When I called the dealer, they said they were starting to see a problem with the keys if they were around cell phones and such, especially during in-coming calls. Apparently it can somehow wipe the key clean and cancel the programming. Wonderful. I know the manual says cell phones can drain the battery, but I did not think they could wipe the programming. I need to take the key in and have it reprogrammed. Sounds like it will take a few hours to do it. He said that there may be a recall if the problem continues to allow them to change the chipset in the key.
In any event, I'm just glad it happened while I was at home and not 30 miles away at work without easy access to another key. I'm hoping they will consider throwing in an extra key just in case. I've only had the car 3 months and I love it. Best thing I've ever driven. But not feeling too comfortable that the key can get wiped like that and there is no backup other than hopefully having easy access to the other key. They need to get this straightened out.
Keep your cell phones away from the key!
I've owned Nissan products before (2 Altimas and 1 240sx) and have never felt anything like this before. It feels very unsophisticated.
Has anyone else experienced this? Can anyone explain if this is normal for this car? Can anyone explain "technically" what is happening in the engine/transmission to cause this?
This is exactly what the dealer told us when we took delivery last week. It is an apparent design flaw and Infiniti is owning up to it being their problem and responsibility. They may have to replace &/or re-program the key fobs.
#565 of 591 Keyfobs, possible recall! by scottm123 Apr 28, 2007 (5:58 pm)
Hey everyone
Just a heads up.
I haven't seen it mentioned here, but there are some owners experiencing issues with the keyfobs leaving them stranded.
You can use the key to get in, but even with the fob in it's slot, the car never sees it and won't start.
(Hasn't happened to me yet, knock on wood)
Anyway, Infiniti is now saying it's caused by keeping your fob too close to your cell phone, and the phone deletes the code in the fob.
For some, just having the fob in the right pocket and the cell phone on a belt clip has been enough to cause issues.
Infiniti is supposed to be working on a solution and possibly supplying new fobs, but in the meantime, they are asking us to keep our fobs away from our phones.
I'll keep you posted as I learn more.
From what I've been seeing, it appears to be much more common among the GSM phones, and not with the CDMA phones.
What ype of phone do you have, and have your fobs been close to the phone?
ie, do you keep them close on a table, both the phone and fob in your pocket, etc?
It'd be nice to know your daily fob/phone habits, so we know what to avoid.
I actually have been keeping my fob and my phone very close together when I drive. Other than that, they are separate. They won't be within a yard of each other any longer. Crazy stuff.
Can anyone elaborate further on that?
Who's your provider?
Verizon is CDMA, but most others are all GSM now.
I keep my phone on a belt clip, on my front right side.
I've always kept my fob in the front right pocket.
No issues yet.
I have LCD and one older CRT monitor. If someone near me gets a incoming call on their GSM phone, the CRT monitor on my desk buzzes and picks up all kinds of horrible interference.
I also hear this buzzing when on conference calls.
All this appears to be related top the GSM technology.
I know that when I get an incoming call with my Verizon Razr (CDMA), I get no interference at all.
Just trying to narrow this down :confuse:
I use Nextel. They don't sell my phone anymore so I can't check the specs on the unit. I saw a posting from someone about this phone and it led me to believe that it was a CDMA phone since they indicated they wanted a phone similar to the i530, but wanted it to be GSM and globally capable. I admittedly don't know much about it, so I could be wrong.
Nextel uses something different... they use a technology called iDEN.
I'm claiming ignorance here.
I have no idea if this is closer to CDMA or GSM, but it sounds like it's a possible issue like GSM, so I guess we should take necessary precautions.
Thanks ! !
In the mail last night, I finally received mine as well.
It's official now, and they're working on providing us new Fobs in early Fall 07. (free of charge of course)
For some reason, however, I don't think my cell phone caused it. I have verizon. I always kept my key in the cup holder or purse along with my phone. They are my buddies : ).
So why fail now? Frankly, I think the issue is greater. I suspect one of two things are happening: Batteries are suddedly going dead and the decoded signal is lost when replacing them, or perhaps there are theives in the area using scramblers to wipe out our keys. I cannot simply imagine that now, all of a sudden, people are having problems with keys nearby cell phones. We would have figured this out in November shortly after launch. There is more to this story.
The issue begins when they are close or touching, and a call is received.
You can keep your friends close to each other and have no ill affect if a call never comes in.
Also note that some owners have had their fob/phone together in a pocket or purse, received a call, and then 2-3 days later, witnessed the problem with the key fob not working.
It's very strange, but it is the phone causing the issue.
This has been an issue for months and months.
I asked my salesman about it when looking at the car and he played dumb, but Infiniti has known about and has been working on a resolution for quite some time.
At one point a few months ago, they were blaming it on radio and cell phone towers. (LOL)
My only complaint is that they knew about it, I asked about it, and they played dumb.
While I'm sure there is something wrong with the fobs since infiniti acknowledged it, I really think the issue is with a cell phone band that clearly interferes with other electronical devices... Verizon doesn't do it.
Ya know, I brought this same point up elsewhere, and everyone thought I was nuts and they knew nothing about this interference.
You'd have to be dumb, blind and mute to not notice it in any office environment.
I hear it through CRT monitors, conference calls, speakers, etc.
My Verizon doesn't do it, and that's why I was asking if this is more of a GSM issue than a cell phone issue in general, as the Verizon CDMA phones don't interfere with electronics.
Not everyone has this problem. I too have the Razr and Cingular and no interference with CRT, calls, speakers, etc.
Put your phone right next to your CRT monitor and make sure the speakers in the monitor are turned on,and at a volume you can hear.
Now, call your phone.
Your monitor doesn't make noises? :confuse:
I experience no problem. Ahh, but my monitor is an LCD, not CRT.
Have any of you had paint problems and did you get it resolved through the warranty from the dealer? Please help. I am so angry and am wishing I bought the BMW.
I won't trouble you with my riff on crap "green friendly" water-based automotive finishes, but I do have one.
I am supposed to have the dealer look at it again after talking and showing it to the owner. he said he could not promise anything which sounds like I am screwed.
I think I am going to have to get it re-painted completely and there is no telling on what that is going to cost me.
I hate infiniti. I knew I should have got the BMW 335i. I see where they get off charging 12.5K less.
This is not an Infiniti issue.
It's an unfortunate byproduct of new environmentally friendly low VOC paints.
They're softer, and they chip MUCH more easily, and more often.
You'll find this on Acura, Lexus, BMW, Infiniti, Lincoln, etc.
The roads and conditions you are driving in are causing this chipping to occur, and the already very easy to chip paint is suffering from these conditions.
If you go buy the BMW, you'll see the same occurrence.
Those of us who were already aware of these issues chose to not even pick the car up from the dealership, without getting a protective paint film installed first.
Whether you choose a re-paint, or the BMW, I suggest you consider the same.
Or is that the "paint protection"?
I was the one asking about the total care package that you said was a ripoff. Im still trying to determine what I should get before I pick up my car.
I got my Hood, Fenders, Upper and Lower Front Bumper, and Mirrors done... essentially the whole front end.
Dealer had a 3M Certified installed on staff and I got my whole kit installed for $695
Well worth it.
Having owned enough cars you kinda know when something is not right. If anything the technology should be better and not worse and the paint should be tougher. I think they painted it in the wrong conditions and thats why its is peeling off.
Oh, and the paint chips are in places that road driving would not get to it. Behind the spoiler facing the window. Roof. Crazy places. Especially plastic.
No, Its definately not normal and its definately not right.
None of my friends with BMW's have paint problems. Some with the same color almost as mine. Paint is the last thing I would have thought would go wrong on the car. I took paint as a given under normal driving conditions which is what the car has been throguh.
Good thing we're not friends... it'd throw your equation way off.
I'll just keep mine parked in the garage from now on.
Not making assumptions or accusations, but may I ask...
What octane/type fuel are you using?
How was the car driven/treated during it's break-in period?
Posted this earlier, in the nav section. Just trying to see if i can get some more responses.
I noticed that the nav on my G35 coupe (07) doesn't recalculate routes if a miss a turn. Is this for everyone or something wrong w/ mine?
Also, it seems to be a little sluggish. It for sure updates slower than the NAV in a honda pilot.
anyone w/ similar exp?
I've noticed that in new areas, the navigation doesnt update any turns or misses. Once I am on an old road (one that is in the database) then it recalculates the route. If you're not in a new area, then it is malfunctioning.
Your issues sounds more like a low battery or something.
If it wirelessly unlocks the doors and trunk, you have a different issue.
Have you tried placing it into the keyfob slot, down near the driver's left knee?
If you do have fob issues, the dealer will need both of your keys and the car itself, as everything needs to be reprogrammed.
The fob issue they reported on, when you experience it, will require complete replacement of the fobs anyway.
marble size hail hitting the cars. My G was way out in the parking lot away from everyone so I could not see it. This hail lasted about 10 minutes and I was depressed has He-- as I could just picture what that beautiful titanium finish now looked like. After it was all over I could not believe what I Found. There was not a single mark on the finish. UNBELIEVEABLE !! Don't tell me prayer doesn't work. so still don't have any rock chips today. ( Fingers crossed) I'm just hopeful that Infiniti maybe did something to the paint.
Motorhead7
Nothing better than a happy ending.
Glad it was damage free.
I know how I'd feel if it was me.
