Chevy Venture Engine Problems
hi i have a 97 venture and for the last 2 weeks i have been trying to get the antifrezze temp up to bar when i drive it but its not warming up. it will only warm up when it sitts ther on idol. i have changed antifrezze and theromstate and it still didn't help if any one else has any ideas it would be a big help. thanks
Aside from being ASE & a GM certified tech, I own a Chevy Venture myself which has over 150k on it. Never have I heard of this oil pan being pourous, nor have I seen one leak that way. Although some oil pans out there do leak this way, yours having 70k on it, should most definitely not be leaking in this manner. It's more likely that it's your intake gasket leaking and trailing downward to the pan area. When the 3.4 engine leaks from the intake gasket, it's usually seen somehwere around 50 to 75k. By the way. The labor time (per Mitchell) shows 5 hours to do this job. 2 extra hours could mean the difference of $200 or more, depending on the shops rate.
My actual problem was with one of those Fram easy oil change plugs (where you remove the cap and screw on a special fitting w/tube connected. Once in place, the fitting automatically opens up and begins draining the oil. This fitting was leaking around rubber gasket. I had the shop replace it w/a regular oil plug and so far have had no more oil leaks. What a relief as just under a year ago I had to have the intake manifold gasket along with the head gasket replaced ($2200). I'm very happy when it's something simple like that. The price was $25 labor plus cost for Mobil 1 Synthetic oil and a Napa Gold Filter (I purchase these and asked the shop to use them, which they agreed to). So just an expensive oil change.
I would definitely take it in and hope it is just the intake manifold gasket and not something more (hopefully not head gasket). If you do it sooner than later, you may minimize the damage.
Other than the couple drops over night, the '99 van uses no oil at 104k miles.
If the dealership told her it was a sensor problem, they were likely deceiving her. You can read about this problem all over this forum, going back a number of years.
I have an oil leak in the front of the engine left side over the starter. The leak is only when the engine is running and is a solid stream ~ 3/16". It does not appear to be coming from the pressure sending unit. Does not appear to be coming from any gaskets or valve cover. Do the ventures have any exterior oil hoses, like to an oil cooler? Is the location of the oil pressure sending unit over the starter? It is very difficult to see exactly where it is coming from.
For your "audible whilst driving" noise, the sound might be coming from 2 different areas. The one area to check is its front wheel bearings. If wheel bearings are going, the front end while hum - while driving. The faster one drives, the louder the hum is. In some vehicles, sound travels under the vehicle and echos between its body and ground. Thus, the sound may "sound like" its coming from the engine area but it might be coming from under the engine. Being a Mechanic, I'm sure you know how to check for worn out wheel bearings.
The other area to check for "audible whilst driving" sound is the AC clutch. My previous 2000 Sunfire had a weird humming sound under its hood. Sometimes it would squeek and sometimes it would hum. Most of the time, it would hum. My local mechanic used a doctor's stephoscope (no kidding) and placed its sound pickup end of every engine part. Really cool to watch because he would say, "nope - not the water pump", "nope - not the idler pully", etc. etc. as he put the sound pickup end on every steel engine part. Finally, he nailed it. Found it was the bearings (steel sleeve) on the AC clutch assumbly that was gone.
If you can, try to use a doctor's stephoscope to hear that "sound under the hood" as well. Especially if you can hear the "audible whilst driving" sound while its tires are turning - while the vehicle is on blocks. And yes, do be very careful when turning tires - when the vehicle is on blocks.
Hope this helps as well.
OH and there are 2 check engine lights on these cars, one is for the oil change.
after i bought mine like 3 weeks after i had it the check engine light would come on stay on for about a couple hours the i noticed it really didn't have lots of power and when i give it gas it would act like it was bout to shut off so i brung it into my job we scan'd it for the fault codes and it came back as a dirty air filter....
got a new one and it still did the same thing so i did a re scan and it come back with the fault for a cyl misfire . ggrrrrrrrrrr .... then i sent it to team in vallejo come to find out it was a fuc*ing mass air flow sensor and now it runs like new after 500.00 .
************************* but *****************************
The check engine light will come on for the smallest things also.. as per:
Dirty Air filter
Loose Gas Cap
Low Coolant
Low Oil
i hope this was helpful for you
I just spent over 2 grand having the waterpump replaced, thermostat replaced, radiator replaced. Yesterday my husband had to pull off the hwy, because the van overheated & the engine shut off. When he opened the hood, he said there was water dripping out of 2 bolts/screws on top of the radiator. Does this mean it needs replacing again? Have had the van only a year and it has been in the shop like 4 times so far.
Thank You
Does anyone know the interchangeability of Venture engines? I would like to get a newer, lower mileage engine.
We had to change the tranny and engine at 114 000 km.
The engine could not even be rebuilt had to buy all new.
Good luck!
It all started about a month ago with a P0302 and a camshaft sensor fault codes.The van was running rough and barely stayed alive at idle. Long story short, I fought with it and replaced the CS sensor and spark plugs and wires.It ran fine for about 3 weeks until last week when it started with this Cylinder no. 5 misfire code.It is running like on 5 cyl. instead of 6, no backfire though.When I had the cyl. 2 misfire , just changing the spark plug seemed to make the difference.Unfortunately I would have to rotate the engine again to get to no.5.I remember I really made sure all plugs and wires on the back side were fitted perfectly, knowing that it would be tough getting to them again.
Today I checked the air filter and it was not blocked or dirty; also did a vacuum test and came up with perfect results, which is kind of weird considering how rough it's running...
Anybody have any ideas where I should go from here? Thanks in advance for any help...
Anyone got any ideas?
Get your cooling system flushed professionally. The over-the-counter flush is ok but will not get the gelled stuff unstuck. The DEX-COOL in these vans gel when it gets old.
I had to get my system flushed twice just to get all the coolant passages clear. This means changing your thermostat, inspecting your water pump and new/non-corrosive coolant.
FYI: open your themostat to heat the rear too. Opt for an aftermarket water pump when you replace, don't go for the like/factory water pump.
Flush your system or get the air out of the system.
Similiar thing happened to me. I changed the water pump and after filling the radiator up, I started the van and let it warm up for a while. When the temp guage started climbing again, I loosened the bleeder screw on the thermostat housing and waited until some of the coolant squirted out. I closed the screw and by the time I checked the temp guage, the temp was down to the normal spot. The guy at autozone told me that I had an air pocket in the system and the air got hotter than the coolant, thats why the guage was fluctuating
Also, if you want to go higher than $2,000, you can specify specific changes to the engine, like superior wearing parts, or a performance boost (which I would not recommend unless you also re-build and upgrade the transmission).
What was most interesting was the engine was almost as clean as the day it was built. I used Mobil 1 synthetic 5x30 oil. I also inspected the crankshaft and rod bearings and they were okay. I did not pull the heads (leave well enough alone).
I did NOT change the lifters as they seemed to be okay. In otherwords there was no obvious wear or damage on them and when I pushed down on them, they held pressure. One of them was a bit suspicious, but after soaking it in oil, it pumped up.
The engine now seems to run quieter and I feel confident it should see me for another couple of years.
This engine also has what is called "piston slap" which mimics the lifter sound. Chevy says it is not a problem. It is found on several GM engines to include new 454 V8s. A design problem where the skirt of the piston hits the side of the cylinder wall and makes noise. If the noise you hear goes away within a few minutes during warmup it could be the slap, but DO NOT count on it. Chevy may say it is okay, but I would like to see if a Chevy executive drives one with that noise!!! A neighbor of mine had a new 2000 Chevy/GMC big dually truck with the noise and it drove him crazy.
So what would I advise? First, if you have high miles (75k++, then you should expect to make some repairs. Second, are you using any coolant? That is a symptom that the intake and/or cylinder head gaskets are leaking. This is almost guaranteed to happen on this engine. Mine went out at 115k (previous owner took the hit). It allows anti-freeze to get into the oil and start to ruin the bearings. It may have ruined my cam bearings. You may have a problem checking the coolant level since it is read at the coolant recovery tank on the driver side of the engine. Most of the tanks are filthy dirty so you can't see the level. It comes off real easy. Clean it out and refill. Mine was filthy and it looked okay from the outside.
Next, when was the last time you changed anti-freeze? GM dexcool turns to mud if not cleaned periodically. GM says 5 years. That is a stretch. Take off the radiator cap and look at it. If it looks like it has chocolate on it, it means your anti-freeze is gone and should be flushed out (to include heater cores). In reading the internet, NO ONE likes dexcool. I took the advice of some and went back to good old green anti-freeze. GMC says it will only work for 2 years. There is a lot of data that seems to support that dexcool eats gaskets causing problems. GMC says it is lack of maintenance and not dexcool. It is your guess, but if you see dirty dexcool you will not be impressed. I never had that problem with old green.
So do you take your chances with a noise and metal shavings? You are probably looking at $3000 to rebuild the engine (not at GMC dealer) and maybe $2000 to pull the engine, tear it down like I did and fix what can be fixed short of a rebuild. The cost of an engine rebuild parts kit is about $800 and that does not include cams and lifters. So the cost of labor is not that unreasonable.
If you run it till it goes. At least use synthetic oil 5 x30, change the anti-freeze NOW (and flush the old), get the coolant system pressure checked.
Any suggestions?
Thanks, Gwen
