Chevy Tahoe Transmission Problems
I have a 2007 Tahoe and the transmission has issues. It seems as though it is slipping when you are just starting out in first gear. I have taken it to the dealer and the dealer says all of the 2007 Tahoe's have the same transmission problem. This is really frustrating to have a $40k+ vehicle with this issue and be told by the service department that all of the Tahoes have the same problem but there are no current recalls...Anyone else have this transmission issue?
See Also
Transmission Slipping: Causes & DIY
See Also
R
If this doesn't fix the problem and your transmission still feels like it is slipping, then I would do what the other post said and test-drive some 07 on the lot to see if they do the same thing. If not, then the dealer has to either repair or replace your transmission under the factory bumper to bumper warranty that your 07 Tahoe should still have.
Chevy is normally pretty good about their warranty, so maybe you should go to a different dealership. The dealer is the one who will loose out as Chevy pays them. Maybe they just don’t want to do warranty work because they don't get paid as much as if it was not warranty work. You see the dealers and Mechanic charge you and I the private citizen more than 2 or 3 times what they get paid by the manufacture for the same work. Make's since why they told you what they did. They are trying to rip you off or don’t want to do warranty work. Not all the Chevy dealerships are like this. Good Luck.
Any suggestions.
/s/ Tom Milam, Jr.
milam@inglesrud.com
No sooner than I get it out the dealer my other starts to slip @ 20k. This is the worst I have lost all confidence in these vehicles. This time the whole tranny will be replaced on the week of 4th of July!!!
Has anyone else had a computer monitor installed that is sent to GM?
Has anyone talked to their dealers about lemon laws for their problems and if so what has been said
____________________________________________________________
The lemon laws are pretty much a state issue and each state has different interpretations on what constitutes a "lemon" regarding vehicles and different guidlines on what you need to do to certify that you have a "lemon". Check out your state laws and see what they say.
The Transmission, under acceleration from a stop-light, made a POP sound, then revved up to redline. The transmission only had Park, Reverse, and 1st gear. When revved up in first the transmission would whine. This vehicle had only been put into 4 wheel drive once to make sure it worked, when it was new. This vehicle's mileage is mostly highway, very few city miles. The vehicle has a total of 27,673 miles on it.
This problem resembles the same issue from the 1992-1996 model years where the Spline Drive (input shaft) pin, also reffered to as the SUNGEAR would snap. Under acceleration, approximately every 30,000 miles, the pin would snap causing the input shaft to slam into the forward gears of the transfer case. This could destroy the transmission, transmission housing, transfer-case and/or transfer case housing depending on how severe the load is under acceleration during the failure.
GM knows this part breaks easilyunder load or heavy acceleration (merging, passing, emergency acceleration) and has for nearly 20 years (1998). Why does it appear again in 2007?
C3 :mad: :mad: :mad:
2007 Avalanche-
1) Replaced Sprag Gear
2) Replaced clutch packs
3) Re-flashed PROM for DVD Navigation system
4) Re-flahsed PROM for Console
This cured the problems of the DVD navigation system failing with the A/C Controls and Radio rendered inoperable.
So far, 1400 miles and the transmission is still holding together. No one has raced off of a redlight under full-throttle acceleration, nor have they attempted to repeatedly stand in the throttle in order to accelerate rapidly. My guess is, the next time it happens, it will break again.
In response to the Ford Comment. our 1999 Tahoe worked flawlessly for 167,000 miles- and I do mean FLAWLESSLY.
The difference was, that 1999 Tahoe had driveline slop which caused clunking and clattering and sounded as though something was wrong, when in fact, there was nothing wrong.
I don't hear of these problems in the Pickup, why is it only happening in the SUVs? :confuse:
C3
You can file complaints and fill out forms that send your issues to the investigative group at NHTSA. Its the only way to get GM to recognize the issue.
Also, Contact CNN and file a request for STORY submission at CNN.COM
C3
IT IS GOING TO COST ME 2700 TO GET REPAIRED. PRETTY DISCOURAGING. I WILL HAVE TO SAY THE SINCE MY PROBLEM RIDEN CHEVY TAHOE (LIFTER NOISE PROBLEM,LIFTERS REPLACED STILL SAME NOISE BLAMED ON 5.3 MOTOR,TRAN, A/C EVAPORATOR, STEERING COUPLER)THAT I HAVE PURCHASED TWO CARS BOTH TOYOTAS. I AM A CHEVY FAN HAVING OWED MANY CLASSIC CORVETTES, CAMAROS HOWEVER WITH THE MISERABLE EXPERINECE WITH MY TAHOE I CANNOT JUSTIFY SPENDING 35K ON A VEHICLE
THAT JUST LAST TILL THE PAYMENT AND WARRANTY ARE BOTH COMPLETE.
