Uh no, I have to have kids or wife change time on radio when its needed
One quick question, was the other key fob nearby first thing this morning and getting driver 1 mixed up with driver 2?
Thanks Ray80
A few days later I noticed when I would reach over 65 MPH I would get a sound from the rear like a muffler going bad. My muffler is fine, I have new tires and I have rotated the tires. I noticed it went away when the weather got warmer, and not the the cold is back I hear it again.
Todd
I have had all of my wheel bearing checked. I have a AWD.
Good Luck
Did you look and look and look and you couldn't find the leak like me? How did you come to the conclusion that it was the thermostat? On your own-or did you have to take it to a mechanic?
Nancy
Garnish molding removal procedure ( A pillar mouldings)
1) remove the windshield garnish molding from the windshield pillar by pulling the windshield garnish back to release the two push -in retainers.
upper trim pad replacement for dash
1) FYI ! remove the upper trim pad slowly, the retainer clips could possibly fall into the instrument panel.
2) lift the instrument panel, upper trim panel approximately 51 mm ( 2 in) and pull rearward to release the retainers.
3) remove the DRL ambient light sensor by twisting it 1/4 turn counterclockwise
Anyone else experienced this?
Now 2 hours earlier I was driving on some lovely snow covered residential street, do you think this could just have been my vehicle proteting itself from not being ruined in some way?
1. Will be driving or parked and all of the dash lights and head lights will go out for a second and then come back on. The engine has never lost power, but my wife told me it did for the first time the other night. Any suggestions?
2. The traction control service light and dash ABS light will sometimes come on and stay on until the car is shut off and restarted. Then it will be good for a while.
I will be checking the cable between the battery and under hood fuse box and the wet carpet behind the driver's seat as suggested in some other postings I read. If there are any other suggestions, let me know.
(just remember to pay attention to the ding when you shut it off that is trying to tell you you left the lights on
For the TC/ABS thing, if you took it to dealer and had it scanned it would most likely suggest replacing a hub bearing assembly, but many many times it is more likely (as our vehicles age) a wireing thing (broken/corroded connection) most often but not always the connection at the hub/bearing assembly. I would suggest looking at the other topics with ABS/TC/AWD disabled title in both the Aztek and Vous forums here at Edmunds to find other causes and locations for this problem. .
The problem could be your ignition system. The experts here may be better able to help you out if you could provide a little more detail about the symptoms. E.g., when you say your Aztek won't start does the engine turn over? Do you hear anything? Do you hear clicking noises? Do you smell gasoline?
SUVs and Smart Shopper
I have looked in my manual....not much helpful info there. I have had my father in law search for it...no luck. Is it hiding or am I one of those lucky people who got a vehicle (in Alberta to boot) that does not have one...
Any help would be greatly appreciated.
I'm not sure what the labor would be, but you can buy block heaters in the states from around $35 USD and up.
