Visitor Agreement.
I plan on keeping my Azzy for well over 100,000 miles and will at some point have to replace the shocks. So, why not get a free replacement at 30,000 and put off or eliminate the replacement cost?
The dealership is not obligated to replace the struts if nothing is wrong with your current ones.
I would not take a chance in changing parts that are designed to last for a long period of time, and are operating properly.
I believe that the TSB remains in effect should your Azera develop the problem at a later date.
front and rear shocks. They are the same spec's
I wonder what was done to improve the handling ????
Did they show the same part numbers for struts used in 07 and 08?
Initial Hyundai information indicated "new" and improved suspension and steering systems.
Did they tell a fib?
Interesting find.I did not realize that info is on the site. This really adds confusion to the shock issue, perhaps site info is in error.You do not change the part no. unless you change the part....040 and 041.
note info in post no 870
Replying to: scbob (Dec 24, 2007 11:56 am)
Following up on my buying experience and strut issue: I bought 07 azera and got great price ( about $4000) off MRSP plus 0% interest. I spoke with service manager and he was very aware of TSB on suspension but stated he only had a few customers requesting new struts per TSB. I asked about strut part numbers and he stated:9/1/05-12/26/05-54611 3L040
12/26/05-10/20/07-54611 3L041
10/20/07-now -54611 3L641
So far I am very please with car and especially value. Hopefully reliability will be good. Will watch for suspension problems. Happy New Year.
This seems to indicate that 3 different shocks are involved and my guess is that 10-20-07 [54611 3L641 is the revalved shock on the 2008s.
below are 2 links for 06 and 08 shock specs
The info did not show part numbers. Maybe they changed the valving and the rest is the same.
Something clunking from the right side only makes sense now.
There is a TSB for the timing chain tensioner in some models.
This has nothing to do with the suspension, and only caused a 1 to 3 second sound upon start of engine.
I posted recently #869. This may be the same issue. Mine is an 07 and it sounds like there is no oil in the engine at startup. Could you please post the number of that TSB? I will follow up with service with that. Thank you.
RE. build date, open driver door, look lower right at tag just below the lower rear door hinge, tag includes weight info and top left is build date.
If your build date is Dec5-05 to Feb26-07 your Azera has all 4 shocks which exhibit poor low velocity damping. This causes the "clunk" and porpoising.
The first Azera off the assembly line had shock 040 and on Dec5-05 they began installing a revalved version of 040 and called it 041. 041 has a better freeway ride but responds poorly on a bumpy surface at low speed because of poor low velocity damping. On Feb26-07, Hyundai began installing the old, original shock 040, that's why the TSB build date window ends on Feb26-07. They began corrective action on Feb26-07, but did not issue theTSB until Sept-07.
The TSB only addresses replacing the front shocks with the older version 040. 040 is the replacement shock because it has better low velocity damping than 041. No mention is made of the rear shocks because most Azera owner do not perceive the noise coming also from the rear shocks. Check the threads.
For images of theTSB go to post #682 of this thread, there are 2 clickable links
let us know your build date
I live in Indianapolis, and have had an issue with the uneven rolling of this car since I bought it. The Service Manager claims that Hyundai is coming out with some type of technical fix that involved the Transaxle. My Azera seems to have a slight rumble and a halting feeling when the car is rolling. This is most noticible when the car is going around 40. When you let off the gas and just roll, the Lt. front end seems to have a wavy rumble and the car doesn't roll smoothly. It acts like something is catching as the car rolls. You can feel it in the seats and watch the radar detector bounce as it happens... no fix as of yet though. Mine is a Dec. '06 build the day the factory switched over to the new struts.
Good luck!
If you have metallic bits floating around in your oil, your oil filter, which is designed to remove particles over 10 microns in size, is not working.
Feeeeelings.... woah, woah, woah, feeeeelings... :shades:
Several days later, I rigged up an analog volt meter (VOM) to test the electrical circuit using the cigarette lighter (aux. power receptacle). That night I went for a test drive with the VOM plugged in to the cigarette lighter. I tested the vehicle in all gears, in manual and automatic modes, through the RPM range where the light dimming occurrs, 1050 to 1150. With the RPM decreasing through this range there is a 1.1 volt drop for about one second. Above and below this range everything is normal.
With this information, I took the car back in for service. I explained to the service rep. that there was a 1.1 volt drop in electrical system voltage on decreasing RPM in the 1050 to 1150 range, which causes the headlights and interior lights to dim. Four days later (way to long) I got the car back and everything seems to be working well. The lights are no longer dimming and no voltage drop. Here's what the repair invoice (warranty) said:
"R&R battery - R&R cable clean paint from body and cable end repairs, reinstall cable, R&R Alternator to battery cable & remove power cable from under hood junction box and clean, reset battery, starting systems - all ok"
BTW, I did have an 08 Santa Fe loaner from the dealer while my car was in the shop. Hyundai has really improved the ride of the Santa Fe but I'll keep my Azera. I love the power, comfort and style. The Azera compares favorably to former cars owned, Lexus, Cadillac and Chrysler.
I had a similar problem and dealership replaced battery, at no charge, and problem is now gone.
Since it was mentioned above how this forum has gotten off track of the front end issues, I feel that other consumer feedback and concerns should be mentioned and discussed. I found this discussion by typing into Google "Azera quality problems" when I was doing the research prior to purchase. I was very hesitant to give up my 15 month old Acura RSX Type S (my 5th consecutive Honda) for this brand, but everyone seems to speak so highly of the car and Hyundai's overall quality. What drew me to the brand initially was when the latest Sonata generation was released in 2005. The value was unmatched. The Azera takes that Value to the next level and adds a whole lot of sophistication and most importantly - class. I hope this second Azera confirms that I made a good decision - time will tell!
I was not aware that it was necessary to remove the engine to replace the timing belt tensioner.
They followed the TSB about the timing chain tensioner and performed the specified 17-hour repair, which involved removing the engine (!) I can't hear much of a difference in the noise; perhaps it is a bit less metallic and "clanky", but I'm not so sure.
I also had an annoying package-shelf rattle which they said they addressed (no improvement). Ditto for a less noticable front dash rattle (in the center speaker, I think). AND, yesterday the surround-sound Ultimate package stereo was completed distorted and static-y when playing XM above volume level 16 for quite a few minutes, then the problem mysteriously vanished. So, although like you I love the car, I'm getting worried about quality of build and service.
I have just abandoned the UAW after a lifetime of being a total American car guy due to my having been completely burned by two nightmarishly bad Cadillac SRX's (one V8 and one V6) and an '05 Pontiac Grand Prix GXP on which the water pump died at 15,000 miles). I sure hope that I'm not headed down the same road with my new "Seoul Buick."
Regards
I'm thinking that it's piston slap because it sounds very similar to a Chevy Tahoe I had which was notorious for that problem. The Tahoe quieted down in about the same amount of time as the Azera takes, and was also worse on cold/overnight startups.
My Azera has only 13K miles, I love the car, it's been perfect to this point, and this little problem is not even worth going to the dealer for - since it would mean an overnight stay. I, like you though, hope this is not just the beginning of bigger problems.
2) You sound as if you have substantial technical understanding of the problem (which I do not). Is this "clatter" something which is going to significantly shorten the life of the engine?
Piston slap should not significantly shorten the life of the engine, hence, I don't worry about it too much. It's simply a bit annoying, guess I'll just turn on the stereo so I can't hear it.
Would you agree with that guess?
Thanks again
In my case, the noise is definitely worse the colder it gets, which makes me think tha the "piston slap" hypothesis is the likely culprit. Am I right (asked the English teacher/science moron" in thinking that metal shrinks from cold and expands from heat? If so, that would explain both the worst-engine-noise-on-coldest-mornings problem AND the intermittent metal-on-metal rattle from beneath the rear package shelf. On cold days you can hear it with every slam of the rear door. Last night, however (not very cold), I slammed away and didn't hear it at all.
The car I test drove was black with the new ten? spoke rims. I found that the car cast a very European look that would normally cost thousands more.
"I spoke with service manager and he was very aware of TSB on suspension
9/1/05-12/26/05- 54611 3L040
12/26/05-10/20/07- 54611 3L041 [These are the ones that are replaced per the TSB.]
10/20/07-now - 54611 3L641"
Make the last or current shock number 54611 3L640
This is the correct part number for MY 2008.
I wonder what the real differences are besides price, if any . . :confuse:
Will the newer 54611 3L640 shocks fit the older struts?
Mahout?
Retail is $185.29 compared to $179.94 for the earlier shocks.
HTHs
Why not get your dealer to replace your shocks with the new MY 2008 part numbers:
54611-3L640
If they truly have tried everything else, why not :confuse:
It is worth a shot isn't it? Good luck.
HTHs
However the TSB states that only vehicles made between 12-5-05 to 2-26-07 are covered. Not sure if that has been changed to address a wider time range though.
Are you sure that the 041 units were used through 10-07. If so my vehicle might be covered. It was made in 5-07.
Steve
Good show old boy! Excellent.
So your dealer used a complete strut assembly from a new 2008 (?) and your problems
were solved? Or was the complete strut assembly they pirated from a new 2007?
Were both sides done?
Are you able to notice any differences besides the "klunking" noise disappearing?
I sure did when the dealer changed out my original 041s for the TSB replacement 040s.
Sounds to me like I will be traveling the extra 25-30 miles to go
down to old Escondido from Murrieta to have mine worked on.
Your dealer sounds like they are really hep to solving any problems we may have.
Can you believe that the local dealer here does not have any nor have
they had any 2008 Azeras in stock yet, and it's late March already?
Please be sure to let us all know how your strut brace works out.
Mahout never used one that I know of, and I don't think he finds that to be necessary. :confuse:
