Toyota Camry Starting / Stalling Questions
My Camry was making "clicking" sounds when I tried to start it...turned over hard but would finally catch...I replaced the battery. After replacing the battery it started and I drove to Brewer which is about an hour's drive...took care of my app't. and when I came out the car wouldn't start... and was then told to replace the starter which I did...and it still won't start...not even with a jump...could it possibly be the alternator at this point ??
*Low electrolyte level or shorted cells comes to mind. If your son can remove cell caps to view the electrolyte level, he may be able to bring each cell's level up to just over the top of the plates with distilled water. Not all auto batteries still have removable cell caps, though. If the electrolyte level can be topped up as described, the battery would still need to be put on a battery charger overnight - AFTER DISCONNECTING THE NEGATIVE LEAD to the car, first. (The nominal 14 volt output of battery chargers can fry some voltage sensitive automotive electrical components.)
Thanks much
In addition to various circuit breakers and fuses, cars also contain "fusible links" - lengths of specialized cabling which pass current up to their calibrated ratings but will give up the ghost intentionally to save the rest of the electrics in the event of catastrophic electrical failure farther up the line or S-T-U-P-I-D-I-T-Y. (I'm sure he's really a bright guy, but confusion and/or negligence stepped into the situation and left him with egg on your face.) I suspect the valiant death of a fusible link in the line of duty was responsible for the momentary light show. If I'm right, don't worry - they're replaceable and not terribly expensive. Remember to request that the shop you take the car to also runs a load test on the car's alternator to verify its diode pack wasn't damaged by the power surge. Do NOT attempt to jerry-rig a replacement with standard similar gauge cabling - your car would have NO viable protection left in that circuit in the event of future trouble. An electrical fire could result. Give the kid a pass this time and take a diuretic.
(Leastways hold off on anything you have in mind 'til January 2nd if he's a minor so you can claim a child deduction for the entire 2007 calendar year...;))
If you think that fuse is good and not blown, then I will need you to check some voltages with the voltmeter, I'll tell you what you'll need to check at that time.
Actually if you think that fuse is good, if you either have a spare in the fuse box lid, or there is another fuse of the same 40A size, then swap it anyhow.
There's a way to override the transmission gear lever to put the car in neutral if it has to be towed -- check your owner's manual.
As for the overheating, I'm stumped. Does the temperature gauge on the dash show overheating, or does the overflow tank simply spill over (maybe overfilled in the first place)?
At least you were able to get someone competent to diagnose and fix your car properly, for not too much money as I said earlier.
Good luck!
The car issues (wiring etc) were resolved by the local Toyota dealership mechanics, but I'm not sure how much competency to credit them with. They thought it was the after-market security system I had, even though I said it wasn't likely to be the issue. Since it didn't work any more anyway, I agreed to let them remove it (cost of $272) and it was just by coincidence that in doing so, they could see the bundle of wires that were melted/fused. They weren't looking for that initially. So, I paid unnecessarily for the security system to be removed, but it was worth it since they did end up identifying the wiring issue, and getting my car to start again, as well as incidentally resolving the boil over problem. All because some animal ate my car in 1994! Crazy. Thanks for everyone's comments and support.
My '04 Camry's idle dropped after I changed the battery, but not as low as yours. After about 100 miles of driving, all was fine (except for initializing the sunroof -- that's a whole 'nother story!)
Recently. about once every two weeks or so, the car refuses to start. Took it in to the dealership. They said it was my battery and battery cable so they replaced these items. Car worked fine for awhile then one morning I tried to start it again and it wouldn't start. Took it back to the dealer and they said it started fine for them and the diagnostic test didn't produce any problems.
Drove the car another two weeks, went to start that morning and again nothing. The car turn over but it won't start (tried 6 times over a five hour period). Took it to a mechanic this time once it finally started on try number 7. Mechanic said same thing: started for him no diagnostic results and suggested that I get my fuel line cleaned. So I paid for that.
Car started fine for awhile. Woke up Monday morning, guess what, car wouldn't start. Took seven tries and it finally started. Has been starting fine so far but I know that it is going to happen again. This two week intermittent starting is getting tiresome. Especially on a 2004 Camry.
Really want to get this fixed since I really do like Camrys. I have only driven Camrys since 1998. Now I am faced with dumping this car and breaking my Camry trend.
Any help would be greatly appreciated.
When you turn the key, does the starter motor engage and then engine start cranking over?
If no, then battery, starter, solenoid, key switch, anti-theft/keyfob, battery cables are the likely candidates. (switch keys to see if the symptom changes).
If yes and the engine cranks but it doesn't start running by itself and idling, could be any number of problems and would want to know more symptoms.
Seems like it needs an ignition switch but I am clueless about how to get the plastic housing off to get to it or how to replace it. Can anyone FYI me on how to replace the ignition switch?
I had my car towed to a locksmith. They "re-machined" the ignition and everything was fine from then on.
Sorry, my response was to frankrom22,
I've not had to have the steering column apart, so I'm not sure I can help you. I do have a set of manuals, but I'm out of town for 2 weeks and can't even look it up for you at this point.
Thanks a lot
Kiawah is very good though, so if you can possibly wait for him to return from vacation, I'm sure he'll be able to find the answer.
As far as Kiawah is concerned I wish I could wait. I am also out of state from home and am due back at home...900 miles away by next Thursday.
Thanks for the suggestions though
what could be the problem? thanks, Mollas
Never mind...it took some doing, but we got the new switch assembly installed.
everthing is ok now.
It has happend 3 times till now. First it happened 2 months back. I turned the keys and nothing happend. I
turned it 3-4 times but nothing it didn't even click or anything. I tried few more times it clicked once but didn't
start. My interior light and headlights were working. I went to office in friend's car. In the evening I tried to
start the car again. Turned the keys 3-4 times after trying for few times finally it started. I had the problem for 2
days. I used to start the car by turning key again and again. After 2 days the problem disappeared. But then it
showed up again 2nd time a month back. At that time also it did last for one or two days and then went away. Today,
after a month, same thing happend again, this is third time. In the morning car did not start. I tried to turn the
key 3-4 time. It clicked once(made that start up noise) but didn't start. I did not take it to work. In the evening
when I tried to start it, it started after 3-4 attempts. Once it started I took it to the mechanic and explained
him the problem. He was about to close the workshop, so he didn't take a look at the car. Based on my description
of problem he said it might be a problem with the starter.
What could be the issue? Thanks!
