The hose that drains the top storage compartment were left inside the fender, rather then installed thru the rocker drain hole. .....so all the water that normally ends up in the storage compartment and drains to the ground was draining into the fender and rocker wells. when they reached their max. or you hit the brakes the water would spill out under the carpet. ....Solution: pull the plug and fish the hose thru the hole or remove inside panel and insert thru hole. ..................apparently mine was not the only one with this mfg defect and others.
Early gaskets were smooth on the "A" pillar where they contacted the window. Later Chrysler changed that weatherstrip to include a ridge that kept water from entering the car. I bought the later weatherstrip at a junkyard and installed it on my 98 Sebring, stopping all leaking.
I don't know in which year the change came about.
Karl at aoksales.com
http://townhall-talk.edmunds.com/direct/view/.f0f68aa/146!vuserName=rbender
ClaireS, Host
Automotive News & Views | Coupes & Convertibles
I now have rain that pours in my car at the seal/ window drivers side corner front. when the car is parked and raining.
now sometimes my electrical panel for the speedometer goes out along with it. also adding sometimes if it rains a few days, my drivers electric window doesnt want to drop down automatically when i open and close the door.
this is such a headache and i hope if u do own the chrysler covertable, you dont continue with these problems i have as it seems to add more and more.
best of luck..... boston area
