Isuzu Trooper Timing Belt Problem
I change the Water pump of a 1995 Isuzu trooper and I change the Timing Belt wrong. I know it for the strange sound that it makes in the engine.
Do the valves of this SUV get damage?
How can I change It?
Can I find the user manual of this SUV some where?
what do i have to do dont have a clue about cars and sick and tired of being conned at the garages!!!!!!!
This engine is a non interference engine, according to the experts. There is a warning in the manuals, but I am pretty confident that you should not have any damage unless you really over revved it or drove it a long time with it mis timed, .....which usually cannot be done as the engine will run poorly if at all.
One guys opinion.
pulley bottom lip tight against outside of pulley lodge other end against frame or something very solid and pull lefty loosey righty tighty
get a few feet of 1/4 to 3/8 nylon line (or rope) and feed it into the cylinder through the plug hole until you have a hand full in the cylinder. When you un screw the bolt the valves will close and the rope will compress in the cylinder stopping the piston.
You may need a length of pipe to extend your breaker bar to make it easier on your back. I have used this trick a hundred times and have never bent a valve or piston rod.
To tighten the bolt remove the rope, move piston to 90 deg. BTDC and reinsert the rope. Hope this helps someone! Cheers.
what are the marks on the cam shafts, and how are they aligned?
1) I cannot find a cam sprocket alignment mark on the passenger's side. The driver's side sprocket has a line stamped in the rim of the sprocket and another on the "front plate". The two cam sprockets are quite different. The passenger side has two notches 180 deg apart. One of them lines up approx where the SOHC diagram says. But I can't find any mark/dot/dimple on the front plate. Someone did scribe a mark on the front plate and painted a mark on the sprocket.
2) There are clear marks on the drivers side cam sprocket, but they are not where the SOHC diagrams indicate. The driver's side is closer to where the DOHC marks are located.
3) The cam sprocket marks are way off (~90 deg) if the crank sprocket has the keyway/notch at 3 o'clock lined up with the mark on the oil pimp. But, I did find a reference in the Chilton's manual on the '96 3.2L which says "verify that the pointer on the crankshaft aligns mark with the mark on the lower timing cover". I take that to mean 0 deg on the timing scale on the t-belt cover. My marks line up if the crank is in that position. (Interestingly, the "to install" procedure says align the crank sprocket with the oil pump marks. Re-assembly should be the reverse of disassembly.)
I just want to be sure I've got things in the right position for installing a new belt. The homemade mark on the passenger-side sprocket is one notch off from the others.
Is there any way to be certain of the passenger-side cam sprocket without having to pull the valve cover?
jon
To remove the Serpentine belt tensioner. Looking at the thing from the front there is a bolt 45 degrees up and to the left of the center pivot of the tensioner. 12mm socket gets it. Then need an 8 mm Allen wrench. Not sure what they are called now. And unscrew the center bolt and the tensioner comes right off. Only took me about 3 hours to figure this out, Feared that center bolt would take the tensioner itself apart but it is ok. Now to figure out the power steering pump so it goes back together easier.
