kcram - Pickups/Wagons Host
http://dodgeforum.com/forum/2nd-gen-durango/83554-multifunction-switch.html
http://en.allexperts.com/q/Dodge-Repair-809/2009/12/2005-dodge-dakota-multifunct- - - ion.htm
http://en.allexperts.com/q/Dodge-Repair-809/2010/3/2007-Dodge-Dakota-Multi.htm
http://www.justanswer.com/questions/4q1w-electrical-problem
The part cost $66
http://www.wholesalemopar.com/parts_catalog-small.html?gclid=CN_buqbjw6ACFQldago- - - dJUsPbA
type in "combo switch" for the part description.
You can buy a Chilton Manual at Auto Zone for @$25. It also has detailed instructions and is well worth the purchase price.
When I replace the bulb it works for a while then stops . It has gone in and out intermittently . Any Ideas?
I thought it was the socket connection .. I cleaned and expanded the socket terminals and it still happens.
Thanks Dan
All at once I lost the following in my vehicle:
Power Locks & Keyless Entry
Intermittent Wipers
Headlights
Foglights
Interior lighting
I've checked the fuses, and they are all fine. Has anyone seen/heard of this before?
Worried about not having any headlights or interior lights.
Thanks so much!
This could be just a bad or loose connection somewhere, or a failed computer module. I would pull the instrument cluster, re-seat all the connectors, look for any obvious bad connections, and maybe even reflow all the solder joints on the instrument cluster.
#%@& is about all I can say at this point
Jason
PS: I see from reading this forum that these Dakotas seem to have have strange elec. issues, problems.
