Honda Odyssey vibration
I have a 2006 Odyssey ex cloth. The van has 550 miles on it. The vibration has been there since mile #1. I just had the van serviced at Rick Case Honda in Ft. Lauderdale. While I was there, another woman that had a 2005 ex leather was there for the 6th time for vibration. One of my best friends has a 2006 exl-dvd and he has the same problem. This has nothing to do with wheel balancing. After rick case gave me back the vehicle it rode worse at low speeds and slightly better at high speeds. My buddy stayed with the shop manager for 4 hours today. They feel that the tires themselves are the problem. While going 50 mph and light gas the problem is real bad. I let off on the gas at this speed and the problem almost disappeared. This leads me to think that this is a transmission problem or axel problem. Anyone else out there feel this vibration (seat of your pants, not steering wheel) please post here!
Honda will probably tell you it is a "normal operating characteristic of the vehicle" even though you did not buy it with the defect. They will tell you that cars break-in & exhibit certain characteristics such as supsension noises, rattles, creaks, exhuast noises, etc.
I tried to settle with Honda with a trade my '06 for an '07 & I pay $3,000. They refused. So we are taking the case to court.
This outcome surprised me since Honda always honored their commitment to customer satisfaction, reliability, & quality with my prior 2 Hondas.
I guess since their quality has slipped so much over the years they are spending too much fixing defects.
Did you see the latest class action lawsuit against Honda? Defective transmissions in '99-'03 V6 Honda & Acuras.
The Ody, for maximizing fuel economy has transmission that shifts up into the tallest gear whenever possible (light throttle, medium speed) and the torque converter locks (again normal, designed to do this) to limit slipping and maximize effeciency.
At the lower rpm, there is vibration that I feel in the 45/50 mph all the way up to about 70 mph. Yep, when you lift throttle it is gone. I typically drive 75-80 on the freeway with ours so it doesn't bug me alot on long trips, but the vibration really bugs me otherwise.
Is that consistent with others experience. Those with the loaded models apparently have some active noise cancelation technology in the audio system - maybe that is Honda's way of dealing with it.
I plan to talk to the dealer about it and see if they have had complaints there or if they have done anything different on the '06 - seems like a simple chip reprogramming could make that lock up less agressive.
Anyway, some of the Odys could have exhaust's A pipe resonant problem at engine speed of 2100-2300 RPM. So that could be 30-40 MPH around town or 65-70 MPH on highway. It feels and sounds like transmission is in the wrong gear. But it is mere exhaust pipe resonating: no mechanical problem with engine or transmission.
jt
Is the noise constant or does it vibrate when you push the gas pedal?
Possible causes:
1. If the noise is constant then might be bad wheel bearing(s).
2. If it occurs when accelerating around 55mph then it could be the transmission "lugging". Lugging occurs when the transmission is in overdrive at a very low rpm. This is normal to an extent. If it lugs hard then the vibration is transmitted through the engine mounts.
3. Bad engine mounts? Does the engine shake when idling?
The only significant problems that I've heard of on the '99-'04 Odyssey is transmission problems. Mostly the '00 & '01 with the 4-speed trans (there is a class action suit). There were failures on the '02+ 5 speeds but not as frequent.
Hang in there...consider yourself lucky to have an '04. The new '05+ Odys have several design defects that cannot be fixed...the worst being the drone defect & bad engine mount designs.
The other problems are defective motor mounts that causes a vibrationa when the engine is at certain RPMs.The last is an exhaust pipe that emits that droning noise.
I have one of the first '05 Touring and have spent lots of time negoiating with the dealer(s).Honda definitely does not like to admit there are problems with this van.
I'm thinking of keeping it has a around town car because it is so handy and get a Saturn Outlook for those vacations. The outlook is just as roomy and versatile and uses nicer materials and leather, not to mention it is AWD and I suspect will be just as fuel efficient as the Odyssey.
I don't expect reliability to be as good as Honda, but this new car would really have to stink to even approach the Odyssey touring.
I think honda is going to lose market share to this new crossover segment, especially since the American nameplates don't treat their customers like idiots--which I've experienced with Honda.
What kinds of issues should I expect?
jojobird
I Have 2005 Ody LX-L with VCM with the same issue. Was in dealership in Rockford, IL 4 times (dealership seams to be nice and attentive, but they get no help from Honda except replace this or that). Initallly power steering pump was replaced (was making noise too), but it didn't get rid of main humming-vibration which occures at 1600 and 2100 RPM's (since it is on certain freequencies, I shall call it RESONANCE). Then parts of exaust maniflold and tail pipe were changed - no effect.So I called honda Customer service (I would say customer ditch off) talked with regional manager whose name is Julie Kim - who is completely incompetent in mechanics or physics - probably has degree in political science or liberal arts - zero understanding of the mechanical problem, but great in ditching people off. Requested to give extended warranty since resonance is known to damage things - they don't care. THEY DON'T CARE - even though I own two new Hondas and told that they can loose customer forever. Now I am requesting written statement that sounds and vibrations at certain freequencies (resonance) are usual sounds made by Honda cars, and I shall not give up until I'll get it.
Othervise I like Hondas for their stiffer suspencion and ride, but really not happy with CS.
I have droning sounds on my 2005 LX-L. THIS IS STRUCTURAL ENGINEERING DEFECT due to resonance. It occures at 1500-1600 and 2000-2100 RPM especially whem more torque is needed (acceleration, uphill climbing). It will not go away until Honda will change engine mounts or other unknown to me (probably to them too) parts. Changing A pipe reduces the sound, but A-pipe failure is due to the resonance and will happen again and again. The resonance is well known to damage and destroy things. Honda probably doesnt care about it, since damage occures way beyond warranty to other parts (already had power steering pump replaced as well as brakes) probably transmission and other parts.
People, if you in search of new minivan DO NOT BUY HONDA ODYSSEY LX-L (leather with cylinder managment) or Touring - it will give you trouble in future, unless Honda acknowledges the problem and shall fix it. Meanwhile it should give extended warranty on these cars for free as a courtesy and acknowledgment of destructive resonance -humming, vibration.
Service Bulletin 06-083
December 1, 2006
Applies To: 2005–06 Odyssey EX-L – ALL
2005–06 Odyssey Touring – ALL
Excessive Engine Vibration at Idle or Below 2,100 RPM
SYMPTOM
The engine vibrates excessively at idle or, under load,
up to about 2,100 rpm.
PROBABLE CAUSE
The rubber inside the rear engine mount is torn.
CORRECTIVE ACTION
Replace the rear engine mount and its mounting bolts.
PARTS INFORMATION
Rear Engine Mount:
P/N 50810-SHJ-A62, H/C 8485906
Rear Engine Mount Bolt, 10 x 35:
P/N 90163-SDA-A01, H/C 7151350
Rear Engine Mount Bolt, 10 x 20 (four required):
P/N 90163-S5A-000, H/C 6462931
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Operation Number: 1121C3
Flat Rate Time: 1.0 hour
Failed Part: P/N 50810-SHJ-A61
H/C 7813967
Defect Code: 02101
Symptom Code: 04505
Template ID: 06-083A
Skill Level: Repair Technician
Out of warranty: Any repair performed after warranty
expiration may be eligible for goodwill consideration by
the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a
decision, before starting work.DIAGNOSIS
1. Raise the vehicle on a lift.
2. Using a .610 mm (.024 inch) feeler gauge, check
for clearance between the rear engine mount’s
rubber bumper and its bracket. Also check the
shape of the rear engine mount.
• If you can’t get the feeler gauge to slide through
the entire length of the rubber bumper and the
engine mount bulges out (is shaped like a donut),
go to REPAIR PROCEDURE.
• If the feeler gauge slides through the entire
length of the rubber bumper and the engine
mount looks slightly deflated, this service bulletin
does not apply. Continue with normal
troubleshooting to find the cause of the engine
vibration.
Engine mount
bulges out.
Feeler gauge will not
slide between the
bumper and bracket.
REPAIR PROCEDURE
1. Take weight off the rear engine mount by
supporting the transmission with a screw jack.
2. Disconnect the connector from the rear ACM
(active control engine mount) actuator.
3. Remove the rear engine mount stop (two nuts) and
the rear engine mount (five bolts).
4. Using five new bolts, install a new rear engine
mount in the reverse order of removal.
NOTE:
• Torque the new rear engine mount bolts to
54 N.m (40 lb-ft).
• Torque the engine mount stop nuts to
73 N.m (54 lb-ft).
5. With the screw jack removed, make sure the
exhaust pipe A bracket is centered in its rubber
mount. If needed, center the bracket by tapping it
with a hammer.
NOTE: Step 5 is not needed if the vehicle was
already repaired according to Service Bulletin
06-050, Droan or Moan When Driving at 2,100
RPM.
I also have the droning noise between 47 and 52 mph. Was told by Honda that it's normal.
You can also feel every downshift of the transmission as well. (45mph..35mph.. 25 mph 15 mph until the vehicle stops) I now shift it in neutral when cruising to a stop so I don't feel the annoying down shifting.
How about spongie brakes??? The pedal nearly goes to the floor when stopping. (again, Honda says it's normal)
As you can probably tell, I am very disappointed in this van. This is my 6th Honda purchase and you can bet my last!!
The vibration seems to occur every time the transmission drops into 5th and you remain at a steady speed/load at 1500rpm.
There is also a slight engine shake when in park at idle all the time regardless of temperature.
The transmission seems a little harsh when downshifting, it seems to hesitate and then drop into gear causing the vehicle to jerk slightly.
Can anyone comment on these concerns? Have other 2008 Odyssey owners experienced the same issues and is the a fix I can pass onto my dealer as it has been in 3 times with NO PROBLEM FOUND.
BTW this is good for a laugh, I contacted the former owner of this vehicle asking what they knew about this vibration, and they told me that the dealer told them they should always drive with overdrive off. Their gas mileage must have sucked.
Just trying to gather some ammunition before I take this van in. If they don't drive it right they may not feel this vibration at the dealer.
I have the extended warranty too but I'm not even to 30k yet. At least if they have to replace the tranny I will get rental car reimbursement with the extended warranty.
http://www.in.honda.com/Rjanisis/pubs/SB/A04-066.PDF
http://www.in.honda.com/Rjanisis/pubs/TS/ATS050605.PDF
Refer to these Honda Service News for a 5 part article series on Excessive Steering Wheel Shimmy and Chassis Vibration:
Part 1 of 5
http://www.in.honda.com/Rjanisis/pubs/SN/A071000.PDF
Part 2 of 5
http://www.in.honda.com/Rjanisis/pubs/SN/A071100.PDF
Part 3 of 5
http://www.in.honda.com/Rjanisis/pubs/SN/A071200.PDF
Part 4 of 5
http://www.in.honda.com/Rjanisis/pubs/SN/A080100.PDF
Part 5 of 5
http://www.in.honda.com/Rjanisis/pubs/SN/A080200.PDF
Good Luck!
I also have a 2005 Odyssey EXL and am experiencing the same shudder / vibration when gently accelerating at 1500 - 1800 RPM in the 35 - 40 MPH range. After reading these threads, I called the dealership and told them others have experienced this and they found it to be the torque converter. The dealership said the Check Engine light should be on. Mine is not. Did your check engine light go on when the shudder / vibration occurred? I don't have an extended warranty and have over 70,000 miles on mine so I'm trying to get Honda corporate to cover but the dealership said the Check Engine and its accompanying code would be needed to get corporate to cover.
I will be taking it soon and I will let you know if they diagnose it as the torque converter. This would be good evidence for you if they do diagnose it as torque converter. If so I will try to get them to document that the check engine light was not on and I will send you a copy.
Later I experiened a "shudder" in the 20-30 mph range... after being in a gentle cruise and applying a slight load to the engine (pretty sure ECO is active) the reduced power and lower gear cannot deliver the needed torque - so a rapid shudder develops until all cylinders kick it. Felt like misife, or driving over a washboard - a second or two and the shudder is gone but there is still a definite vibration from the engine.
Had the plugs and the transmission fluid changed with zero improvement.
Had a transmission guy test drive it - car acted up beautifully - but he didn't believe it was transmission since the vibration is apparent at stand still - get the vibration looked at.
Test drove it with a Honda mechanic on board - couldn't make the car act up - but he did notice the vibration - also said he has a current complaint from 1 other Odyssey owner but does not yet have a solution. He suspects it could be an issue with the electronics / VCM program.
Took the car on a long hwy trip yesterday - car runs better at hwy speed but that is because the symptoms less apparent. Its amazing how often the vehicle is in ECO mode - with cruise on I could feel an engine vibration - then given the right uphill grade (slight load on the enginer) the vibration would drop and I noticed every time that the ECO light would turn off within a half second. Seems to me that the VCM program is messed up - as is regular ignition since it is not like it used to be. I have no fault codes. Perhaps if the computer is sending bad instructions - then it doesnt have the right info to create a fault code. A few more days of shudder and I'll be going back to Honda -or maybe future shop to buy Norton antivirus :confuse:
We all have the same problem. You both have described the issue and conditions in which we get the shudder / riding over washboard feeling under light acceleration in the 1500 - 1800 RPM range between 30 - 40 MPH, up a slight grade. Won't happen going down a slight grade. You both have a 2005 EX-L right? I have 71,000 miles on mine.
I went to the dealership today and had a mechanic ride with me...guess what??? IT DIDN'T HAPPEN! How frustrating is that? So the service manager said to leave the car and they'll have a tech take it out a few times. I didn't want them tearing the car apart to diagnose, because they "have never heard of this issue". That would cost me $$$. He said he would go to bat for me with Honda corporate if it is the transmission...My question is if this is a transmission problem, is this just a nuisance or will the car fail at some point?
If it was transmission the symptom would be the same in normal mode as in ECO mode - also the transmission service tech who drove my car did not think transmission was the cause - not to mention that transmission slip would generate a fault code. To me its like a timing issue - and since there is no timing - only a program, I think its computer related. It wouldn't be the first time a computer needed to get replaced on a car. The other thought is that the hardware devices (whatever they may be) which are used to control the VCM are faulty.
On the way home I got a call from American Honda on my cell. They said that they opened up a folder on my car and were going to send me to the dealer that I just left. What's that about? If they didn't know that I was just there why did they call my cell? I called my wife at home and they hadn't called my home phone.
American Honda suggested that I ask the original dealer to schedule a test ride with their factory rep. which is supposedly on the property once a month.
My opinion is that they don't want to do anything about the problem. I only bought this car six weeks ago and it only has 3000 miles on it. I have to drive it for at least five years hating the way it drives. Also, I feel compelled to buy an extended warranty now. With this vibration something has to fail eventually.
