Visitor Agreement.
One other thought, if you can wait, the 05s will drop in price, my guess is around April or May next year. The 06 is supposed to carry a face-lift, and who knows what kind of improvements (or cost cutting) will come with it.
Timing is right for a 2004 right now, though.
-juice
-juice
To be honest I removed mine and it hasn't made any difference. The engine doesn't even look dirty.
The cover is cosmetic, note that a lot of other Subies with the same engine do not have it.
-juice
Or maybe they all sold and they got a new allocation.
-juice
Elissa
Tread lightly. ;-)
-juice
elissa
-juice
John
-juice
-mike
My guess would be that because the CRV doesn't offer full-time AWD, they have opted for the stability control. Also the subies are a bit more setup for spirited driving and VDC can interfere with this, as well as causing problems offroad.
-mike
Honda, which has reports of 60 fires from oil-filter leaks in some CR-V sport-utility vehicles, plans to step up communication with its dealers and remind all oil-change shops of proper service procedures.
The National Highway Traffic Safety Administration (news - web sites) closed a preliminary investigation July 1 despite 22 reports of fires after oil changes in 2003 CR-Vs. Honda said then that it was notifying dealers that oil filters could stick and oil drips could cause fires if the work wasn't done properly.
-Dennis
Basically Subaru designed VDC to work in combination with that AWD system, a very sophisticated approach.
Toyota takes a basic AWD system and adds VSC to it. It's less effective, though, in fact I think they even revised the system for 2005.
So I guess Subaru has not gone "half way", and only builds the more sophisticated system (not unlike German AWD systems). Perhaps they should, though, now that Toyota (2004) and Honda (2005) will have it.
-juice
Same tread design, same price.
Are there any advantages, given the Forester suspension setup and nature of the tire construction, in choosing one speed rating over the other?
Then reconnect the relay, and crank the engine until it starts. Go back to the filter and make sure there are no leaks while the engine is running.
Here's the page out of the service manual that shows the location of the fuel pump relay.
http://members.cox.net/craig.hunter/Fuel_Pump_Relay.pdf
Craig
ps: on my 02 Outback, you could pull a fuse to cut power to teh fuel pump rather than messing with the relay. Much simpler.
Of course, YMMV.
Also remember to have disposable towels or cloths under the fuel lines so if any drips occur the fuel won't spill into the engine.
Someone else on the boards here posted that tip quite a while ago. Please do remember to disconnect the battery.
HTH
Larry
http://img79.exs.cx/img79/1187/cupholderslots.jpg and here's a shot of the cupholder section removed so you can see the side slots:
http://img79.exs.cx/img79/6882/cupholderside.jpg
As you can see, the slots on the sides of the console show a little wear, but they seem ok and still functional. Anyone have this happen and have any suggestions before I have to take it to the dealer and have them look at it?
Steve
Craig
Fuel filter takes about 3 minutes tops.
If the car is cool, just open the gas cap, let it sit for about 20 min.
Then pop off the hoses, pull off the old one (under the hood) and then put it back on.
close gas cap, and bam done.
However in '04/05+ cars it's in the gas tank. Not looking forward to that change.
-mike
I've done it twice and it only spilled a couple of drops.
V-rated tires are generally more heat resistant and offer more grip but don't last as long and they cost more. If you drive hard, it's worth the upgrade.
-juice
I got the H rated tires from Costco as they stated the V rated tires are against the manufacturer's spec. and wouldn't sell it to me. Also, the H rated tires are rated for higher speeds. I love the tires so far.
Clee
P - 93 MPH
Q - 99 MPH
S - 112 MPH
T - 118 MPH
U - 124 MPH (havent seen this one before)
H - 130 MPH
V - 149 MPH
W - 168 MPH (a new rating from when I sold and installed tires)
Y - 186 MPH (ditto the Y rating)
Z - 149+ MPH
I hope this helps a little.
Kyle
Bob
Are you sure of that? I know that higher rated rubber will not stick as well at cooler/lower speeds. As for tread life, not sure how that goes, but just thinking back, and my higher-speed rated tires generally wear out in the same time as regulars however I have driven them much harder or on the track along the way.
-mike
Don't all tires have "wear ratings" on them such as 93, 89, etc.? I'm not sure if they are rated "within" a given speed rating (H for example), or are rated against all car tires available?
Anybody know for sure?
Bob
60 is the bare min of a street tire
180 is a low wear rating
300 is a good wear rating
400+ is excellent
I've seen wear ratings on all different speed ratings varing from 60-400. For instance...
Faulken Azenis have a rating of 60.
Yokahama AVS Intermediates have a rating of 180.
I think Tirerack lists the wear ratings on their site.
-mike
I'm a bit confused -- the gas tank is more or less vented to atmosphere. It may get sucked down a tiny bit, but it should never see greater than atmospheric pressure. It's not a pressure vessel by a long shot.
The fuel lines downstream of the pump are boosted to high pressure, and that's what needs to be purged before you change the filter. The only thing that will purge the pressure in those lines is time (ie, waiting), running the engine dry, or activating a fuel injector to bleed the line down (on some cars, they actually tell you to run 12V across an injector for a few seconds).
Removing the gas cap should have zero effect on the pressure in the fuel line. About the only thing it does is let fumes out (which would normally be trapped by a filter in the tank's vent system).
Craig
Bob's talking about the UTGQ ratings, Uniform Tire Grade Quality. Those are determined by the manufacturer, though, against a "baseline" tire, whatever that means.
The 93, 89 numbers are actually the max payload for the tire. 225/60R16 89H are on mine, for instance.
The heat performance indicator is the 2nd letter in the UTGQ, 460 A A on mine for instance. 460 is tread wear ratings (vs. 100 for the baseline tire), then the first A rates wet braking traction, the second A rates the heat resistance.
My H-rated tire therefore has the highest rating for heat resistance. 460 is a very long tread life, too.
My original tires, Duelers, were 180 A B, and S-rated. So they were rated for lower speeds and had a B rating for heat resistance. In fact they're probably S rated because they scored poorly in heat resistance.
-juice
I guess all the tires are compared to 'a' controlled model.
They didn't say if each speed rating has their own controlled model though.
-Dave
UTQG is determined by the tire manufacturer. So ABS Tires could say their Generic Special is 800 AA A and stamp that on there, even if it's not.
-juice
I think you're right about that. My numbers were for payload, or something like that.
Bob
http://www.tirerack.com/tires/tiretech/general/speed.jsp
Both the Goodrich H and V come with the same "60,000 miles" connected with them. (This from the guy on the phone at Tirerack.) Both, as I said, are the same price.
What mike suggested about the speed tire not doing as well at lower temps strikes me as a bankable thought.
So I wait for the H's to become available again.
That it might take a few weeks is no big concern; my Geo's (43K) will certainly hold out that long.
Depends on the application, I guess. But I think it's fair to say that higher performance tires tend not to last as long.
-juice
kcram
Smart Shopper and Wagons Message Boards
On another note, I take it youve been to fitzmall down there in maryland a few times. How are their stock of WRX wagons? Do they tend to keep more than one or two on the lot? I'll be in the market for a new car next fall and its not too far from my homebase here in philly. I have been considering them a lot as the two local subie dealerships seem to sell mostly at MSRP or a bit below with little want to negotiate. Fitzmall's internet pricing seems most reasonable. Next year it will come down to if they have a WRX wagon in WR blue of either 05 leftover or new 06 vintage.
Kyle
