Subaru Forester (up to 2005)
1150151153155156344
  • joseph50joseph50 Member Posts: 235
    My observation matches Bruce's. I live near Philly, and I have seen but one 2003, and that was up in Jim Thorpe. Competition seems to be taking its toll.
  • lakepoplakepop Member Posts: 221
    All the speculation on the 2004 might have some impact....I for one would not want the 03 because I believe the 04 will bring a turbo!
  • subaru_teamsubaru_team Member Posts: 1,676
    Forester sales are up 4% from this time last year. I was surprised how many I'm seeing in the Southern New Jersey area. Maybe they jump out at me because I can readily tell the difference in model year by a quick glance?
    Patti
  • burnsmr4burnsmr4 Member Posts: 318
    ...will too rust. That black stuff you see on aluminum replacement windows is rust. It doesn't rust as quickly as other metals, but it'll still rust.
    burnsmr4
    Forester rental in Hawaii? How cool is that?
    The hatch striker plate can be adjusted, so that's something the dealer could fix for you fairly easily.
    Bruce: I just read a press release that said Forester sales were up 4%, and that Subaru had a record August.
    But a $1200 incentive? I'd take it, no complaints here. I bet that's not accurate, though. Even the 2002s only carried a $500 incentive, and that was to clear out the left overs for the 2003's arrival.
    In fact, the 1998-2001 never carried any cash incentive, which is great because that keeps resale strong.
    -juice
    Yeah, I just checked fitzmall.com, and they have prices right around invoice. If there were a $1200 incentive, prices would be around $1k under invoice, at most.
    It could be regional, though. Or just a mistake by Edmunds. Patti - can you verify that? Or is that top secret stuff? ;-)
    -juice
  • kenskens Member Posts: 5,869
    A Forester rental in Hawaii would be sweet indeed. Where did you rent it?
    What a way to market a car -- you get to test drive it in paradise!
    Ken
  • k2rmk2rm Member Posts: 205
    They had a both 2003 and 2002 Foresters to rent. I originally had a compact reserved (chevy cavalier) and they told me I could get a brand new Forester for $10 more a day, I didn't even have to think about it. The great visibility in the Forester was perfect for the Island.
    There's a no-brainer if I've ever seen one.
    -juice
  • marinkidmarinkid Member Posts: 7
    Juice- The cash to dealer for 2003 forester shows $1200 for 2 other zip codes I put in for oklahoma and Montana, so it is not just california area. Also, 2003 outback and legacy have only a $300 cash allowance to the dealer. It does seem odd that 2002 had $500 cash and 2003 already gets $1200. Although 2002 legacy and outback both had $1200. Bruce
    Must be regional. If it's true that makes the Forester a solid value, I thought it already was. I'd actually prefer to see Subaru add content vs. drop pricing.
    -juice
  • ddunbarddunbar Member Posts: 31
    When I pull up the 2003 Forester incentives page, the first thing it lists are the special APRs and $1200 dealer cash for the 2002 Legacy (so it seems the Edmunds folks may have a programming glitch here somewhere). When I go down the page a bit farther, I see special APRs for the 2003 Forester but no cash deals.
  • azealazeal Member Posts: 11
    The surface layer of untreated aluminum will oxidize, but it will not "rust" in the sense that steel will rust till it crumbles (the way body panels on older model cars commonly do). The black stuff on the surface of aluminum can often be wiped off with a coarse rag, rust on steel needs to be sanded :)
  • padraicsdadpadraicsdad Member Posts: 16
    Instead of cutting prices, I'd rather see Subaru put decent OEM tires on Foresters.
    The "older" of our two '02 Foresters has been vibrating at 65-70 mph for more than 8,000 miles now. I've taken it to Martin Subaru (South Jersey) three times and each time they say they balanced all four Duelers but it still vibrates. When I asked if their lack of success indicates I might have one or more out-of-round tires or a different problem, the service adviser suggested take my problem to a Bridgestone dealer. Grrrr. Oddly, our other Forester is fine.
    As much as I hate to spend $$ replacing the tires on a new car, Marin Subaru is obviously not going to help and this vibration is right at cruise speed so it's a source of constant annoyance. Any thoughts on a good choice for replacements on an '02 Forester L? I'd prefer not replace the wheels but will if I have to.
    Jeff
  • declansdaddeclansdad Member Posts: 120
    I just put Dunlop Sport A2s on my 2000 Forester and I love them. I ordered mine from Tirerack.com and had them delivered to a local shop who did the install.
    FWIW, I wasn't to fond of the OEM Yoks. Good luck finding some new rubber.
    Michael
    Don't write off Yokohama's... I suspect the primary problem with the stock tires is their crappy OEM status (a cheap tire built to order so that the manufacturer can keep vehicle costs down). The Bridgestones on the Honda CR-V have similar issues.
    Some of the Yoko models have won rave reviews. If you are looking for a highway tire for the Forester check out the Avid - Touring model.
  • rsay777rsay777 Member Posts: 100
    After the initial break in I was impatient to hit the road so I did a 2k trip which included mts. desert and coast. The handling and comfort was right on. This 03 Forester goes down the highway "real nice" Bob L.
    Wil eventually eat it's way through the whole thing. I've seen it happen, it takes a lot longer and can be prevented by cleaning it more often.
    -mike
  • grahampetersgrahampeters Member Posts: 1,786
    G'day
    Aluminium develops a fine coating of aluminium oxide as soon as it is exposed to air. If this is not disturbed, it provides a protective coating preventing further oxidation. It is unlike iron oxides which flake away, exposing fresh steel to corrode.
    Cleaning exposes fresh aluminium which in turn oxidises. Typically, aluminium is anodized, often using coloured salts, to give a better protective finish and ensure the core thickness of the metal is undisturbed.
    Cheers
    Graham
    I believe the $1200 for the 2002s, or what's left of them.
    Score one for aluminum.
    The 2002 still had the 15" steel rims, like mine did. My problem was the size 205/70R15 doesn't offer a whole lot of options that aren't "mud digger knobby" specials. So I chose a Plus One.
    Consider the BF Goodrich Touring T/A tire, though. Honda put them on the CR-V, and that alone improved the lateral G's by 0.03 in C&D tests. I've also heard good things about the Dueler H/L (different than the OE H/T tire).
    -juice
  • caperosiercaperosier Member Posts: 58
    Still something to the many users that experience the poor performance of the OEM Bridgestone Duelers on the L's.
    New 2001 L on mixed highway/rural hardtop driving thru a full winter in northern New England. Wear marks at about 25K (not aggressive or high speed driving). No or dangerous grip on any hint of snow, ice, slush (this ain't Florida or New Jersey).
    Choice for an all season compromise ? Michelin Symmetry. So far thru a northern Maine winter--not too bad. Not the Nokian snow/ice performance, but still safe.
    No response from SOA as to why this choice for OEM tire. Patti?
    Coming up in the Pine Barrens of NJ. Check out http://isuzu-suvs.com/events/pb-09-21-02/index.html for details. It's a very tame/beginner trailride. All are welcome to come on down and join the fun and get your SUVs dirty!
    -mike
  • gened1gened1 Member Posts: 256
    Back around post #5529 there was a discussion on tires you may want to check there.
    At the time BFG T/A M65X 15" and Yoko AVD TA's on 16" wheels were discussed.
    We are probably due for another discussion now as to how tires are performing ,especially since Winter is approching.
    Gene
    Well I got about 33000 out of my duelers. Probably could have stretched a little more but...
    Anyway replaced them with some Dunlop SP 5000s which I got from Tirerack. Put on 215/55/15 which is plus zero and so far they are performing quite well. Clearly better than the duelers and I will wait and see about performance in the snow.
    Had them installed plus balanced and a 4 wheel alignment. They did a poor job on the balancing and I took them to another installer to rebalance.....much better!
    OK..thats my tire input.
    OOPS...my bad.....tire size is 215/65/15
  • maverick1017maverick1017 Member Posts: 212
    Got back from the Subaru Rendezvous in Syracuse this weekend. Fabulous event, very well organized, got a whole bunch of free stuff. The Autocross ride-along was Amazing!! its like riding a roller coaster but definitely more fun! One of the the Subaru USA Rally car was there as well as another STI specification class N rally car, some lucky guy won a raffle to ride in it as it tore through the Autocross course. Anyways, talked to a number of Marketing reps and all seem to confirm that a Turbo Forester is definitely coming in model year 04. Most of the reps confirmed it would be a 2.5Liter low pressured H4 Turbo power plant that would grace the engine bay. They wouldn't comment on technical specifics that I asked for...DOH! I, for one, am anxious to see how the aftermarket parts vendors and manufactures will react (i.e. WRX type craze or not) Regardless, this is good news for us all.
    Mike
    On a side note: An STI ver of the WRX is confirmed for MY04 as well. no specifics though. DOH!
    On another side note: The Baja is one fascinating vehicle. The more I looked at it and played around with it, the more I like it!! AHHHHH, some many Subies, so little time, (and money)!!!! :p
    Those Duelers are OEM for Toyota and Honda, too. Many more, I'm sure. Tires are cheap to replace and can give you a significant improvement, anyway.
    Mine lasted 28k miles, but now I have 16"s and my tires aren't offered in a 205/70R15 fitment.
    -juice
    I'm almost positive they are just hired people who get a press package before the event. :( Like the ones at the NY Auto Show last year.
    -mike
    uses Duelers - Bridgestone gives the best volume deals. So all the carmakers pick their tires for their new cars.
    The Yokos are a much better tire in my experience.
    As far as I know, they were Reps. There were two distinct groups of people there, one group (hires, and Subaru affliate employees) in Red - alot of those, and another, Subaru Reps - according to the people in Red and the people I talked to, I asked them specifically if they worked for Subaru - in Blue (harder to find than a diamond in a coal stack). I am assuming that I was not being lied to. I know, I know, what happens when you assume... But hey, who knows...
    Mike
    I posed the center headrest question I posted here earlier to the MY Subaru site.
    Here is what they sent me, I hope it helps someone.
    Gene
    I apologize for the delay in getting back to you. I just tried to install the rear center headrest from a 2003 Forester into a 2002 Forester. The widths of the bars to install these headrests were different. So, it is not possible to install the rear center headrest from a 2003 Forester will not fit into your 2002 Forester. Best wishes!!
    John J. Mergen
    Subaru of America, Inc.
    Hey - at least they tried. Nice service.
    Visited my dealer yesterday, and he also said the rumor he heard was the turbo would be a 2.5l.
    Watch out, competition.
    -juice
    Don't know what I am ah ha-ing about but it seemed appropriet...:)
    Hi all,
    I think I triggered this round of "tire" posts. Thanks, the opinions you've all contributed are really appreciated. However, our two Foresters are family vehicles, not race cars. High performance tires might be fun but we don't need high performance or expect it from OEM rubber. I'd just like to to drive my Subie at 65 - 70 mph without it vibrating and without spending $800 on aftermarket tires and wheels. And that is possible. The OEM Michelins Ford provided were still on our last car when we traded it with 73K on the ODO. I rotated those tires every 8K and kept them at 35 PSI but they never caused a problem or needed rebalancing.
    I don't think it's us. Everything is smooth when we drive our "newer" 2002 Forester L but our "older" 2002 L (with 10K miles on it) vibrates and has almost since it was new. That's mildly annoying on commutes but a major pain on long trips. It also pulses under light braking, which might suggest warped rotors and may or may not be related.
    Sounds solvable, right? Yeah, me too. So I took it to Martin Subaru...three times. Each time they said they balanced all four wheels but the only change so far is that they moved the vibration zone up 5 mph, to 70 - 75 mph this last trip. When I ask the service advisor if this might be a different problem, such as an out-of-round tire, a wheel or rotor defect, etc., she acted like I was stupid and told me to go see Bridgestone. Worse, when someone from Martin phoned after the latest service to confirm that everything was OK, I told her I wasn't happy and why. She said the service manager would call. He hasn't.
    Come to think of it, maybe I am stupid - for buying two cars there this year. If you're in the South Jersey area and in the market, Martin's Internet sales specialist Karl Fulton is really great to deal with. But figure on going somewhere else for service. Or buy a Honda.
    Venting is good! :-) Thanks for the space.
    Jeff
    PS - People seem to like the Yoko Avid All-Season Touring radials and the price is right so I guess I'll order four of them from Tire Rack. Hope the problem is really those &@#! Duelers, not something else!
    J.
    How about switching tires with the other Forester you own? Then all you would have is sweat equity to see if the vibration is the tires or something deeper?
    Gene
    a friend of mine lost a side view mirror the other day on her 02 S premium. Dealer quoted her $300 for a replacement. Anywhere else to get one for a little cheaper?
    Mike
  • riskman11riskman11 Member Posts: 11
    Jeff:
    Here's a suggestion: go to www.hunter.com, click on Products, and wheel balancers/GSP9700 Vibration Control System. I had the opportunity to visit Hunter in St. Louis and see how this thing works. It is an amazing machine at finding and fixing balance/vibration problems. Click on "find a GSP9700" to find a shop near you and give them a try, especially if you still have usable tread left. If you still need tires, do the comparison thing on TireRack's site, comparing the size and type of tire you want. Having done this several times, I just today ordered a set of Dunlop SP Sport A2's for our '01 Forester S+. Besides being a great price, they won the comparo hands down. Good luck!
    gened1 - Thanks, a good suggestion that I'd better follow before I order new tires.
    riskman11 - An even better suggestion with an interesting result. When I asked Hunter's website to tell me about the nearest shops that own Hunter GSP9700 machines, guess who two of the closest are? Subaru of America in Cherry Hill, NJ (8 miles) and Subaru of America in Merchantville, NJ (10 miles). Now that I know Subaru has this advanced equipment so close to me, I wonder why Martin didn't either take my Forester there or suggest I take it there and why the SoA people on this board are so silent. I didn't think I had to appeal to the factory to get a relatively simple problem solved but maybe that's what it takes. What a disappointment. I'll call SoA next week, I guess.
    Also, the Dunlops you suggested look like a good choice but they don't come in a size that fits my stock wheels. I'd have to buy aftermarket wheels to use them.
    Thanks all,
    Jeff
  • jrosasmcjrosasmc Member Posts: 1,711
    Is the '03 Forester's wheelbase the same length as the original '98's, and if so, what is it? 100 inches?
    For wholesale prices on OE stuff, e-mail parts@libertysubaru.com for a quote. They were a little cheaper than subaruparts.com. But then you have to install it, or find a body shop that'll do it for you.
    Wheelbase is the same. They're all 99.4".
    -juice
  • garryc1garryc1 Member Posts: 9
    My wife (and I) want to disable the DRLs in her '03 Forester.
    Can't seem to find a definitive method anywhere.
    Any of you tech-types able to help us out?
    Much appreciated!!!
    My question to you is, why?? The vehicle is safer with the DLRs, than without. Other drivers can see you better in marginal lighting conditions, such as overcast or "gray" days.
    Another thing to consider, you may(?) be breaking DOT laws by doing so.
    Bob
  • logtraillogtrail Member Posts: 74
    I recently got a letter from one of my local Suburu dealers (Valley) indicating that they had been selected by Suburu for a special deal on a trade in for my 99 ForesterS. I was skeptical, but was in the area so stopped in. To trade in my
    99 Forester S (40k miles, loaded, sunroof, garaged, etc) for a 2003 similarly equipped would cost me $12,000+. Wow, what a deal! I think I'll wait for the next model and probably wont go to that dealer. Does Suburu have anything to do with this "promotional"?
  • jackleungjackleung Member Posts: 79
    Anyone know how to adjust the headlight focus left and right? I only found how to adjust focus up and down.
  • eps105eps105 Member Posts: 216
    Logtrail,
    That actually sounds like a bad deal. Sounds like the dealer is trying to lure you in with one of those deceptive ads trying to make you feel like "you've been specially selected from a exclusive list". I see those all the time. The "exclusive" list is everyone on their mailing list. I'm willing to be that Subaru corporate is not involved.
    I bought my loaded to the hilt '03 XS (sticker $27K+) for $500 over invoice - about $25,000. I traded in my '99 L with 50K+ miles (much less equipment than your S) for $12,000. Yours is proably worth closer to $14,000. So you see, a really good deal would be if they gave you the new one for $11,000-11,500+tax/tags and not a penny more.
    Good luck making a fair deal,
    Elliot
  • harvittharvitt Member Posts: 9
    I bought an automatic 2003 X model at the end of August in Oakland, CA. Options included extended armrest, cargo tray, cargo net, splash guards.
    Here's what i paid:
    20,341.14 vehicle (about $85. over invoice)
    45.00 doc fee
    1681.86 sales tax (alameda county, CA)
    177.00 license fee
    5.00 calif tire fee
    Total out the door price: $22,250
    I used the fightingchance.com method of buying a car, which worked really well for me and took the major stress out of buying. I highly recommend it.
    Still the dealer tried some slimey bait and switch stuff on me -- you gotta watch those guys like a hawk!
    Also, I bought a 7yr/100k subaru gold plus added security (extended warranty) for $1295.
    So far, I love the car!!
    Jack: sorry, the lights have changed at least twice over the years, my '98 is different than the 2001s, which are different than the 2003s.
    Daniel: congrats! What color did you choose?
    -juice
  • gopiratesgopirates Member Posts: 4
    I normally just view you guys messages, but I have to tell you my deal I got this weekend.
    I just got a 02 all deck out with only 4000miles, leather/6cd/moonroof/upgraded speakers and amp-subwoofer/cargo net and tray, for $22800 out the door! I had to jump on the deal. Please let me know if this sounds like a good deal!
    We are now proud owners of 2 SUBS, the other is a 01 Outback. The Forester seems to sit higher, have better overall visibility, and be a tad bit quicker in response(which I love.)
    *What is weird is my 01 OB has lower LATCH anchors in the back seat, and because of the hump in the middle the seat, we have to put it on the outside seats. On our new 02 Forester, there is NO lower LATCH in the back! But because of no hump in the middle, we can but the car seat in the middle.***
    Can someone please explain this one??
    I think the LATCH may be new for the 2003 Foresters.
    But some tests have shown that they're not any easier to get tight than regular belts, so don't worry about it. You do have the upper tether anchors, been there since 2000.
    -juice
  • rblelandrbleland Member Posts: 312
    I concur with Bob - why do this? In Canada, DRL's have been federally mandated for many years now and no one (to my knowledge) complains about them. It is definitly a lot safer to have the DRL's, especially in passing situations and marginal light conditions. There is no problem with glare or blinding. I'd let them be (but it's your car). Just my opinion.
