Ford F-Series 4x4 Problems
93 ford f150 4x4 is stuck in 4 wheel drive cant get it out the 4x4 light is not on.but it is in 4wheel drive help please
kcram - Pickups Host
1992 Ford Owner's Manual
Local Ford service manager can't find problem or info on Ford net.
I don't really know more but the guys at ford-trucks know a bit more, and there's a guy that posted a TON of detailed service guidelines on his own. He took the time to detail it with pictures and everything, I say he did better than any manuals I've ever read. He goes by the name of guzzle, check him out.
Mark
on it own when the switch is in 4x2 sounds like your f250
did you find a fix for yours iv been working on this veh for
about a week I work for ford in tulsa ok as a tech iv installed a new shift motor after driving veh now veh is stuck in 4x4 only way to get veh out of 4x4 is to install a
new shift motor im installing a new 4x4 module & new 4x4 relays see if will work let me know if you found a fix for this . thanks jeff 918 812-8541
_________________________________________________
all the fuses are good. the front shaft is locked in. the switch has power. but it is not switchin power to the front.
well i put a jump it and jumper wires to the transfer case motor. and the transfer case moved and made noise. but i dont hear the sound when it is on the truck. when its in the truck i get NO POWER to the motor. If someone could tell me where the relays are for the motor and how i can test them.
well the relays are good. and saturday at about 5pm est time. i had to go to town. and i had the wires and stuff all hooked to the motor. and i stopped to do something. and i heard a big boom. the transfer case tried to go into gear by itself. and then the motor was turning like it was trying to go in. then i went about 50ft. then it locked into 4/wd. then the motor started to make the noise again so i pulled the fuse and it stopped. and at this point it was locked into 4 hi so i put the fuse in to put it back into 2/wd. and it did but the front hubs were locked. then i went to turn around and it tried to engage while i had it in gear and i hear the gear grinding in the transfer case.it happend about 4 times. then the front hubs unlocked by itself. so i slowly at 5mph drove it a mile. and i parked it. so this morning i pulled the 2 wires off the transfer case motor. and it is fine now. this all started and the switch wasnt even in 4hi or 4lo. it was in 2/wd. I am starting to feel this truck is a hazard on the road. PLEASE HELP!
orange wire going from 4x4 module to relays was short to ground also burted up 4x4 module had to do a lay over
on wire & replace 4x4 module .
I just $500 on front end work at the tire shop on new control arms. The mechanic at the tire shop thinks it might have something to do with my differential but he wasn't sure. Any ideas?
key off
turn 4 wheel slector to 4 wheel high
start truck
the 4 wheel engages (light on)
Wish I knew what the problem is. I would like to fix it.
Hobo5
thanks, frustrated ford guy
