Visitor Agreement.
Email a host if you continue to have trouble and we'll try to help out.
Here's the True Cost to Own link (and there's a link on the left when you drill down to your used Volvo), but it's only for more recent years (2003 and later years for the V70).
SUVs and Smart Shopper
a. Break Fluid Flush;
b. Coolant Flush;
c. Transmission Fluid Flush;
User's manual doesn't tell me when I should be doing the above services.
Thank you in advance.
kcram - Pickups Host
The real unusual part is that the emissions light came on and it started running fine. As soon as the emissions light went off it became sluggish again. So every time the emissions light comes on it runs normal.
Has anyone experienced this before? If you have, what were you able to do to fix it?
Scott
Jalimey
If you are not seeing an option to post a message it is probably because you are not on the last page of a discussion. You will need to navigate to the last page of a discussion to find the text window like the one you found here.
Also, another way to post s message, when appropriate, is to click the "reply" link of an existing message.
Good luck!
The car was driven like this for 15 miles, or so, then parked and turned off. The windows were closed using the key in the outside of the door. After about 25 minutes the car was turned on but would not start. The control lights light up but the ingnition does not engage. No click or buzz. Nothing. The battery is good. The radio goes on. The clock is on. Headlights work. Fuses are okay, though there are a quite a few empty spaces. Though the windows can be operated from the outside with the key, the sunroof will not close with the key or from the inside...
Oh yeah. There has been a brake fault beeper goiing off since about a month ago, though the brake operation is okay- perhaps the abs system is not working quite right...
In older cars, I would have expected the "solenoid" was out, but even that would click with the surge of electricity through the ignition to the starter motor. What's going on? Is there a reset switch somewhere? Has anyone got a loaner? :confuse: :sick:
I get bad gas mileage 15 normally 25 city 30 hwy. Vehicle taken to several certified mechanics all say there is not error codes, fuel pressure is good, good tune up, plugs, oil change. The car runs great. Recently replaced two fuel injectors.
Can anyone help? email at rockmanishere@yahoo.com
Good luck - welcome!
Chevrolet Malibu: TSBs/Recalls/Problem Codes
Chevrolet Malibu Maxx: Problem Codes/TSBs
You should also take a look at the Nissan Sentra: Prices Paid & Buying Experience discussion.
thanks :sick:
MODERATOR /ADMINISTRATOR
Review your vehicle
see very little on replacing ECUs. does it cause any further damage if replaced?
There are few old ECU posts in the archives too:
tarik, "Defective ECUs or other controller problems on your car?" #1, 5 Sep 2001 6:16 pm
Greg
If yes, please direct me to it...if no, I see no reason to start one...after all, I like to avoid controversy, as I am rather sweet and introverted, and sometimes even downright gentle...
There is the odd Al Gore comment now and then.
You're insured - come join us. :shades:
I asked him, if the NEW HD model's are being built with the NON-ULSD engines. He could not tell me.
So, my question are directed to the GM dealers/manufacturers here online:
1. What is the difference between the 2007 2500HD and 2500HD Classic?
2. Is the 2007 HD, the new body style?
3. Is the NEW body style HD avaialble with the NON-ULSD engine? If so, how long will they be available?
4. When, will the ULSD's be hitting the lot's?
5. I guess this is a given.. based on the answer to #3.. but, are the NON-ULSD engines only available on the Old body style 2007's?
6. If I ordered a new 2500HD Diesel this month, what would be my chances of getting the old diesel engine?
Loyal Chevy PU Owner
Review your vehicle
