From the service manual
1) Remove and reposition the underhood electrical center.
2) Remove the front end sheet metal diagonal brace.
3) Remove the battery ground cable
4) Remove the battery positive cable
5) Remove the battery hold down retainer
6) Remove the battery
7) Remove the battery insulator from the battery.
Another person said they changed theirs by only removing the brace and carefully inching the battery out, barely enough room. Another hint: while out buying battery, also buy bottle of iodine to take care of any scrapes that are likely to occur
I own a 2001 Aztek and for the most part we are pleased.
Problem #1, the tailgate will not open at all, either from the lever inside or the keypad. When you press the keypad you can hear the lock "working" but the tailgate will still not open. I am a good/average mechanic but I don't see a way to access the lock with the tailgate closed?
Problem #2, What is the proper method to reset the "Service Engine Soon" light for this model?
Thank you in advance
Joel
Really...so why do they have to make replacing a simple bulb so difficult...is there something I'm missing in my effort to do so?
From what I can see there are only two screws holding the entire lamp assembly in place. They are located in the gutter/trough that the hatch back seats in when it is in the closed position. I removed both screws only to find minimal play/movement in the assembly. I'm thinking that perhaps there is some hidden tab that the assembly hinges on but I hesitate to pull on it for fear of breaking the entire lens/assembly.
Has anyone ever personally replaced a brake lamp on an Aztek? What's the big secret to doing it?
#2 Do you know wgy SES light is on? If its just loose, corooked, bad seal on gas cap, it should go off by itself after problem is corrected and it comes through a few startup/shutoff cycles. If its something else , some places (such as auto-zone) can scan and perhaps reset it for free.
SES light came on when my fuel pump wiring completely burnt up!! A local shop wanted $3000.00 to repair. I bought one at a junkyard, pulled it myself off of the car, repaired and everything went fine. I will try the gas cap fix as I have heard that before.
The lens assembly did finally come off, but it took quite a bit more than a gentle tug. Fortunately everything is still intact, the lamps are working, but most importantly the wife is happy and doesn't have anything to chirp about.
Thanks Again.
1. Open the rear doors and remove the rear seats
2. Remove the tailgate inner trim panel by carefully inserting a tool similar to GM's J38778 interior garnish trim remover tool. There is not a great deal of room around the trim panel, so it may be best to start in one corner and carefully work your way around with the tool using the same procedure as with the side door trim panels. You may have to replace some of the plastic retainers if they break.
3. Once the trim panel has been removed, you will see two cables (one for each latch) coming from the center of the tailgate toward the liftglass latches). To release the liftglass, pull the manual release cables on both liftglass to release both latches. (Sorry no picture available)
4. Then you should be able to release the liftglass and drop the tailgate. You should be able to leave that panel off and close the tailgate as you normally would. You can reopen it by pulling on the cables.
5. Reassembly, replace any broken retainers and press the inner tailgate panel on to the tailgate.
You may be able to use putty knife or something simliar in place of 'official' tool, perhaps wrapped with tape to prevent maring pf plastic. You could also try pressing liftgate closed (don't break it) to see if it helps with getting it released (saw one person having 'stuck' gate from no closing it hard eneough) good luck
Just wanted to bring to the attention of those with liftgate problems. There are two rubber, spring-loaded bumpers attached to the underside of the hatch on the sides. They push the liftgate up when the latch is activated, whether it's with the dash switch, key, or fob switch. They can be adjusted by turning them outward to give more tension and force to pop the hatch far enough to release totally from the latch. Mine are adjusted all the way out so I glued a rubber pad to each side on the channels where the bumpers make contact, to act as shims. The liftgate now releases completely in all temperature ranges. BTW, the dealer techs didn't know about adjusting the bumpers.
Rob
2001 AZTEK :confuse:
I was hoping fellow Aztek owners might chime in with some AZTEK insight . Are you out there RAY 80??
There's this thread over in a Chevy discussion for coolant:
airmn65, "Chevrolet Cobalt" #1686, 18 May 2006 3:15 pm
But that doesn't seem to have anything to do with the heat/defrost not working all the time. If this is a cabin temp problem check out the Climate Control Problems (Air Conditioning, Heat) - All Cars discussion while waiting for responses in here.
Sorry to be confused; I usually think of the thermostat relating to the radiator/cooling system.
I'm looking for feedback on this. I'm looking at purchasing a used 2001 Aztek, 124k. Supposedly in great shape. My father in law is a mechanic, and is advising us to stay away from this vehicle, and keeps telling us all the problems with Azteks. Now as drivers of Azteks, would you recommend this vehicle? or should I steer clear of Aztek's all together?
THANX
Have you checked your local car junk yards? I have bought a few parts for my Aztec locally, maybe try calling one around your town. If anything, maybe when they get a vehicle in, they can hold one for you.
Hope that helps.
1. Yesterday, my gas gauge stopped working. About 30 mins after filling tank full, my light came on and registered that I had no gas, about 15 mins later, the light went off, and gauge seemed to work. I read on other posts it's something to do with the "BCM"... What the heck is the BCM?
2. The heat/air control set at the #1 barely works, but the #2 and the rest work fine. Problem is that you get blasted with air and can't regulate the flow without turning it up and down the whole time you drive.
3. A/C doesn't seem to be cold enough. 2 years ago, AC went out, GM fixed the compressor, but last year it started acting up and doesn't seem to be cold enough.
4. When the A/C began acting up, so did my air compressor. It doesn't work now. I can hear it running, but it won't inflate anything.... Are these two issues related?
5. The light for half of my HVAC controls and my AC button doesn't work unless I keep thrusting my heat/cool selector (middle dial) towards the HVAC controls (right dial), then the lights will come on. Takes multple attempts.
Of course, the car is out of warranty. So, any help or suggestions anyone can give is GREATLY appreciated.
When the car was in warranty, the dealer had to fix:
rear latch - 3 times... works fine now
air compressor-twice
A/C
full brake job
Out of warranty fixes I had fixed:
wheel bearings
replace driver side window control switch
Overall, the car has not given me much trouble. Just routine maintenance over the years.
If you have any suggestions on my current problems, I'd love to hear from you.
Thanks !!!
From what I am told, there is no cabin filter (I was told about a year ago during an oil change, they couldn't find it, and it's typically located in the engine area).
Friday night, my "service engine soon" light came on and is staying on. In the owners manual, it says that it's an emissions problem and that I would have had malfunctions prior to the light (hence, the gas gauge). I would really like to know if I could fix this myself?
I am going to try the connections cleaning. Thank you sooooo very much.
Last week I had the oil changed, but when I drive the change oil light comes on. Also, the repair shop changed my head gasket for $700 last week.
My 2nd problem is when I drive the hot engine light comes on. The antifreeze container holder fluid is mild & not hot.
Does the repair shop have to change my thermostat or reset the computer or what else could the problem be?
Thank you in advance!
Let me know, thanks!
