Is This the "Day of the Diesel?"
1235713
  • blufz1blufz1 Member Posts: 2,045
    Q....Your post 164 states that my disagreement with gagrice's 148 is wrong. You say "no his (148) post is absolutely correct." He is wrong in 148 and you are wrong in 164 affirming his 148 as being "absolutely correct." What are you a professional weasel?
    Q.... The difference in rpms is only 300-500 at cruising speeds. Not 1300 rpms difference as gagrice claimed and you affirmed!
    I have been following the RPM discussion with some amusement. But I think the point is being missed about what the consequences show. So if one is interested in the real differences. Just compare the figures of like sized engines gasser/ diesel.
  • pch101pch101 Member Posts: 582
    It strikes me that you are both correct and incorrect on this point.
    On one hand, you are correct -- it's the gearing and final-drive ratio that determine engine speed at a given speed and gear.
    On the other hand, the gearing and the final drive ratios used in the design are selected based in part on the torque generated by the engines. So it is reasonable to expect a diesel to cruise at a lower engine speed than would a comparable gas engine. It's not the difference cited by Gagrice (who does have a persistent tendency to make up a fair bit of his "data" as he goes along), but there should be a modest difference.
    pch101..... That's what I am saying. The diesel cruises at 300-500 rpms less than the gasser. Not 1300 less as incorrectly stated previously.
    OK, fair enough. There may have been a bit of confusion because you said in #163 that the engine type and engine speed had nothing to do with each other, but I do see your point.
    I stated that it's the final drive ratio not the type of engine that determines engine rpms at a given mph. That's correct.
    I'm talking about your statement in your post 148 stating a camry is turning 2800 rpms vs. a diesel running side by side turning 1500 rpms.
    The difference is quite simple. When pulling a long grade, which was my premise for liking to drive the diesel Passat, the Camry or other gasser/hybrid cars would have to downshift to maintain the same speed. The 4 cylinder gas engines in the midsized cars are not well suited to heavy loads. Put 4 adults in a new Camry 4 cylinder and take a drive up a long grade on one of our Interstate highways. It is a chore for that little gasser to maintain even the 75 MPH speed limit. They do go like blazes downhill.
    Welcome to the world of diesel. Did your cell phone break? I was basing my 2800 RPM figure on the one time I rented a 2005 Camry in Victoria BC. With the 90 KMH speed limit ( 55.92 MPH) our rental Camry ran at about 2200 RPM. My off hand calculation was that it would be ABOUT 2800 RPM driving the normal Southern CA 75 MPH. With a 27% increase in speed I would expect the engine to be turning an additional 27% in RPM.
    As you have pointed out it is all a matter of gearing. I think my point was lost in the RPM argument. Diesel engines by their lower RPM average have a longevity advantage over a gas engine.
    The other thing is folks have been conditioned almost relentlessly to get rid of their cars well before 250,000 miles. If yearly salvage rates of 7% and the average age of the fleet of 7-8.5 years is true it is usually like 100-150k. My TDI is literally a baby at 86k and three years. My goal on the diesel is between 500,000 and 1.25 M miles. A new diesel engine costs less than 3,000 dollars. :) For want of longevity of an engine how much would you gasser buyers of gasser cars in 10-25 years think a car will cost vs a 3,000 diesel engine?
    On my side of the business most people are getting rid of their cars in 2-4 years.
  • larsblarsb Member Posts: 8,204
    "conditioned relentlessly?" By whom? In what way?
    I think one reason people buy new cars is because their old cars don't have new (cool) stuff in them.
    Another is that it takes a certain "type of person" to want to keep a car for 250,000+ miles. Not everyone thinks that is a worthy goal or a good thing to do.
    There is more to owning a car than have an engine that can theoretically make 250,000 miles. Cars that approach that many miles inevitably have a lot of things broken. Small plastic interior pieces that have broken. A power window motor stops working. A transmission goes out. The ABS system has a problem. There's a gouge in the rear bumper from that little pole you didn't see when backing up at the county fair. Seats rip. Carpets need replacing. Keeping all that stuff in perfect running order can sometimes be very costly.
    My point is that although you might have a diesel ( or a SAAB gasser ) engine car which hits 1 million miles, the cost of maintaining items other than the engine will be high without fail.
    That's another perfectly good reason people trade cars: If it's going to cost $1,500 to get the fuel injector or the air compressor replaced/repaired, why not just trade the car in and use the $1,500 on the down payment and get a whole new car out of the deal?
    If diesel engine cars were built with other parts and components equal to the longevity of the engine itself, well, there would be no better cars made anywhere. Too bad that's not true.
    It was true at one time. There are still many MB diesels from the 1980s running fine with all their amenities working. Our 1990 LS400 runs great. Too bad the new Lexus and Mercedes are not as well built as the old ones. It is the toys and gadgets and electronic wizardry that has degraded the longevity of our cars.
    ""conditioned relentlessly?" By whom? In what way?
    If diesel engine cars were built with other parts and components equal to the longevity of the engine itself, well, there would be no better cars made anywhere. Too bad that's not true. "
    Indeed thank you for asking the question and thank you for going on to give examples of my point. :)
    I would also agree. It is those very things we think are ("cool") (truly not that I do NOT think they are cool- some are), that drives us more toward the so called "throw away" attitude.
  • hypnosis44hypnosis44 Member Posts: 483
    At the current rate of additions and improvements in safety equipment alone any car older than six years or so will be at a significant disadvantage safety wise. At that point the average car will have about 75,000 miles on it. I would still like to be able to buy today a well made modern diesel with every safety device known to man on it.
    Again it falls into the post I made about throw away attitude. If you follow motor sports even casually, you will see that the latest and greatest safety devices known to man are there and they do periodically crash test that equipment at speeds approaching 150 mph!!! So that I am not vague, full roll cage, 5 point safety harness,helmet and fire protection, restraint devices. If you follow motor sports even more closely, do you know any one who actually uses an air bag/s!!! Why not? Do you think any of those race car drivers are remotely suicidal or crazy!!??
    The sanctioning body of many motors sports actually require you to disable the airbags on a vehicle you will be competing with.
    My post does not address the so called "throw away" attitude. It does address one of the reasons people upgrade their cars - improved safety and survivability. Your attempt to conflate the two disparate ideas fails logical processes.
    I have met and do know race drivers. Good judgement in life choices are not their strong suit. By necessity they all think they are immortal.
    In real life the 99.999% of the rest of us understand things far differently.
    For inspiration to keep your car 300,000 go to www.hondabeat see how long these people are keeping their cars! Click on high mileage club. Many of them mention they change oil and filter @ 3-5k miles. Most people don't understand the true cost of buying a new car every 2-4 years vs keeping a well maintained car for 15 years.
    May I suggest that you have missed the point: " about 150 mph" crashes and the "less than strong suit aka belief in themselves as immortal" WALK away!!?? What would that do in the so called real world where the average death dealing fatal crashes are under 45 mph? May I ask, what does that tell you, if if I am being clear about the issue I am trying to highlight?
    I would almost totally agree. Perhaps that is why folks do NOT do the math!!? :)
    Again it was like a needle in a haystack finding out the design parameter for the VW TDI engine of 25,000 hours (@ average of 50 mph). I It is probably even scarcer to find what the (hours)design parameters are for the Honda 4 banger.
    Incidently, (off topic)the goal for mine Civic gasser is 250,000 miles and above. I am doing 20,000 mile OCI's with Mobil One 0w20,5w20. I also understand that the Mobil One 0w40 gives even more excellent oil analysis numbers.
  • qbrozenqbrozen Member Posts: 33,813
    in your post 163, the post I took exception to, you never mentioned the rpms were wrong. And I never said they were right. So neither you nor I were talking about specific numbers. Hence, when you claimed him to be wrong, and didn't mention the numbers, I assumed you merely didn't understand that a diesel can run at lower rpms, period. You since clarified (or changed) your stance ... it sure took a long time to clear that up, though. Maybe if you were clearer in what exactly you thought was wrong to begin with, it would have saved us both alot of time. And if you look back, it was many posts ago I stated I didn't know what the exact numbers are ... I guess you must have missed that one. That probably also would have saved us quite a bit of time.
    Discussion has made my head hurt.
    Can we just forget about it now?
    don't worry. i'm finished. i shouldn't have even posted that last one.
    No problem guys.
    It's nice of you to change your story, but your tendency to exaggerate is pretty clear on this one.
    In #148, you claimed, "The biggest advantage you two have with the TDI is while you are cruising at 1500 RPMs the guy next to you in his Camry 4 cylinder is turning about 2800 RPM."
    According to this test of the Jetta TDi in Canadian Driver, the Jetta is turning 2,500 rpm in top gear at 120 km/h (75 mph).
    According to Car and Driver, the Camry SE's top gear is set at 26.3 mph per 1,000 rpm. At 75 mph, that equates to 2,811 rpm.
    That's a difference of 300 rpm, not 1,300 rpm. At 60 mph, the difference would be about 250 rpm. This is not even close to what you stated earlier.
    See my past post about the difference in fuel mileage which is really the upshot. Trust me if Toyota could get 50 mpg like the TDI Jetta does (at any RPM) it surely would. It surely doesn't, so they don't even compete from that point of view.
    I would hope so -- even with a turbo, the Jetta TDi is a much slower, less powerful car:
    Jetta TDi: 100 hp, 0-60 mph in 11.5 seconds
    Camry SE: 158 hp, 0-60 mph in 8.6 seconds
  • 600kgolfgt600kgolfgt Member Posts: 690
    I've surpassed the 300,000 mile mark. Twice. In a 16-year span. With the same car - a 1987 VW Golf GT. It would have gone further, except that it met its demise at the 624K mark during a 55 mph encounter with Bambi. I performed most of the maintenance on the car (oil/filter changes, spark plug changes, timing belt changes, water pump, brake rebuild, A/C rebuild, suspension changes, exhaust changes, alternator change, starter change, and a fuel pump replacement). The only maintenance items I didn't perform required putting the car on a lift (clutch, drive axles, front wheel bearings, engine/transmission change at the 429,000 mile mark).
    I replaced it with a 1997 VW Vento (Jetta) and just turned over 200,000 this evening. With my 1hr, 20 minute daily commute, I should hit the 300,000 mile mark in about 3 years... :shades:
    Congrats! what type of oil and change intervals do you use. Good luck on your next 300.
    The hp is certainly more, however compare the(2007) torque 161 #ft vs the 2003 TDI of 155 #ft . MPG is 24/33 vs 42/49. or 48% better, or the SE gets 33% less than the TDI. So are you saying 161 is WAY more powerful than 155#'s? It is clear to me you have not experienced the A/B difference.
    On a practical basis, while it is VERY obvious 11.5 seconds is slower than 8.6 seconds, it is really not a big deal, especially on the open road. As a comparison, I am also keeping in mind a 4 sec 0-60 car that I also have.
    I realize that "torque" is the usual rebuttal offered by diesel fans, but torque is not critical to acceleration if your goal is to move a relatively light object such as a car. It would matter if you were hauling heavy cargo, as do locomotives and semi trucks, but the numbers make it clear across the board that diesel cars are simply slower off the line.
    Also, the diesel fans have a tendency to give credit to the diesel that they should be giving to the turbocharger that is often attached to diesel engines. Diesels need forced induction just to get even tolerable performance, as the Jetta illustrates -- 100 horsepower from 1.9 liters AND a turbo is pretty lackluster at best as compared to a gas engine with a turbo. The VW Audi 2.0 liter turbo gas engine produces about 200 horsepower, about double the output from a turbo engine of about the same size.
    It is pretty obvious the diesel would probably not be for you. I do not see torque as a rebuttal. It seems you have not spent much time in a diesel car. To me it is very well adapted to the roads in the USA. I have also said that the diesel is slower off the line. To me 0-60 is way overrated. But I realize it is important to some folks. If you rather get 33 mpg rather than 50, mpg, hey it is truly your nickel.
    The turbo is an intergral part of the design. So what about the T in TDI, is not giving credit to the turbo?
    I notice a tendency in these discussions for apples-to-oranges comparisons being made between turbodiesels and normally aspirated gas engines, while forgetting that a turbo gas motor will generally far exceed the performance of a turbodiesel of similar size. If you want to measure the true benefits and deficiencies of diesels, you need to start by accounting for what is being contributed by the turbo, which provides similar benefits to both types of engines.
    Well I think part of that reason is for example the VW TDI is NOT available WITHOUT the turbo. So you are being way too redundant. The gasser as you are probably aware comes in turbo and normal aspiration. The other is in answer to the turbo diesel vs turbo gasser performance issue is SO WHAT? If I wanted a gasser turbo, I would have gotten it. The problem I sense is you want them like for like. Hate to break it to you, but they are not like for like, but have their differences. If it is too hard for you to comtemplate stick with a normally aspirated car. You would be setting yourself up for undue disappointment. It is also best to drive (ANY) the car with the various systems in mind, so that might also not suit you or cause you undue complication. So it is a matter of choice now isn't it? Or in the case of the USA lack there of of diesel models.
    I don't follow your point. What I am illustrating here is that turbos provide certain benefits to BOTH types of engines, namely torque and fuel economy, that you are attributing solely to the diesel, when a similarly equipped gas engine provides many of the same benefits.
    I think that you can safely make these general statements when comparing a turbocharged gas engine and turbocharged diesel of similar displacement and configuration:
    -The diesel will have less horsepower
    -The diesel will have slower acceleration
    -The diesel will have a lower top speed
    -The diesel will rev less freely, and redline at a lower point
    -The diesel will have better fuel economy for a gallon/liter of fuel
    You can argue about what matters most to you, but at least let's be honest about the benefits and drawbacks of each. And let's also acknowledge that installing turbos on gas engine will provide a portion of that same benefit to gas engines that it does to diesels.
    "that you are attributing solely to the diesel"
    NO! I am not. That is YOUR interpretion, even after I have mentioned at least twice about TDI turbo diesel. So I am not sure what you are trying to prove!?
    ...""The diesel will have less horsepower
    -The diesel will have better fuel economy for a gallon/liter of fuel "...
    Not sure why you are trying to reinvent the diesel/turbo diesel here!!???
    Comparing the turbo Jetta to the normally aspirated gas Camry is one example of this. Comparing a 100 hp engine to a 150 hp engine is not generally going to result in similar stats, no matter what car you're talking about.
    Again it comes back to my point about the lack of diesel options on more models. So when are they going to come out with a Camry TDI !!!?? The comparison was made for SIMILAR torque 161 vs 155. and 4 cylinder and the fact the Camry was the bigger 2.4 vs the 1.9 TDI. and the almost extreme difference in mpg. Again you are trying to make them the same they are not and I have said that up front. Again it was for similar torque and of course the Camry had app 68 hp more.
    You are being way redundant again. If you wish to do that go ahead, I will just stop answering.
    That's sidestepping my point, which was to point out the flaws of comparing a normally aspirated gas engine to a turbocharged diesel.
    Again, I don't understand the point of mentioning torque, when it has no discernable benefit to acceleration, as has been implied here. Higher torque numbers in a vacuum don't help passenger cars to achieve better acceleration, so why keep bringing it up as if it does?
    This is the sort of apples-to--oranges comparison that I'm talking about. Is anyone actually surprised that a motor with 50% more output and stronger acceleration in a larger car gets worse fuel economy? I would expect to see this very same thing with any comparison you could make, including one that included only diesels.
    I will grant you that diesels get better fuel economy. But you overstate the differences by comparing cars that aren't similar to each other.
    You might want to google torque for a encyclopedia defintion. http://en.wikipedia.org/wiki/Torque
    Force = force? like for like (relatively) 161 # ft of torque vs 155# ft of torque!!?
    Horsepower. http://en.wikipedia.org/wiki/Horsepower
    The torque obviously isn't resulting in faster cars.
    Have you ever compared similar cars in turbodiesel and turbo gas variants to see the difference? You'll invariably find that the diesel gets better fuel economy, but is slower. The torque doesn't help the diesel cars to achieve better acceleration.
    In 2003 VW has both turbos: 1.8 T gasser and 1.9T diesel. The answer is yes and again, so what? If acceleration is important to YOU and you have said that already (for example) DON'T do the diesel. But I have said that already, said that already. DID I SAY THAT ALREADY?
    If acceleration is important to YOU (for example) DON'T do the diesel.
    I'm not talking about what's important to me, I'm just trying to get the discussion to stay honest and not prone to overstatement.
    Again, why do you keep mentioning torque as if it is a substitute for horsepower when there are plenty of high torque engines that deliver slower acceleration? Torque clearly isn't where it's at -- the cars are slower.
    I think you have issues way independent of this topic and of being solved here. YOU are doing the overstating. You dont like the acceleration of the diesel. So if I were you I'd stay away from the diesel. Your problem is you want the diesel to accelerate the same as the gasser; like for like it doesn't. So let's stop and move on.
    Now you've lost me. I simply pointed out the fallacy of comparing 100 hp motors to 150 hp motors, and of comparing non-turbo gas engines to turbodiesels, so why are you making this a personal issue?
    Because you are personally making this an endless loop. Stop and move on.
    When I read these exaggerated claims, such as diesels getting 37% better fuel economy, then I have to shake my head at the overstatement that is occurring here.
    You only achieve these numbers by comparing cars that aren't evenly matched, and then overstating the benefits of the diesel. That's not a legit course of argument for the diesel fans to take.
    The VW 1.8 T gasser gets 31 mpg and the VW 1.9 TDI gets 49. That is app 37% (.3673469). If you don't like the math dont look at it. It is a statement not an overstatement. You are doing the overstating. Like I said and you have confirmed, you can't get over wanting it being evenly matched and can't accept that even I am telling you they are not evenly matched. One IS diesel and one IS a gasser. You want faster acceleration and 31 mpg get the gasser. You want or are ok with slower acceleration and 49 mpg, get the diesel.
    So if you compare a 1.8T VW to a 1.8T VW now thats evenly matched eh? 31 mpg=31 mpg? You want an endless loop? Just talk to yourself.
