July '08 A/C-Heat not blowing on driver side and leaking something(freon?) on Passenger side floor causing puddles...Dealership In Arkasas replaced blower motor. Wound up doing it again a day later...
August '08 Mechanic replaced something that made it all work until...
November '08 A/C-Heat went out throughout the whole vehicle in ...Mechanic replaced some box on passenger side which caused it all to work except the Drivers side.
July 09- Dealership in Louisiana says there's a leak and bottom half of a/c needs to be replaced, along with a part on the drivers side...$2,000. Bringing it back to my mechanic(friend) rather put money in his pocket AND he said, "no way on costing $2,000"
Any help info on this situation would be helpful!
Otherwise you need to deal with a professional A/C shop, or a dealership. Many A/C shops are good on the A/C items inside the engine compartment, replacing parts and recharging. If you start talking about inside the cabin....personally....I'd be using the dealership who specialize in that particular brand.
Since you mention the fan being 'turned on', I will assume that your fan is the type with electric motors. Assuming that the squeak isn't those electric motors themself, then I would suspect that those motors, are putting an electrical load on the alternator, which in turn is putting a physical load on the serpentine belt.
So you could have a worn belt (do you have more than 30-40K miles on this belt?) or the idler pulley for the belt is worn (or has a bearing going bad).
Many A/C systems have a clutch on the compressor. So although the outer pulley is spinning with the serpentine belt, only when the a/c clutch is engaged is when the compressor itself is turning and putting a load on the belt.
My first thought was that the fan speed control switch was bad, but that doesn't explain why the fan would continue to run even when the ignition switch is turned off. My next thought was that there must power supply relay to the fan is stuck closed. I checked every relay in all of the fuse boxes, but couldn't find anything that appears to control the fan. Also if it was a stuck relay, it doesn't explain why the speed control doesn't work? I removed the kick panel on the P.S. & there is some sort of control board between the fan & the supply harness. I was hoping somebody could point me in the right direction, so I don't end up buying expensive circuit boards that won't fix the problem...
Kind Regards
Gus
gussie@ntlworld.com
We were told by a mechanic that the "bend" door is moving very slowly and takes a long time to open. I was also told you have to take the dashboard off to fix this.
Can somebody advise what they think the problem is and what it might cost to have it fixed?
Blend, as in blending the hot air and the cold air, to get the temperature that you want.
It's the pot/rhe/relay behind the dash, where (in my case) pin1 keeps getting corroded. I dremeled it the first time, but after that, I just replaced the part. $30 at GM or $18 at O'Reilly. (BWD part number S15002). I haven't addressed the corrosion issue.
Quote:
Condition
Some customers may comment about an underhood rattle noise heard on acceleration or a sudden loss of A/C system performance.
Cause
This condition may be caused by liquid slugging of the A/C compressor. This condition may cause an internal failure in the A/C compressor. The serpentine belt
tensioner and serpentine belt may also be damaged.
Correction
Technicians are to check the A/C system performance and compressor operation using the following repair procedure:
1.) Open the hood and inspect the A/C compressor for damage and to see if the compressor is seized. Verify that the serpentine belt is not damaged or missing. If the A/C compressor is seized, proceed to step 5.
2.) Perform the A/C System Performance test. Refer to the Heating,Ventilation and Air Conditioning (HVAC) section of SI. Correct any performance concerns or refrigerant leaks that are found.
3.) Inspect the vehicle for other possible sources of A/C compressor noise or performance concerns. Refer to Corporate Bulletin Number 01-01-38-013 for more information.
4.) After all other possible sources of A/C compressor noise or performance concerns have been eliminated, only then should the A/C compressor be replaced.
5.) Remove the A/C compressor. Refer to the A/C Compressor Replacement procedure in the HVAC section of SI.
6.) Inspect the transmission cooler lines for damage due to contact from the serpentine belt. Replace the transmission cooler lines if necessary.
7.) Install an inline A/C system filter. Refer to Corporate Bulletin Number 01-01-38-006C for more information about A/C system flushing and filter installation procedures. An A/C system flush is not to be done unless prior authorization is given by the GM Area Service Manager (in Canada, the District Service Manager).
8.) Install an A/C Suction Screen. Refer to Corporate Bulletin Number 01-01-39-003A for more information about A/C suction screen repair recommendations and procedures.
9.) Install a new A/C compressor. Refer to the Compressor Replacement procedure in the HVAC section of SI.
10.) Install a new orifice tube for the front A/C system. Refer to the Expansion (Orifice) Tube Replacement procedure in SI.
* If the vehicle is a 2003 model yearChevroletExpressor GMC Savana van, the vehicle may require a new accumulator. Refer to Corporate Bulletin Number 03-01-38-016 for more information. This bulletin refers to an updated design accumulator that may improve the performance of the A/C system.
Install a new serpentine belt tensioner and serpentine belt if they have been damaged due to A/C system slugging or an A/C compressor seizure. The serpentine belt tensioner may have broken stop tabs and/or a missing front cap.
Verify proper operation of the A/C system.
Parts Information
Refer to the GMSPO parts catalog for the latest service replacement compressor part numbers.
Part Number
Description
Qty
89016656 (*A/C Delco Part# 15-10413)
Universal In-Line A/C Filter
1
Parts are currently available from GMSPO.
*This filter may also be purchased through your local A/C Delco distributor.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
D4440
Compressor Assembly - Replace
Use published labor operation time
I am from GM Customer Service. Although I cannot diagnose your vehicle over the internet, your A/C possibly may need to be recharged. If you feel that your temperature is not as cold as it usually is, then I would recommend taking it to the dealership to have it looked at. Thank you,
Mariah GM Customer Service
And you never just refill your A/C... The refrigerant isn't supposed to leave, so if it needs refilled you have a leak. That would need to be addressed also.
For awhile it was going on then off and back on like it had a mind of it's own.
NikT
Thanks for your reply.
Yes, I do understand refrigeration principles, but I am not an expert and I have the help of a ASE certified mechanic. He has the gauges and tools, and is the person who diagnosed the leaky shaft seal of the AC compressor. He travels a lot and until he returns, I thought I could get a head start by researching available, suitable replacement AC compressors.
NikT
Assuming you are planning to keep the car a couple years, I personally would get the best quality I could get. You're saving on the significant labor cost. The risk/stakes are high if a compressor sends metal shavings into the refrigerant....it would mean a complete purge, replacement of parts, and rebuild. You may not have access to your friend in future years, so do it right, and do it once.
Sounds like good advice to me. I'll follow through.
Thanks again,
NikT
