Has anyone had any problems with this or have heard of this happening? I took it to a dealership and he basically told me that he didn't know how to fix it.
PLEASE HELP!!!!
Arnie
1. When I attempt to use the remote start, there is a loud pop sound coming from inside the hood. When that happens, the lights flicker on and off inside the vehicle and resets the clock in the car. Now I don't want this to sound like it happens all the time but it happens probably once a week.
2. The second problem I'm having now is I will try and unlock my vehicle with my Key FOB and the doors will not unlock. When I manually unlock the vehicle none of the lights work inside and I also will put the key in the ignition and the vehicle will not crank over.
Has anyone had this similar problem and what they did to fix it? Thanks!
Does yours only do it when the AC is on? My husband wonders if it is the belt tensioner. Good luck. Let me know if you figure it out.
When I got home both problems disappeared before I saw the dealer and never returned.
I've just chalked it up to the Yukon gremlins that are always messing with me. Windows that decide not to work (until engine restart), battery that drains in 15 minutes, door locks that engage while I'm gassing the car ....
Let me know if your dealer finds the problem.
Tom - Franklin, MA
Tom
I am having a problem with my 2007 Yukon. The remote key pads do not work and my key does not work all the time in the door lock. When it's really cold out, the key won't go in the lock all the way and when it does, the lock slowely rises to unlock the car. I took it to get looked at and the dealer said my keypads are fine, it's something in the computer. I have to take it back to be put on the diagnostic machine. Has anyone experienced this? All other electrical systems seem to be fine.
Have you had anyone look at your vehicle to diagnose the concern? I apologize that your vehicle has a concern. How long has the issue been present? Thank you,
Mariah GM Customer Service
the dealership [darcy gmc] says it my problem !!!!!
Have you spoke with the dealer? I apologize for your experience.
Christina
GM Customer Service
I took it to the dealership and I am going to get a bum deal because warranty is expired (but they cant even figure out my mileage!!!). Any how, the I told the service rep my problems and he says "I've never seen this problem before!!!" automatically I think the opposite, then I research and find this discussion and everyone is having the same problems also and I laugh.
After holding my car overnite, the next day I get a call from the dealership and the rep asks me if I opened the dash and tampered with it???? I say y the hell would I do that? Then the rep asks me if I jump started someone else's car and did it wrong...I told him I have helped others jump their car, but I am pretty sure I know how to jump a car. OH and that the diagnostic report indicates "30 codes" or that 30 things are wrong!!!!
So then I also researched for recalls and my VIN number indicates none (although all the yukon/gmc recalls seem to sound like the problem I am having which is prompting me to find out how to initiate recalls). So in researching recalls, I find a GM number I call it. The GM rep seems very helpful and informs me that he will call the dealership service department. He returns my call and leaves a message that the dealership has still not determined what is wrong and he will get back to me on monday.
That was 2 days ago, and since then the dealership has not called me on an update on the status of my car. My car has been at the dealership for 4 days now....am I going to pay for 4 days days of labor???
My complaints are that:
1) these problems ([non-permissible content removed] computer system, dash, remotes) really seem to be malfunctions and not my fault as it is a prevalent problem.
2) dealership thinks I'm dumb and gave himself away with stupid [non-permissible content removed] comment and I plan to print these posting out for him, but im sure hes already heard it already....liar.
3) This is a family car....I live in Hawaii where I pay extra for the car to get shipped here, I pay more for the cost of living, with that said, I expect my moneys worth but now I am going to probably end up paying more for a piece of CRAP....I do not ever plan on buying GMC ever ever again....id rather have a KIA lol.....if GM were to fix this and take accountability for their workmanship...I might actually think about it and have a little faith in....nevermind.
Lastly I am glad there is a forum like this, so I can find a site where ppl are happy with their car....then I'll know where to shop.
The problem is, I keep finding more problems. Some that I have found:
The blinkers dont blink if the lights are on.
The cruise control doesnt work if the lights are on, but do when they are off.
When the lights are on, the tail lights light up like you are using the brakes.
If the lights are off and you step on the brake, the dash light lights up.
Some one told me that there is a chip board behind the tail lights that is causing the problem, but I was hoping to get a little more info on it before I dig into it myself or bring it to a shop...
Any help is greatly appreciated!
I apologize for your frustrations. Have you spoke with your dealer? Can you send me your VIN? I look forward to your response.
Christina
GM Customer Service
I looked into the manual to see if there was any information on the remote keyless entry system. There is a section on what to do when you notice reduced operation:
"At times you may notice a decrease in operating
range. This is normal for any remote keyless entry
system. If the transmitter does not work or if you
have to stand closer to your vehicle for the
transmitter to work, try this:
• Check the distance. You may be too far from
your vehicle. You may need to stand closer
during rainy or snowy weather.
• Check the location. Other vehicles or objects
may be blocking the signal. Take a few steps
to the left or right, hold the transmitter
higher, and try again.
• Check to determine if battery replacement is
necessary" (p.115).
Hope this is helpful for you!
Sarah
GM Customer Service
And explained and they ended up fixing it, not sure what they did but it finally got fixed, not until I complained . But it's.been fine ever since, sorry to hear about yours, hope you get yours resolved soon, it's aggravating isn't it.
Any ideas?
1. When I turn the car on a loud clicking sound comes from the CD player that lasts for 30 seconds. Nothing stuck in it. Have learned to live with this after 3 years. Irritating, but at least the car is turning on, which leads to the next issue...
2. Without any notice car just simply won't turn on. No clicking, nothing. Silent. I have to open hood, jiggle battery cable, and usually it will fix. But not always. I have had a new alternator, new battery cables, new starter and new batteries installed. The latest attempt was installing a gmc battery bc "the posts on the non-gmc battery were not exactly the same size as the clamps on the cable and it wasn't getting good connection". Well, yesterday I pulled into the driveway, ran in the house, came out and again, car won't unlock with key fob and when I turn ignition, nothing. I opened hood, pushed around on cable and it started. Has now done it twice today.
3. When it does run, I will be driving and suddenly everything electrical on car turns off. Radio, cruise control, lights, ac, you name it. Few seconds later, it all comes back on. Periodically the lights flicker on dash and headlights. Serious safety issue at night.
I seriously don't know what else to do. I have 3 small children and can't afford to be stranded with them anymore. If anyone has had any luck fixing these types of issues please tell me what to do.
