Chevy Silverado and GMC Sierra Duramax Diesel Questions
                    Talk about problems with your Duramax - as well as the older 6.2 and 6.5 diesels - here!
Rocky
Anyone else have this ticking?I love this truck and hope to have a long relationship with it. You know what I mean!
Each failure happened when truck was parked in same spot - slightly downhill with wheels turned to right. Also, temperature had dropped significantly overnight.
Would appreciate any insight available since repair service can't do much until problem recurrs.
Injectors were replaced when the problem with the 2001 system was first discovered. Heater block hadn't been used until I got the vehicle but this doesn't have any effect on the problem.
Any ideas as to why this could be happening?
Now it seems to be happening more often
Any clarification?
mark
We are all in different cities in NC, GA and MO so its not just our fuel stations.
Here's my notes on my 2003 GMC Sierra Fuel Filter Problems:
3/26/07 - 4/2/07 37085 miles, after diesel fuel filter was replaced on 3/19/07, priming problems happened 4-5 times (i.e. the problem is worse). I left the truck with Chevrolet from 3/26 to 4/2/07 and the service tech kept the truck outside at all times and started it with no problems each morning. I talked with the Mark - Service Manager and he said they have had problems with water in the water separator which freezes and partially restricts pressure/flow and the vehicle won't start. He recommended buying GM Diesel Fuel Conditioner. I bought 2 bottles of the GM Diesel Fuel Conditioner and added 1 with a fuel fill up on 4/2/07.
I haven't had any problems since I got it back from the shop and I keep the truck in my heated garage at night.
I'm wondering about the new Ultra Low Sulphur Diesel being a possible culprit?
I'm currently running 100% BioDiesel in my 07 Silverado 2500HD. {LBZ 6.6L}
I feel relatively comfortable running 100% BioDiesel in my truck, but some colleagues and friends have warned that I'm taking a risk with warranty issues.
I think that's all bunk based on very old news, but any thoughts on that are welcome!
-Pete
kcram - Pickups Host
I am having a problem with no acceleration if I punch it quickly, it will continue to run the engine but will not exceed over 2 RPM's, I have to shut if off for about 10 minutes before it will accelerate and run at a normal RPM. It has left me sitting on the side of some pretty busy freeways, all because I am trying to get out of the way of a larger vehicle. Anyone having this problem? it also rattles like it has 100,000 miles on the front end. yes, I am 100% woman, therefore, the dealer looks at me like I have lost my mind when I complain, it's less than 6 months old and 14,000 miles mostly highway miles and the suspension sounds old already anyone have any advice for me? I thought HD stood for Heavy Duty, this truck gets driven like a truck should, not a sedan. they tell me that I have the best truck on the market, so do not worry, we can fix whatever happens to it, but, they don't.I have tried other dealers, they are all the same. I would love mine too, much more if it didn't make me worry that my girls and I are going to be stranded some place out of town and with horses in tow.
I guess I should add this is an 06 Duramax Diesel.. 13.500 miles..
