Visitor Agreement.
Regards
Corkscrew
I hope someone can help me?First sorry about my bad enlish,but i am from Austria.
I have a Dodge Ram 1500 5.9 Bj 97 2WD with 63000miles.The transmission called 46RE i think.
Now my problem is that he shift how he want.He shift up and down every time and in all gears.I drive on,it works,he shift in the second gear it works sometimes,he shift in third gear it works sometimes and sometimes he shift in the second or first back and sometimes in neutral i think.I drive with the o/d and make kick down and he shift down normalbut sometimes the engine turn high without a gear and than with one and than without one,i hope you understand what i mean?If i drive with manual first and second gear it will works good,also the engine brake works good and i have no sleeping every where.so my problem is that he change the gears how he want and its be not nice,the engine turns up and down every time and i will not be realy faster.An other time he shifts normal.So i doesnt think that i have brocken bands or stuff because i can shift the gears manual without problems.
I thank you sooo much for helpfuly informations.
http://www.2carpros.com/forum/2000-jeep-cherokee--replace-governor-pressure-sens- or-vt95889.html
Corkscrew
No,its a 46RE tranny.But did someone have the same troubles or do someone know what i should do?I would make so much,but i dont know if its work and so i lost the time with the wrong repairs.Yesterday i got the information thats my tranny was a changet tranny.so i have only 20000 miles on it.So what can i do?Change the oil with filter,clean the Valves,cleane the cooler????I dont know.Doday i will drive to a crysler store and i hope they have a computer that he can read out my tranny.thanks :sick:
I have a 95 3/4 ton ram. I've owned it for 5 years, it has slowly lost power over the past two years. I used to tow a 28' travel trailer but now would be a struggle to haul a load of fire wood in bed with no trailer. the gas mileage has dropped to below 9mpg. I have replace the plugs wires cap and rotor, hollowed out the converter. cleaned injection system, I have no clue where to go next. truck idles and revs great but once you put it in gear pressing the gas pedal is like stepping on a wet tissue box, there is no real throttle response and the truck takes a very long time to come up to speed hills or flat. I thought maybe converter but don't know how to check this. any help would be great
thanks shigs
V6 & V8= 100 psi minimum, no more than 40 psi variation
Regards
Corkscrew
thanks shigs
Also check the fuel filter, transmission fluid level and check to see if the brakes are binding (does it roll downhill easily)
Corkscrew
http://www.dodgeram.org/tech/transmission/automatic/AT_band_adj.htm
On a 95 2500 you probably have the 46RH tranny. Note the paragraph under " automatic transmission band adjustment" Clutches play an important part in these transmissions.
Corkscrew
kcram - Pickups Host
To compound the problem i added 150+hp (above stock) to the motor, cant even use 1/4 throttle. Afraid to melt transmission then my work truck will be down for weeks. I want to build a tranny to hold the added power. However, would like to figure out how to fix the overdrive problem before i start throwing money away.
ANY IDEAS, HINTS, ADDVICE is welcome!
They also do all kinds of auto work, not just transmissions.
Ski in TX
yor best bet,and this means ALL of you dodge guys,is to let the truck warm up in neutral,because as said,the pump wont flow in park.
hey Randy,
speaking of cold,the other day i fired up my 97,and the front seal? i think blew out..its pouring tranny fluid out between the block n trans..am removing motor today and installing it in other 97,as the old girl has earned the rest...bought it for 230 bucks,and drove it over 30-000 miles.
wondering if transmission is still good,ie,just needing a seal,or was there another reason it blew?
thanks in advance
cheers,Rob
PS anyone with 48re problems?
:sick:
We ended up rebuilding it. Yesterday they put the tranny back in. Took it for a test drive and it ran great. Went back to the garage to fix a minor problem with the wiper blades. After that they were taking it on its final test drive, and to put some gas in it before driving it out to me, while checking to make sure everything shifted correctly something went wrong. He got it up to second gear, let off the gas so it would shift to first, laid on the gas again, and nothing happened. He said it was essentially, in neutral. We replaced everything on the tranny including the torque converter and cooling system. We are stumped. I've been without the truck for 2 months now and in that time I managed to kill a car i was borrowing from my uncle by cracking the head and the engine block. Not to mention in January the car accident i was in (i was the passenger) immediately after towing my truck, totalling my mom's car. I've been able to borrow her new car but she's starting a new job. So now we're scrambling to get my truck working because i need to be able to get to work, school, and various other places. Any ideas everyone has would be much appreciated.. we're lost!
cut the Tranny lines out by where they mount at the radiator and add a cooling unit.
a Good one
be Sure to cut it where the Factory RESTRICTOR bushing was/is inside the factory line
theres some sort of bushing that restricts the flow to heat the tranny fluid up quicker...this usually clogs up high mileage...get rid of it.
then unplug the battery for awhile,i do it overnite.
rehook it up,start it let it warm up in neutral,and drive the truck while Manually shifting it for awhile,then try normally driving left in D.
i had this problem too,the magical mystery will it work today transmission..the above worked
when the truck finally died,it had 310 tho miles
