Ford Explorer Electrical Problems
I have a 98 Ford Explorer that I just bought and it is driving me nuts because it is showing the signs of a bad alternator but the alternator seems good.
I can start the car, (sometimes) take the positive cable off the battery and the car stays running. This used to be a test to see if the alternator was good, is it still? This morning the car started fine then as I was driving on the highway the electrical gauge dropped down all the way. I got to work and left the car running. I checked the positive cable and the wires going to that and nothing. I got back in the car and turned on the AC and the electrical gauge went up to normal. Does this sound like a short of some type? Any help would be great. Oh, I also changed the battery and the fusable link and that has not solved it. Thanks Chris
Thanks a lot,
John.
Rick
Here is something I found in a quick search:
Honda Oil Change Reset
grant
MODERATOR /ADMINISTRATOR
Review your vehicle
you have to go into the dashboard computer.
>system reset first
>system setup second
>says new oil?
>hold reset when you see it
>takes a few trys to get it but it does work.
Dont disconnect the battery it messes with the computer!
Gregstarola
They rewired the alarm system 2 days ago thinking that may be the problem, but it has cut out twice since.
Is there a relay for this or do I need to purchase another sensor?
Thank in advance.
Rick
last I recall the windows were not working for the passengers only the master switch. In addition, I bought a replacement mirror (aftermarket), and installed and have it installed by a street Kat! Simple, he had the tools. But upon hooking it up, the directionals are not fucntioning. Only up and down.
Help!!!! :mad:
