Do you feel the pulsing on the brake pedal at highway speed when braking? If so, likely culprit would be the front rotors, or at least one of them. :confuse:
Just make sure it doesn't cause an overfill of the trans fluid, and I would highly recommend having a shop flush and refill, adding the shudder fix if that's the route you wish to take. I'd probably have done that if mine wasn't under warranty.
My 07 is one week back on the road and still running like new, post new torque converter.
BTW - he did admit they have had to do several of these...
Apparently this is a much more common problem than Honda will admit to the public. They're fixing all of them that report the vibrations, and had (when mine was done) a shortage of replacement torque converters. Honda should issue a recall but won't, it would blemish their reliability record. It took my dealer several days to get the part, and the better part of two days to fix it. They also have to remove some of the front suspension to get to it so the job includes a total alignment when done.
Sorry I couldn't be more help.
It ended up being my crank shaft pulley. The only way the mechanic found it was because it finally broke right after I pulled out of the lot.
Now, if I could only get Honda to admit that the 2005s also have a torque converter issue and help me fix it. I don't have $2K to fix it and the shuddering is getting worse.
I've explained to the service mgr, "So you're telling me that for a 4yr old Honda with 65K miles, $2,500 in repairs is normal?" (crank shaft and torque converter) Ridiculous.
If for some reason they turn you down, I would get a quote from a reliable local mechanic. I bet the price would be considerably lower than the dealership. Good luck.
I owned the 2007 Odessey EX. The mileage is 37k now. After replacing the torque converter and the software updated by the local dealership, i can feel the vibration is still going on at the certain speed 40-50 mph. After one week from the car was diagnosis, I drove back to the dealer to complain the problem. The service manager department took a short driving test, and he said everything was normal. This is very disappointed me. I can feel the engine is shudder onto my feet @ speed 40-50 mph. I will try to bring my van to different honda dealer to see what they are saying.
Anyone here has the same problem, please share it with us.
Did I tell you this will be my last Honda?. I will finish my lease and get NISSAN or TOYOTA and NEVER BUY HONDA AGAIN.
I am wondering if all of these problems are because the Honda Odyssey is made in the USA. Does anyone have one made in Japan> Does it have the same problems?
i was dealing with same issues. tc was replaced, which got rid of the judder. the vibration never went away. it happens when the van goes into overdrive and you lightly accelerate. it happend at approximately 30 mph, from 48-52 mph and then again at speeds above 70 mph. the dealer acknowledge it and they tried neutralizing the motor mounts. didn't help. we were sick of dealing with the issue so we traded the van in for a subaru forester and bit the bullet on the lost.
hopefully they get your issue resolved. we could have pushed the dealer to do more but i hated going to the dealer every week. good luck with yours.
They said they configure the software for vibration issue and adjusted the driver side passenger sliding door due to rattling sound.
Rattling sound disappeared BUT, the vibration became much worst. Before it vibrates at 45-55mph speed. Now, I won another vibration. 2X vibration at 25-35mph speed. I asked to get rid of vibration but instead gave me another vibration. (Buy one take one)
They may adjusted the software and that's it. Not even bother to test drive before calling me back the it is ready. Now I have to file a day off again to bring back this CHEAP HONDA ODYSSEY.....I should have gotten TOYOTA.
I WILL NEVER EVER EVER EVER BUY HONDA AGAIN.
I alraedy raplaced a transmission torques converter.
Still I have the same problem.
I reported this issue to BBB.
I contacted a consumer lawyer too.
I have worked with machines all my life (I'm now 70) and I think I "know" when something is not right. Sure enough - it has gotten progressively worse and when I complained again last week I was told about bulletin 09-053 describing a "judder" from the torque converter lock-up clutch. They complied with the directive to do a PCM A/T software update.
The net result was that the judder is now worse - to the degree that I notice the low speed variation now. It is no longer subtle. My wife had the vehicle all day today and reported to me this evening that the high speed variation is more noticeable too! It reminds me of the chatter that my first car had when starting out in first gear. It was a 1947 Ford and I installed a chatter bar that took care of the problem. Oh, if only the Odyssey fix were that simple!
My dealer, Honda of Ocala, is being very cooperative - the torque converter will be replaced. What concerns me is that this is a design problem and that it will eventually come back in spite of the new part. Sadly, there are people out there who are "living with" the problem because they have not been informed about it. But, to Honda's credit, they seem to be doing a better job than Saturn did with their infamous VTi transmission. I'm still burned over that one and will never buy another GM product as a consequence of the way Saturn has handled it. I'm sorry that they have failed but if their handling of the VTi is an indication of their philosophy - they asked for it.
Another concern I have is the motor mount issue which can also cause vibrations. I will be insisting that the mounts be thoroughly inspected.
I will post the outcome of the torque converter replacement which is scheduled for 12-16-2009 providing the part has arrived by then.
I will let you know guys the result.
Had it in to the dealer today, and they confirmed I need to have the torque converter replaced to address the first two items, and the clunk is due to a loose or broken engine mount. Parts on order - will take 1-2 days to repair next month. Will report back.... I must say, after having owned probably 5 or 6 Hondas, this is the most serious issue I've ever experienced, by far.
I keep you guys posted.
When I purchased the car I was a little nervous because I believe it was the first year they offered the Econo mode on the engine. I am wondering if it is related to this feature of the engine since it feels like the engine is skipping not trying to change gears.
If anyone hears about a recall or what the fix is please let me know. We are living overseas in the military right now and return to the US this summer. I will probably have to wait and have a dealership check it out when I return.
The TSB: http://www.in.honda.com/Rjanisis/pubs/SB/A09-053.PDF
A reference list of TSBs: http://www.odyclub.com/forums/showthread.php?s=&threadid=46072
will probibally be supplied or required by the tranny supplier. I have an 07, had the judder problem since 5,000 miles. Had the recall done, converter replaced, judder started again within 50 miles of dealership after taking delivery of the :lemon: vehicle. Have turned it over to lemon attorney.
