Isuzu Rodeo Transmission Questions
New member, have 2002 Rodeo, V6, 2-WD, leaking transmission fluid from Servo.....I'm taking to dealer this weekend for their people to fix. Warranty is 10 year, 120K. Only have 49.5K. Is this an expensive repair and or should this be covered by warranty. Any comments are greatly appreciated. Thanks.....yankee6
why would yuo buy a ute in auto. manuals cant have this and many other problems. matt
I like 'em but manuals are a dying breed here.
I wanted to know when is the transmission maintenance sue. The manual is not clear on this. It only suggest when to check the fluid not when it should be changed. I have asked the dealer they said every 30K. I use to have a 2000 Amigo wich has the same engine and that had a sealed transmission and had to be changed at 120,000 miles. The Rodeo I have now does not have a sealed transmission. Im also about to hit 42K.
The previous owner left the tranny fluid in there too long. I just changed the fluid because I know it was burnt and low on fluid. I don't know how long they ran it on that fluid, but the filter was nasty black.
I didn't find any unusual pieces of metal in the pan, which I expected. The oil was still red, just dark blackish red and smelled burnt but not metallic looking. There was very little sludge in the bottom of the pan.
Any ideas??!!
Cindi
Good luck!
Any ideas of what the problems is from previous experience?
Anyway, once the repair shop relaced the transmission, it seemed to be okay. Of course my bank account is $4k lighter. So much for the 10 year warranty.
Also when I put it in drive I can't move. Alls my car does is rev the engine up and then it jumps and then I can move again. Until I come to a complete stop and then we do it all over again. It is almost like the feeling of hitting a patch of ice. U go skating and revving the engine up only u are not moving. Now it is doing the same thing in reverse too. So what is going on here and what do I need to do.
The orginal problem is that it got stuck in second gear. Meaning that the stick is in neutral and when I let the clutch out it goes and I cannot shift into any other gears other than 5th and reverse but when I do this I cannot move.
So all of my bellhousing bolts are off and the transmission is loose but will not come off. I tried raising it and lowering in different positions but no luck. Also triple checked for any missed bolts. My guess is that it is still connected to the engine via 2nd gear. The only thing I can think to do at this point is mount the slave cylinder and have sombody push on the clutch. While I pull it out until it unlocks then remove the slave.
Any suggestions?
2003 warranty changed to 7/70.
I just got my rodeo three mths ago and since u cant the trans fluid should i get it flush or what could be the problem?
Can anyone give light to my situation.
have a 200 rodeo LS 4x4 :confuse:
Found this in addition on one of the other discussion groups
just make sure the truck has warmed to normal operating temps & you will be perfect. Not screaming hot, not just warmed. Keep in mind that Isuzu states you must be idling in neutral, not park, when checking ATF level. Some AT's dont pump ATF in park, but they do in neutral. Not sure if this is true for the 4L30E, but it's easy enough to do anyway!
G/luck
Meaning what? Meaning that even when restarting the engine you must press the accelerator other than that it goes off.Befor it goes off it jerks.
When you stop in traffic
jam and you release the accelerator and press the brake it goes off systematically.
I have parked the car till I hear from you because I don’t know what to do and I do not want the mechanics to mess wit it.
My truck is IZUZU Rodeo 2000. The vehicle Body is SPORT UTILITY.
Me if I had to tow the car I would Have. I also would have rented a car. A couple of hundred in car rental is way cheaper than $4,000.00 also you just voided any warranty on the isuzu..
It would have been way cheaper than the $4,000.00 you claim; you had a "new" transmission installed; not a rebuild???
Today, while driving city streets at 45mph, the trans light started flashing and the car was rough shifting. It continued for 10 minutes (i reached home). After 10 minutes with the engine off and after a restart, the problem was gone and the light stopped flashing. SHOULD I BE CONCERNED???
ALSO, sometimes after putting the suv into park, it slips out of gear and starts to roll. I then have to replace it to drive and back to park then it stays in park.
Please help!
I would have it checked out - immediately.
SUVs and Smart Shopper
Eric
The shop that replaced the tranny checked everything, the wiring, replacing the PCM, range sensor and there are no error codes.
The strange thing is that when I bought the Wizard second hand a year ago the D light never came up on the dashboard, but the tranny was switching normally. Two weeks ago it started slipping between 2nd and 3rd gear, which ulitmately resulted in a burnt gearbox, without any warning. It now apppears that the cooler was clogged. In the current situation the AT temp warning is working but the D light still doesn't light up.
So what could be the problem?
Thanks for reading.
When I drove it the tranny seemed to shift just fine. The trouble is the disagreement between the dash indicator (which seems to agree with the tranny itself) and the gear shift which, as it is, is preventing me from putting the car in reverse or park. Any suggestions?
One thing that sometime happens is the tranny will upshift and downshift really hard instead of the normal smooth transition between gears. Sometimes you can kind of clear this up by cycling the shifter completely through the range of gears (while sitting still with the brake on) a number of times..this might clean the contacts at least temporarily.
Pictures and description of mode switch http://isuzufaq.ibctech.ca/range.pdf
earlier discussions http://forum.planetisuzoo.com/viewtopic.php?t=1707
