You said your dealer pulled out the bulletin that ssaid the torque converter needed to be repladed? Could you please share the bulletin information with us?
See post 188: http://townhall-talk.edmunds.com/direct/view/.f1085e1/187#MSG187
http://www.in.honda.com/Rjanisis/pubs/SB/A09-053.PDF
Thank you to the people at Martin Honda of Newark, DE. They did a GREAT job!
We have a 2008 H.O. EXL. 29000 miles. Just 2 weeks ago the engine light came on and the VSA light. The car started to shake and vibrate and also felt like something in the gas...not flowing thru properly to the engine???? Sorry I dont know anything about cars.
The biggest problem is that we are military overseas( Italy). There is a Honda dealer that I went last week. He hooked the car up the computer and said I have water in my gas tank....that's why the car was shaking and vibrating. When I drive it and try to accelerate sometime the car starts shaking and no matter how hard I am pushing the gas pedal its just slows down and shakes. Anyway. we live on the military base and we have an Autoport where they fix your car, so I took it thinking its the bad gas. They emptied my gas tank, washed it out. Also they hooked up the car to their computer and it said...I need new spark plugs and ignition coils!!! ????
I am so confused now after reading all these posts about torque converter???
Can the computer tell you exactly what is wrong with your car?
Unfortunately the Honda dealer here in Italy doesn't even have the parts for Odyssey...and I called honda about the warranty but they were not helpful at all.
I am kind of lost here..... any ideas?
If you indeed had water in your gas you most likely still have water trapped somewhere. If it was my car I would try and add some gas dryer. If you can't find any there I would add some isopropyl alcohol to the tank as this is the main ingredient in most of the gas dryers. Be careful that you don't add regular rubbing alcohol as it is usually 70% alcohol and the rest is water but you can find 90% rubbing alcohol here in the US. Make sure it's isopropyl alcohol (also know as isopropanol) and nothing else. The alcohol mixes with whatever water it finds and suspends it in the gas and then it's carried through. You could add about two cups to a tank of gas.
BTW - Where are you based in Italy?
We are in Naples Italy.
And you have to be careful where you buy your gas at. We went to this mini gas station in town and since than we are having problems. Usually we buy gas from big stations on the highway like Agip. But you never know here.
This car is very sensitive to these things.
I am still kind of shocked that the ignition coils went bad after just only 29000 miles....????
thanks yes I bought that water dryer liquid and we will see. The car still shaking though.
thanks so much for your answer
Ignition coils? Spark plugs? I DONT KNOW.....driving me crazy...this car.
I guess its between the dealer here and Honda Corp.Usa.
Hopefully we don't have to pay anything since the car is under warranty.
We have only driven it a little over 1000 miles since the repair. The slow speed chatter (or judder) is gone but the irritating indecisive jerking between 55 and 60 mph has persisted from the "get-go." I suspect that there is a real engineering/design issue with the torque converter and that it will become a monster for Honda as the months go by and people get more and more miles on their Odysseys. I don't think it will go away unless they come up with some compatible redesign and large-scale replacement which would be very costly. If they don't, I think they will lose a lot of customers just as Saturn did over their VTi (constant velocity) transmission.
I am totally satisfied with the efforts on the part of my dealer to fix the problem, now that I'm no longer being told that "It's just a characteristic of the vehicle" but I do not have the confidence to keep this vehicle much longer and because of this and other engineering and design decisions that Honda has made over the last few years, this could very well be the end of Honda being in my family. I bought my daughter a new Civic when she graduated from college and had expected to do the same for my son when he graduates but the brand may change. I think Honda really screwed up with the design of the 4-door Accord (and surprised a lot of people when it came out far removed from the prototypes we had been seeing) and the new CrossTour (I think that's what it's called) misses the mark too - in my opinion.
Because of the negative feelings (and the rational fear of a retired man on a modest fixed income) generated over this experience with such an expensive vehicle (the Odyssey) I intend to talk to my dealer to assess their attitude about future problems of the type I've been having. I will report to this forum once that happens.
Safe Driving!
Cloudman23
I also had the judder issue and a broken front engine mount on my 2007 Ody (with 22,000 miles). I have owned something like 6 Hondas and have never seriously considered a different brand. This experience with this Ody, though, is causing me to have serious concerns. I have never experienced any technical issue anywhere near this severe with a Honda. On my 90 Acura, I think I changed the oil regularly and other scheduled maintenance, and that was it for 130K miles. I didn't even have to change the clutch on that manual 5-speed. When I talked with my mechanic about selling it, he said it was still a "pup" and would likely go 300K.
I just had the engine mount and torque converter replaced on my 07 Ody on Friday. The judder at 30-40 mph is definitely gone, which is great, because it was worsening fast and was very, very annoying. However, in general, I am leery of the behavior of the transmission. Of course, I only have a sample size of one, but it just does not feel to me like it is behaving smoothly and with confidence. I never felt this way for the first two years of ownership. Perhaps it is psychological on my part, but it just doesn't seem "right".
I had a discussion with the service advisor expressing my concerns about this being an inherent issue that, for all I knew, would recur in another 22K miles. He did his best to assure me that this was not something they see a lot of, and while serious and major, I should not presume that there was an increased likelihood of recurrence. I appreciate his position, but I am in a quandry because my confidence has been shaken. My wife and I are pretty conservative drivers and our vehicles typically last a long time because of it. As I told the service advisor, "it's not like we're going off-roading with the thing."
At the moment I am considering purchasing the extended warranty as a hedge, and as a less expensive alternative to swapping to another vehicle. When we got the 07, it was a trade-up from an 01 Ody, and it was my hope that the 07 would last 7+ years easily. Now I am not so sure.
We are now contacting Honda and hopefully they will fix it.
This is the first that i have heard it could be in the converter.
We will be calling the dealer and see what they say. :mad: :mad: :mad:
The first step is to re-program the ECM/PCM then when that doesn't fix it replace the torque converter. Usually just the re-program is not enough..
Also for others this vibration would be had to confuse with a wheel balance or brake issue as it feels more like a engine misfire or clutch chatter.
I can get rid of the vibration (feels like you're driving on a washboard) by turning off the overdrive. At 80KMH I can feel it the most and turning off and on the overdrive will turn off and on the vibration. On a slight incline I have the same vibration at about 60 KMH. This was verified by the HONDA mechanic who said to me it was the transmission trying to find the right gear. He had suggested that I turn off the overdrive. There was a 2009 courtesy Odyssey that we test drove and it had the same condition. In the end, he said this was not the judder noted in the TSB calling for a program or torque converter change.
Now I have the same droning noise when I have a "cold" start and it lasts for a few minutes. Do you have the same issue, that it is temporary?
So far I have BS from CSR and Case Manager who tell me this is a "normal" operating characteristic of the vehicle. Obviously if I can turn on and off the vibration by turning on and off the overdrive, it tells me there is a direct link or cause, especially if the HONDA tech tells me the transmission is trying to find the right gear. The game that is played is the dealership cannot replace parts if they cannot root cause the issue properly as HONDA will not compensate them if it doesn't fix the issue. I know this as I initially had the vibration issue and they re-balanced the tires. Issue is still there and they have not sent me my "work" order. They told me once HONDA gives approval for the dealership, I'll get the work order. So if there is no TSB (or product update), they may not get compensated for work done if it does not solve the issue.
I'll be escalating this issue to the next level. Anyone else have the same issue.
Same senerio as all the 2005-2010 models. Honda is still not being honest about the issue. Insist the dealer do a snap shot diagnosis. 99% they will find a defective torque converter. My 2007 is now pending arbitration. My symptoms started with the exhaust droan at about 5,000 miled on the odometer. Suggestion! set your average fuel economy meter to zero while on the interstate. You fuel economy shoud show 25-26 mpg. If it indicates below 22 mpg then your torgue converter is not engageing which is what gives you overdrive for fuel economy. Had the recall done about 60 days ago. Vehicle made it about 40 mile before failing again after picking vehicle up from dearler service dept. When you disengage the overdrive you are changeing the engine rpm which compensates for the shudder and also partially disengages the torque converter. I am seeing that this issue is extending into the 2010 model odysseys. I own two hondas. This will be my last.
This issue extends into the Acura line also.
I own 3 Hondas, and my 06 Odyssey will be my last Honda too. I have all the problems people talked about here on this forum. You mentioned that you had the recall done 60 days ago, would you mind telling me what recall you were refering to?
The droning noise you are hearing in cold temperatures may be unrelated. If the noise is coming from the front it could be the power steering reservoir. There is a known problem where air can enter the power steering system. The fix is to replace the power steering reservoir. You may want to have your dealer check this out.
It's not a true NTSA recall but a TSB (technical service bulletin) issued by honda. Involves reprogramming the PCM ( powertrain control module ) which is supposed to control the shift points of the transmission. However the converter is controlled hydrolically by timing valves so I don't know why Honda would think that reprogramming the PCM would fix the torque converter shudder. The proceedure is first reprogram the PCM, If that doesn't stop the shudder then teplace the torque converter which is not correcting the problem either. You should get a notice in the mail, however I did not receive one either. Bad thing is, a lot of owners are not experienceing the shudder issue until after the PCM is reprogramed.
4grandsons:
The exhaust droan is a precurser to and created by the torque converter shudder. Makes the exhaust system vibrate like a guitar string. (resonance)
Fix the transmission the droaning will be eliminated also.
