I suspect a relay module under the dash maybe? I see that the interior fuse #26 protects the Battery Saver Relay, Electronic Shift Relay, Interior Lamp Relay, Power Window Relay, and Electronic Shift Control Module. Hmmmm...
Did you solve?
Is anyone using aftermarket motors on their windows, mine have failed on my 03 EB V6 at least twice each while under warranty (expired now)?
:surprise:
Anyone have any Ideas? thanks
96 Explorer with pwr only operate with ignition on engine off
sethar@live.com thanks
work. I tried replacing the Accy delay relay with no sucess any suggestions thanks
When I bought the car used, the remote would open but not lock the doors. The alarm system thinks it is locked because you could arm it just by pressing the lock button. I would lock the doors by pressing the switch on either door. Recently, both switches will now only open, they will not lock, but the switch in the hatch still locks and opens the doors. The touch pad on the drives door also will open just the drivers door as it should, and all the doors when 3/4 is pressed. It cannot be used to lock the car, but will activate the alarm if you enter the code and it thinks you are locking it. I changed all 4 relays in the back, no help. All fuses are ok.
I checked for a broken wire could not find one.
honest mechanic.
I have a radio that just gets CRAPPY reception. I mean -- it seems to lose signal power. And strangely enough, this happens slowly, like over the course of four or five months. Local stations that used to come in loud and clear give me only static now. And then -- after about six months of this garbage -- the situation reverses itself. The signal slowly GROWS in strength -- until I have A-1 excellent reception from local and non-local stations.
This great reception will last for approximately six months, and then start that downward slide to static hell again. I'm telling you -- this is driving me nuts. Ford installed some sort of connection between the antenna and radio, promising that would solve the problem, but the static only got louder.
Have any of you had ANY issues with this? Can you provide any help?
The CD player on this thing works fine. It's the only part of the radio that I can rely upon with regularity.
Thank you,
Bill
Thanks....
Tom
I've been having the same problem and it has become worse over the years. It started off as the door ajar/dome light staying on but when the dealer fix my TRANSMISSION PROBLEM (1st & 3rd gears broke and fell into the trans), I believe they fixed the problem; which i think was a short in the passenger door. Recently, my car shut off on me 3 times! First i replaced the battery (it was time). the second time i was on the eway, the car started riding kind of ruff and then it just shut off. I had to cost to the bottom of the exit ramp. I replaced the alternator. Just 2 days ago, someone jumped infront of me to where I had to hit my break, just hard enough from my purse to fall on the floor. When I slowed down to start at the light the car shut off. Thank goodness it started back up, but I really need to get this fixed. Not to mention the locks flicking back and forth sometimes! When I was cleaning the snow off my windows the locks started flickering and locked me out with the car running! How much did it cost to reprogram the computer and replace the throttle?
I hope this helps, and I hope you find some broken wires in your door jamb because it's a very easy fix.
