farout
There is a acknowledged problem by Chrysler. They have developed a reFlash they are doing now, which may fix the problem. Replacing the TC is according to my Service Manager may or may not be an solution.
I doubt driving 1400 miles on you vehicle will show them anything. Heck that's going to take maybe a month to put on that many miles. I would not do it.
farout
You do not say how many miles you have on the PAC, and when did you get it? Have you had ALL work done at a Chrysler shop? Have you kept it up by the B schedule in the owners manual? These are Major issues that can hurt or help in a huge way.
farout
In Ohio you are entitled to recoup every dime spent on the car, including any accessories you may have added (i.e., trailer hitch), finance charges on any loan, registration fees... and best of all any attorney fees.
A friend of mine went through the process a few years ago. I don't think Chrysler can beat this settlement. However for the sake of fairness and avoiding attorney's ... which is nearly always a good idea... I would consider a buyback. But don't wait too long, most Lemon Laws have constraints on both time and mileage parameters to work with.
Best luck to everyone!
However the better part of wisdon says it's better to be better prepared to meet those you want to win over to your point of view. Threatening and shounding like a lion when your a kitten is fool hearty. The service managers and those even in the uper management are use to big noise makers and those who vent angry nasty words. This goes in the drag your feet file. Lemon Law threats are usually settled by an arbratration board, and rarely does the consumer come out 100% satisfied. Ohio may well be different.
I have used kindness, praise for the Service Manager, and the dealership when talking with the people that has authority to move my request to a higher person up the ladder. I have seem that for me this has done more than any Lemon Law or Lawer ever could.
I guess whatever works best is what a person should try. But one shot is generally all we get.
farout
please drive slowly to 20 Mph and then brake all the way to complete stop and tell me if your transmission downshift rough, please any of you that can send me the feed back .
thanks.
I notice that at 11 F the rumble or whatever you all it, is louder. But, the ride is smooth, and there is plenty of power.
The service manager says the lock up clutch in the conveter is what Star is saying, and there is a new reflash out in two weeks. The new T&C with the AWD 4.L 6 speed auto is doing the same to some of the 08 as well. So help will arrive, it may be a while.
It's just time to document the time and places it happens and be ready for the fix, and make the dealer aware of what's going on.
farout
Regards.
What update did the dealer use to flash your trans control computer? I hear there are a few versions out there. Whatever one they used on mine did the trick. I will try to get the version from my dealer and post it, if I can.
I still really enjoy driving my PAC, and I hope they can make it right like it should be. Or they will see me yet again. I think of myself as extremely patient as long as I am treated with the same respect. So far, so good. I won't be taking my PAC to the other Dodge dealer in town because these guys do really seem to care. I will keep everyone posted.
Regards.
I am going to go through the arbitration process again now that the selling dealer has literally thrown parts at the front end (sway bar bushings, right strut, steering rack) only to make the clunk worse. We shall see what happens.
I bet you won't find a single, reputable person using "disks" in a fuel tank. This sounds like a nasty gimmick that at best does nothing....at worse, does too much....wrong.
Have your buddy read-up on how octane is tested and calculated, then see if he can explain, in detail, how these things work.
I am a chemical engineer and I doubt there is any science behind this.
Good evening, there are two items that I would like to address to help with this concern. Chrysler has a few service bulletins related to these concerns. Most deal with flashing the controller as you mentioned having had performed already. One of them in paticular being service bulletin #21-016-07 requires replacing the torque converter assembly and flashing the controller. It deals with the actual shudder concern. The new torque converter has a revised friction material. With this info in hand take a moment longer and listen to the next info. I have personally dealt with this issue regularly being a Chrysler technician. It was requested to me by the Chrysler instructors to add a half a bottle of rear end additive which is a friction modifier. They recommend doing this first before replacing the torque converter. They have had great results with this so far and that is exactly what I have been doing. So my first recommendation is the addition of half a bottle of friction modifier and make sure they perform a quick learn on the trans after it has been driven a few miles which will allow the modifier to mix evenly. This isnt documented through chrysler anywhere so no dealer will have this info. If they do not wish to perform this simple process then they can then remove the trans and replace the torque converter per the service bulletin. The additive is where I would go next.
Q.. What about the warranty? and the hard down shift it even pull the car foward if you don't have the brake pressed firmly and I beleive is the reason of the broken engine mounts. my car has 7000 miles today
A... I work at the dealer and have performed that repair and no issue related to warranty. If the dealer has questions regarding the additive, they can contact the chrysler hot line called "Star" and they can speak to the factory reps and get the same info. This is the starting point I would go with and then recheck the other issues after wards. Otherwise they will need to remove the trans and replace the torque converter. Make sure to bring it to their attention and even give the service bulletin number if need be. An informed customer can scare the hell out of them.
A.......Its the starting point. You may have 2 seperate issues. That service bulletin covers a few different complaints such as a bump sensation with torque concoverter engagement at different times. We need to address the most obvious issue that I have a solution for, then recheck it to see what is still present if anything else.
Q.....this kind of shudder does any harm to the internals of the transmission?
what is really happening when a car shudder, does the engine moves? or vibrates? because I have that feeling that the engine is shaking inside it feels like vibration.
A.....The shudder does no actual damage to the trans or vehicle.
What is Torque Converter Shudder?
Torque Converter Shudder occurs when the clutch inside the converter on an automatic transmission is being applied and the transition from slipping to locked up does not occur smoothly. The clutch locks up for a brief moment and then slips, or breaks away, because it could not hold enough torque to complete the lock up. The ability of the clutch to hold torque is the converter's torque capacity, which is a function of the oil pressure applied to the torque converter clutch combined with the friction characteristics of the oil and friction surfaces. This process of locking up and breaking away repeats itself rapidly, typically 30-50 times per second, until the engine RPMs are reduced and the clutch finally locks up. Torque Converter shudder can be both felt and heard as these rapid vibrations are transmitted to the drive line.
I think this guy has been much more on the point that my dealer, lets try this with our cars , please keep posted.
Here is what is happening. at 1200 rpm tp 2000 rpm in what ever gear the transmission is in, while just gently giving it some gas if iam at thr slightest incline it has this lugging or whatever. (I am not sure what a shudder is.) There is more noise from the engine and a vibration shich the passenger feels as well. At 52 mph in 6th gear is starts and only when going up in an incline just enough to tell.
I did some trying some things on my own. Wjen this lugging starts I put it into auto stick, and down shifted and it goes away right that instant, no matter what gear it is when it happens. Which leads me to believe it may be the shifting points. Is that reasonable to think this?
My dealer is LLoyd Belt in Eldon, Missouri. I am very pleased with the work and the interest the service staff takes in this, and especially the Service manager Ron. So it in not an issue that we don't get along or anyone feels I do not appreciate what they have done or are doing. They have had three PC's with this problem. They have not sold but only a few 2007 PAC's. So any suggestions or your opinion is appreciated.
I do think the PAC is a great vehicle, and fit and finish and materials are what is needed in the rest of Chryslers brands to keep it floating and get ahead. What a sad think thet DCX did not advertize the PAC, as I think it could have made a better production run.
The 4.L engine with the 6speed automatic is a fast quick combination. The fuel MPG is 19 if outside temp is below 28 F and when above 40 it jumps to 22 mpg. We have gotten as high as 25.3 mpg and that sure beats the stuffings out of the cheap Compass we bought in 4/07, which we traded in on the pAC, best move we ever made! The CVT and the 2.4 L is NOT a good combination and the engine is severely lacking.
The AWD is flawless and takes our hill as good as any of the 3 Jeep Liberty's we have owned. After the PAC we see we really never needed a Jeep. We bought a 05 Liberty CRD which DCX bought back after 25 times in the shop in 16 months, and the dealer flat called the Zone Rep nad said they did not want to see it anylonger as they gave up. That's how we got the Compass in the buy back.
One thing I like the looks of is the Duel exhaust, even if they split off the same pipe, it looks cool, shame they only had it on the 07, any idea why?
Thanks for you help in advance.
farout
One other question, and this one is a good one! Both my wife and I own 07 PACs. They were manufactured less than 4 months apart from each other and are nearly identical - both Touring Editions with the 4.0 L and 6-speed auto-stick. Mine has leather and hers doesn't. But I did notice a weird difference and it may be why hers is less noisy in front than mine. Under the hood of my wife's PAC, on top of the strut towers (where the struts mount to the body of the car with 3 bolts on each side) there is a 1/4" thick cover made out of the same material as the heat shield stuck to the uderside of the hood. The tops of the struts and the 3 bolts that hold them in place are completely hidden from view by the covers. They continue down over the sheet metal about 4-5 inches and are charcoal in color. Under the hood of my PAC - no such covers! Almost identical cars except for that. Anyone else have or not have these covers? My dealership parts manager can't find them in the parts manual, and even the serial numbers don't help! He said he will have to call Chrysler to find out why hers has it and mine doesn't. Will someone check theirs and let me know if the covers are there of aren't there? Thanks in advance!
I also like very much my Spring Special edition Pac I think the engine, brakes and concept are very nice, I just want to be driven as a Normal car.
by the way they are relpacing the torque converter this comming week I hope it works.
I'll keep in touch.....
farout.
you can see wide shock absorber and in one side you see the oil duct.
Also, any thoughts on when to change spark plugs.
They rplaced the transfer case about a month ago, and when I went to pick it up, the vibration had lessened, but was still there. At this point, they've replaced the transfer case, replaced the left wheel bearings TWICE, and installed a new motor mount.
I contacted a lawyer (In VA, car has to be in for 30 days in a year's period for the same problem to classify as lemon law), and we'll see what Chrysler comes back with about a buy-back.
The motor mount is what bothers me...they said it would reduce the vibration from the transfer case, but isn't that like fixing broken glasses with duct tape? They're STILL BROKEN, just functional!
I've heard grumblings of a "silent recall" on Chrysler's part regarding the '07 Pac...anyone else heard the same?
Taxi, police, or delivery service (commercial service. <>
These are to conditions that demand the 15,000 mile service of the Transfer case and the differential. Spark plugs are listed at 102,000 miles.
So if you tow a trailer just once in a while it still is not required.
If you think that 15,000 miles under the above conditions are bad then don't consider a Jeep because they ALL require these services at every 12,000 miles on all true 4x4's. Hope this clears it up for you.
farout
It does seem like the dealer is attempting to get it fixed, so that's in your favor.
Having had a buy back in April 07, Chrysler was more than fair to us , and we were very pleased how everything was handled. We had a 05 Jeep Liberty diesel, which had been in the shop 25 times in 16 months. Chrysler called me, and asked if I would like them to refer this vehicle to a manager who just might take it to the Zone rep. Ir all started on Feb 16th and was done by April 4th 07.
Our mistake was selecting a Jeep Compass for the new vehicle. The Compass is a very cheaply made vehicle, and fuel mileage was 21 mpg and had no power and the CVT is a poor excuse for a transmission. SO on Aug. 31 07 we bought the PAC touring AWD. Very pleased but has the shuddering, and there will be a fix soon. Heck we got the Lifetime Powertrain, and the Lifetime Max care too. So I have time on my side and a daren good vehicle to boot!
Hope this helps some.
farout
I looked last night (but now I don't recall the details) and the book is REALLY confusing. It talks about x-fer case at 15k, rear diff at 22k, and front at 30k and then it is due for the transfer case AGAIN. There is an A and a B schedule as you said and we don't tow. Also the plugs are due at 75k in my book.
I will double-check.
Keep in mind it was the dealer that told me I had to do everything at 15k and also the plugs at 30k. Seems like someone is getting carried away.
I have always been good about maint on my cars, but I don't go crazy. In my Suburban I did all the fluids at 50k....15k seems insane.
I have a 100k bumper to bumper and will probably keep it for 100 to 150k. I just don't want them pushing back on any warranty issues.
BTW, the car has been great.....perfect....no issues (knock on wood).
The only thing I have noticed is that at about 40 mph, under light load, and going up a small incline it will tend to bog, or rumble a little bit. The rpms are very low when this happens and it seems to be in 6th gear which is too much gear. A little more gas causes a proper downshift.
However, under the "severe" every 15k it recomends the fluids but then there is an * indicating towing etc.... It never says when you should change when you don't tow. Under "normal" service, it never calls to replace the fluids at all.
farout
I'm from Toronto with an '07 Pac Touring that had the shuddering problem. See my posts on this thread (#25 & #27). Last April I had the torque converter replaced which reduced but did not eliminate the shuddering. Two months ago we took it in for re-alignment and the mechanic/technician noticed that the control arms needed to be replaced. Can't say I noticed much difference in the shuddering after that. However, about three weeks ago the shuddering stopped; the only thing that coincides with this was our inadvertent switch to using PetroCanada mid-grade gas. I'm not making any claims with that statement. There may have been something else done at our service appointment two months ago that caused the shuddering to eventually go away. Don't know.
Anyway, I would ask your dealer to locate the service bulletin and/or give them the TSB number (from post # 232). That way they're prepared to deal with it ahead of time, there's no dispute about the existence of the issue and they will have the parts on hand when you bring your car in. No need to wait days to get your car repaired. Best of luck. Hope it works out for you.
A missfire can be slight, or violent AND, often times they do not "pop" a code. Modern technicians have completely forgotten how to troubleshoot, they just hook-up code readers, start ruling crap out, and then start replacing parts.
If changing fuel "fixed" you problem, you either have a fluke, the problem is really not fixed, or it is in fact fuel related.....such as timing.
I have an idea.....you guys who claim to have this issue should find a good tuner in your area. Spend $50 - $100 and get the car on a dyno. The tuner can replicate the situation while on the rollers and data-log everything. Plus, they can use listening devices such as a stethoscope to look for knock and missfire condition.
Unless you are sure this is a drivetrain issue, I think the dyno might be a good option.
The tuner may even be able to correct the issue on the spot.
BTW, I have personal experience with working with tuners and have had them reprogram my ECU before to accounts for after-market modifications.
