Unfortunately, you are right.
If your dealer has a solution I hope that they pass it along to Hyundai.
I have been unable to get a response from Hyundai that acknowleges a suspension problem, although as I have previously posted, mine has gone away.
I'm sure that those who still have the problem would like to know the name of the Hyundai rep. who says that Hyundai acknowledges a problem and are working on a fix.
He checked the torque on the appropriate bolts and nuts and all were on spec.
My Azera Limited clunker is as it was before; UNSATISFACTORY
Have you rotated the tires?
Hyundai claims that there were no manufacturing or parts revisions made which would affect the suspension. Maybe they are not telling the truth.
There is an email address and start sending them emails.
Don
Riiiight. That's what they told me. Didn't solve the problem though.
Every nut/bolt took an additional 1/4 turn or more.
The bushings were off center, backed off, re centered, re tightened.
The clunk has moved on and no longer resides within our Azera.
All of this goes back to 'factory assembly' and application of assembly tools.
My car is in shop today for steering wheel replacement due to delamination.
I just called my service advisor and informed him of you discovery. I asked him to have tech. check these areas.
If I get any response from him pertaining to this issue I will post findings.
Did you check the left side at all? Is it possible that the rear suspension is also less than perfect? Is your Azzy totally quiet over the washboard type of surface?
Some of us who are not technically adept at doing this kind of adjustment will have to bring your report to our service managers. Thanks for your input.
Don
Just picked up my car from dealer after steering wheel replacement project. To my dismay, the new wheel came with the remote switches installed. I had changed my audio switch to the 07 version to get additional features. They had not noticed that the switches were different. Needless to say, they didn't want to take unit apart to change the switch to the 07 version. I borrowed some tools from the tech. and changed it myself on their lot.
They checked the suspension and could find no loose bolts or misaligned bushings. He also checked computer to see if there were any notices or TSB's about the "clunk" issue. There were none. The Service Manager claims that no other owners have complained about this "clunk".
Only the right front so far, the left side is quieter than a church mouse and the right side has followed suit. I will work my way around, right rear is next.
Dealer/service responses are typical. My dealer/service just talked it away because it did not pose a SAFETY concern.
For those of you who rotate your own tires. Pick up some anti-seize lubricant and put a little dab on each wheel lug before replacing the wheel and re-torquing. I use a q-tip to apply and wipe around the thread. This improves the torque application as dry threads tend to bind and may not actually be at the desired torque level. You only need a little, don't over do it.
Grayfox
The service men are looking at the paint stripe placed on the nut and stud at the factory. This does not mean the torque is correct. If the paint is still inline (straight) it means the nut hasn't moved (turned) since leaving the factory. So the techs think everything is fine.
If the factory torques to the wrong level the paint stripe is put on anyhow. Obviously 'inspectors' (quality control) cannot test torque every bolt (time consuming).
The amount of thread showing above the nut should be nearly identical on both sides. Same bolt, same nut, torqued to same level. If one side has more thread showing then the other it becomes questionable. IE: one side is 1/16" or more longer than the other side (measuring from the top of the nut to the top of the bolt) the short side is of concern.
Along with the paint stripe the nut or bolt may have 'thread lock' which in the best of cases would not budge when torqued with a proper wrench at the proper setting after the thread lock has had time to cure. To verfy proper torque one would have to back off the nut about two turns and then tighten to proper torque level (with a torque wrench). If the paint stripe lines up the factory torque was correct. If it does not line up the torque was incorrect.
So, if you lean on the wall it may move. Until it does we have to figure out how to present this to the service guys/gals without them thinking that we are trying to tell them how to do their jobs after they spent many, many hours in school to acquire the diplomas and technical knowledge they have. We aren't mechanics so how can we expect them to think we know what we're talking about.
One quick "off the subject" question for you. I live in Texas and the weather hear has pretty cold (certainly not as cold as Minnesota or Wisconsin) and in the morning when I start my Azera it revs up over 2,000 rpms. Given that the engine is cold and most of the oil is in the pan, it causes me concern. I have never had a car that revs up that high. What do you guys think and can the dealership tone it down?
JMJLK
Car does rev up to 2000 when started but comes quickly done after a little while.
I'm having NO problems whatsoever with the car. As a matter of fact, I'm in LOVE with it! For myself the heated seats are a blessing!
I really wouldn't worry about it.
The oil pressure is restored as soon as the starter turns over the engine. As was previously posted, there is enough oil residue to lubricate prior to the pressure restoration. The computer monitors the rpm's. I take it that the rpm's reduce as the engine warms up. If they do not, have your dealer perform a computer check.
Tell me more about the steering wheel control you got for 42, dollars I'm assuming, can you give me a link to purchase.
Did you disconnect the battery or was it simply no worries about removing the air bag. Did you disconnect the air bag after getting it loose? Unplug connector and reconnect?
The new switch just plugs into the exisiting wiring, right?
