off
Vehicle will not restart unless I jump again
Would a bad battery or alternator cause loss of instruments?
It's a 2002 Dodge Caravan SE
If you go to your local Advance Auto Parts ( for sure ) or other local parts store, they SHOULD offer free battery and alternator testing and will come right out and do it for you.
