Visitor Agreement.
I can't quite figure it out. My garage is about 83 degrees.
We need tool coolers in West Palm Beach.
Bye now, back to the pool.
Now you know how to hurt a guy.
FEMA shows up in Miami and pays claims for snow removal.
We don't worry about hurricanes. We can always live in our Azera.
Yes, since the Azera has a top speed of around 150 mph, just keep it pointed into the wind and it'll manage a Cat-5...
I am supposed to meet a Hyundai rep at Dean Team on the 26th but I dont expect much in the way of help.
Do you have any idea of what Suntrup may have done when they had your car? It's encouraging to know that by doing SOMETHING, the problem is alleviated. If I dont get any satisfaction from the rep, maybe I'll call/visit Suntrup.
BTW, where do you go to run your speed checks? Seems like around here, if I did that, the local gendarmes would find a short rope and a tall tree!
Is there a torque specification for these nuts, or is is a trial and error job?
Tighten until secure, do not apply the force of Samson. The ball joint and stut will work just fine, the added tightening has no impact on function.
In reviewing past posts,owners gave experienced different results with the re centering and tightening process. Some have reported no change, with continued "clunk" while others, like you and Jim have seen positive results. That was the reason for me asking about the torque. Perhaps you have tightened the nuts more than others. My question is simply, if the struts were not so loose as to be moving and torque does not matter, what would the tightening change?
We, 2006 Azera owners, bought a 'NEW' model that has yet to be debugged and for those of us who can, will make effort to improve the ride while the 'dealers' are trying to get on board. If turning a wrench saves us several trips and much aggrevation with Hyundai service reps then you betcha we're going turn that wrench.
I'm just curious to see if there is a sort of "cut-off" as to when the problem(s) cease to occur, by build date...
So far after 5k miles................. no "klunk".
My cars, build if I remember correctly, is Oct 2005. Took delivery in June 2006.
I have 23,000KM and NO clunk!
Dealer states same thing in all Sonatas and due to stiff suspension.
Otherwise car has run flawlessly.
If one jacks up the right side, removes the right front wheel, places a safety stand safely under the car to start.
Then take your flashlight and look behind the strut at the rubber bushing that holds the body to the frame. If you see a pointed bolt thread sticking out from under the nut you're in the right place. If you see a space between the top of the rubber bushing and the frame you have found the 'CLUNK'. There should be no space between the rubber bushings and the frame.
There are other body frame mounting points and if you look you will see no space and there is no space for the same mounting position on the left side.
Yes, my 'CLUNK' went away after tightening the strut bolts.
The reason I know about this new find is, a buddy of mine bought a used Azera Limited Premium and discovered the 'CLUNK'. He called me and we went to work. The right strut took 1/4 to 1/2 turns and then I noticed the space on the body mount. The nut is tight, takes a big breaker bar to turn. We took it off, the thread on the bolt may be a little short or the bushing may be a little thin. We added two washers and put it back together. The space and 'CLUNK' was gone. We inspected the other body mounts, no problems.
If the thread is short the nut reaches torque before it compresses the rubber bushing. The same think happens if the bushing is a little thin.
Good luck, if you take it to the dealer and you can get them to put it on a hoist and look, it's really visible to the naked eye, maybe they will give a it a turn or add the washers if you ask.
Mark, I wonder if you can send me copies of the high resolution pictures you took of the front suspension? I have an appointment with the Hyundai Rep on Monday and they would be very useful along with copies of several reports from other Azera owners who have found faults and corrected by tightening nuts/bolts. If you can, I will post my email address in the profile of this service. I can do that, can't I Pat?
If the stand is under the body at the normal jacking point, you might see it whereas if the stand is under one side or the other of the front suspension, the space could be hidden and look OK. I'm not sure where you put your stand.
Maybe Mark could post the pics on his CarSpace page so everyone could see them.
I hope he sees your post. He hasn't logged in since the day he posted that.
Anyway, hope it works out on Monday - let us know either way.
Let me know if you need to know more.
My two reasons for asking was that on Monday, I will meet the Hyundai Rep at a local dealer. I needed to know precisely how the car was supported in order to see the space you described.
Since I am pessimistic that they will spend much time investigating my suspension noise after this third visit, I probably will be doing it myself here at home. I am willing to solve the mystery on my car no matter how long it takes me. I work cheap!
I've gone through my car and tightened everything I can think of relating to the front suspension. I even found the body mounting bolt that Jim101 mentioned in post 335 and inspected it. The threads extend well up into the rubber part of the bushing, so there is no problem with the nut tightening before the bushing is properly compressed. My car seemed to be doing pretty well until recently. I've noticed that when the weather was cool, the "clunk" was non-existent or very faint. Today here in St. Petersburg, FL it was pretty warm and the "clunk" was very pronounced. Maybe it's my imagination, but I swear I can also feel it in the floor of the car when I hear the "clunk". The severity of my "clunk" seems to be directly related to the outside temperature.
