Visitor Agreement.
gear, reset the code, disconected the battery to rest also, checked the drive line, checked to see if the tourq converter was connected. I have no R, no D, 1, ,2, 3.
Time for a new transmission or is there something I don't know?
I wish these guys would reply!
Is it pulled out of another vehicle, a rebuild, or new? What kind of warranty?
call justin 800.409.1540
where do you live?
do you have a friend that has a shop?
Just keeping track of what the different fix alternatives are, and what they cost.
So in your case, you are going to have someone swap out the whole transmission, and it appears you have a friend who has a lift and labor who can help you do that. And then justin will take your old transmission back, rebuild it, and make it available for the next guy.
So after contacting several shops and getting prices it became clear to me that this has to be a pretty common problem with my trans since all off the trans shops knew exactly what failed when i described it to them. It has a broken sun sprocket which tends to wear and break after excessive abuse or a lot of miles which I have.
The differences in prices were varied from over 2000.00 to around 1200.00 with just about every shop adding (give or take a couple hundred bucks). I kept my searches to local shops that took the time to talk to me about it on the phone and avoided the chain store type of operations altogether.
So with a bit of knowledge about what it costs for parts for this repair and the care that is needed to do the job correctly I was able to get a reasonable price and a 2 year warranty. I don't have the final price yet since it is currently in the shop but I was told it will definitely not exceed 1400.00 dollars. and that is with a heavier gauge sun sprocket (after market part) and replacement of the planetary gears included in the rebuild. also the transfer case seal will be replaced since these tend to dry up and become brittle which allows trans fluid to leak into the transfer case. This I am told is a VERY common problem and can result in the loss of 2 quarts of trans fluid into the transfer case. And within only a couple years of age of the vehicle.
And as for the clunking sound from the drivetrain , apparently GM considers this normal!!!??? This is what I was told by several trans shops and the fix that they use to try and alleviate some of the binding and noise is to improve the finish of the surface on the input shaft going into the transfer case and lubricate it well so as to improve its ability to adjust within the moment of its engagement. sounds a little sloppy from the get go, but hopefully that will help. It is a major annoyance and takes away my confidence in the soundness of the drivetrain. Unacceptable standard of quality if you ask me. I will be listening carefully if I venture into a showroom for a new vehicle.
keeping my fingers crossed and my expectations high.
I will post again with my impressions of the repair when I get the vehicle back.
If you know anyone that needs one call Justen 800. 409.1540.
e-mail if i can help anyone.
gary
Anyone have any insight as to what part might be wearing out. I'd like to be armed with some information prior to contacting dealers (who are looking to maximize revenue in a tough market).
I have a '04 Tahoe too with 98 000 miles but have no problems like you describe but there is one thing I would do before taking it to anywhere to have it looked at any deeper - Change the transmission fluid. I had it done at 75 000 miles and I did feel some jerking a couple of times before fluid change.
You might not be at the mileage what service manual calls for fluid change interval but harsh change between gears can be caused by break down of the transmission fluid.
I know it is about $100 but well spend compared to changing transmission or having some other big job done to it when it really just needs new fluid. Make sure they fill it with correct fluid if someone else than the dealer shop does it.
And you are correct, almost any shop, including dealer shops, try to maximize their profit telling people, who do not know better, that they need to service items that they really do not. This is why I would not tell the dealer or other shop about the problem you have when taking it for fluid change. I would just take it in and say you want fluid change because you feel your truck is used under heavier than normal load conditions.
Arrie
I bought a used 2000 Tahoe in August and have not had trouble until the past month or so.
I had to even have it towed last night!
I seem to have the tranny slip like other have mentioned.
I also have the problem when I'm in a gear, it may not be what gear it reads. For example I was in Drive but it went in Reverse. I put it back in park and went to Drive again. This time it did move forward but very badly and then I too heard a loud bang, similar to a truck that would have a fully locked locker in the rear, only this truck does not have that, just the GM Gov lock or what ever.
Then it would move fine forward.
Other times I put it in Reverse but it acts like I'm in neutral.
Last night I put it in Drive and it would hardly move. The RPMs were way high. So again I put it in Park and tried again. Still the same. It seemed like it was trying to pull out in maybe 3 gear.
I have issues too when I'm just driving it feels as though the tranny might be slipping but it will go on to the next gear.
I have not taken it to a dealer...they seem to stuck on their "tech tool". They couldn't figure out the steering box whine on my husbands truck. I could tell them the steering box was bad and that a tech tool was not going to read that.
Any ideas? So far some one mentioned to me a shift module or some thing there?
It just doesn't go in the right gear when I put the shifter to that spot. Drive just might really be neutral, 3rd or worse reverse.
I for the heck of it tried to just drive with it in the 3rd gear or what ever it's in and I get a huge bang and then its in the right gear. Seems to me it's not fully shifting in to the gear I choose.
Now the truck will shift on it's own fine when I do get it in just Drive.
Nothing shows on a Tech Tool either.
Seems to only do this when it's very cold out. I have not had it do it all summer and we have had a few days inthe 50s now and it won't do it.
Any one think this is electrical and weather affecting it?
I have only had the truck for 3 weeks and I have already replaced the fuel pump and done a complete tune-up (plugs, wires, cap, rotor) The truck takes a very long time to start and I was told at first it was the fuel pump that was weak and so I replaced it and the problem stayed the same. Then I was told all my plugs, wires, cap, rotor etc were original and they were the cause. So I replaced all of that. The problem didn't change. Then today I was driving and the transmission started slipping in 3rd and 4th gear. The truck has 148,000 miles and I paid $5000 for the truck. I have now put almost another $1000 into repairs and I have tranny problems. What do I do?
____________________________________________________________________
I doubt that the fuel injection would have anything to do with the tranny. Better get it checked out right away by a professional. The longer you wait the more damage you will have to repair.
All the dealers I know are fine upstanding individuals. I think we should stay away from maligning a group of people based on a statistically insignificant and flawed sampling.
SUVs and Smart Shopper
I would certainly get a second and/or third opinion.
Transmissions and engines used to wear out, not experience some catastrophic failure that is based on very bad and poor design.
GM customers also used to last but not any more. There still are some "red necks" out there who still believe GM makes the best vehicles but facts are too strong and many GM fans are switching to imports as $55 000 vehicle indeed should not experience a catastrophic failure of anything in it.
If GM would respect their loyal "audience" and go and fix catastrophic failures like transmission "explosions" under warranty even when warranty is out they would have a chance to survive but this is not happening and a lot of people have finally had it with GM.
I have a Tahoe now but my next vehicle will come from Germany.
Arrie
Arrie
I got one of their 2004 model year pieces of crap, which now is good as I fixed all problems myself while it still was under warranty. Well, one problem remains. The steering shaft still needs to be lubed every 40 000 miles or so as I do not have the new part fix in place as the dealer refused to replace it under warranty and I refuse to pay for it since it should be changed under warranty. I have read on many posts where shaft has been replaced for them under warranty but by the time GM finally had the new shaft designed I had too many miles on mine. Problem with defective part existed since I bought the truck but I could not get it done. I bought the lube kit, which is not available any more, but I use it whenever I need and re-lube the shaft.
No more GM for me after this one.
Arrie
Ok, bought my '96 Tahoe LT in April, with 150K miles on it, of which 10K are mine. It has a full tow package on it and I first made use of it with a 5x8 U-Haul trailer this past weekend. About half way into the 700 mile trip, I was entering the Trans-Canada from a ramp and, while accelerating, at about 45-50mph, there was a "zzzzzz" sound, kinda like a power steering pump, but from the tranny area. I was in OD, shifted to D, same noise with power on, it stopped when I released the gas, but no noise at all in 3rd. Everything still worked fine, passing gear, etc., no sign of slipping and the noise quit at hwy speeds.
When I stopped an hour later, for fuel, checked the oil levels, all ok, then put it through the gears. Noise in forward & reverse, with brakes on and slight gas pedal, but it did not last. I finished the trip with no further noise, and no drop in performance and no obvious slippage.
Without the trailer, and in our new snow, I've been putting it through the gears a little more aggressive, but everything seems ok.
I'm doing another 300 mile trip with aging Mom & Dad at Christmas and don't want any problems... any ideas??
Tranny oil is ok and, red, not burnt. Thank
