Subaru Forester (up to 2005)
Alan
Ross
I've always had it serviced at Subaru and since it is not part of the suggested maintenance schedule I'm sure it was never done. I will give it a try - I hope it is that simple.
spuds
-mike
It has 53,000 miles. The strange thing is that there is only a problem when shifting from Park. Once the car is moving it shifts through the gears fine. It looks like I will be changing the ATF today.
Alan
-mike
so I went to station and filled up. Made sure that gas cap had clicked several times. Started car. Lignt still on. Parked car to think about things. Started car again and light was now out.
Logic? Could this possibly have anything to do with being low on gas? Suspect not but???
On my other car, I had an MIL (Malfunciton Indicator Light in VAG products = CEL) that lit and then after several driving cycles went off. After the diagnostics were run several months later, it turned out that I had a loose connection in one of the spark plug wires ...not loose enough to be mis-firing but just enough to trigger a MIL/CEL.
--'rocco
"By far, this is the most upscale-feeling mini SUV we've ever had in our fleet,"
momof05: I couldn't find a loaded 2003 Forester XS in San Diego or Orange counties here in southern California when I went shopping for one in September. There were many Xs and XS Premiums, but few XSs, and those had zero to four port-installed options (PIO). I ended up ordering one from the factory near the end of September; it took about five weeks to arrive at the dealership. The window sticker lists port assembly at Vancouver, WA. The vehicle as delivered was missing three PIOs I ordered (Cargo Bin, Cargo Net - Rear Seatback, Trailer Hitch) and included one I hadn't (Cargo Area Spotlight). I took a pass on the missing items for now and the dealer didn't charge me for the spotlight.
thecat: At least you put thousands of miles on the car before it started leaking. My 2003 Forester had only 197 miles on it when I found it was leaking engine oil. I dropped it off at the dealership Monday morning. The service advisor called that afternoon to tell me it was a loose baffle plate and that they needed to drop the transmission to reach it. According to the 2001 factory service manual the baffle plate is enclosed by the engine oil pan, so I'm guessing that it's really the oil separator cover that was loose. I'll find out for sure when I retrieve the car this afternoon. After driving the complimentary 2002 Saturn SL1 loaner for four days, I can hardly wait to get behind the wheel of the Forester again. I hope this early failure isn't the start of a trend.
ninian: Perhaps attaching the hook side of hook-and-loop (e.g. Velcro) strips to the smooth underside of the rubber mats would reduce slippage.
the_schlepper: Juice is spot-on about the rear differential protector. I installed one on my wife's Forester last year in about an hour. It bolts on into existing threaded holes. The kit came complete with the necessary bolts, spacers, and what I think are clear installation instructions.
spudman: I agree that the gold Foresters are pretty. My wife's Sierra Gold Metallic 2001 Forester S looks good, even when it's parked next to the Platinum Silver Metallic 2003 Forester XS I picked up last Thursday.
--- Lowell
When Car and Driver tested the '98 Forester, they got a 0-60 time of 9.1 sec. with the manual. Most reports indicate that the auto is about .5 sec. slower. The Edmunds reports shows the 2003 Forester with automatic, that weighs about the same and has the phase II engine that produces a bit more total torque and more torque at lower speeds, at a slow 10.2 sec to 60 mph. While there are always differences in testing conditions, and possibly, differences in axle ratio, this seems rather disappointing and is another reason that we could use a turbo. One of the reviewers suggested the H-6.
The review foound that the XS with Electronic Brake Force Distribution and the new, larger, front discs stopped in 137 feet from 60. The '98, with smaller front discs, was found by CD to stop in 119 feet, which they happlily compared to a Porsche 911. Again, testing conditions vary, but the current figure puts the Forester below average for current small SUVs.
Also, the review seems to indicate that the in-dash CD changer is part of the premium sound package. It is standard on the XS.
You'll usually find that car magazine 0-60 times are faster than those found by Edmund's or Consumer Reports. I'm not sure how Edmund's tests their vehicles, but with C&D, they'll try several methods (like dropping the clutch) to get the best times. I'm sure the majority of drivers will get times comprable to Edmund's or CR in day-to-day driving.
Do you know if C&D did a road test on the 2003 Forester? That's probably a more accurate comparison.
Ken
Now I'm almost halfway through reading the owner's manual and saw something interesting last night. The manual mentions the handle on the inside of the rear gate. In bold print the owner is warned not to hold onto the handle while closing the gate. I imagine that might hurt a little bit.
hank
As to driving, do the obvious: allow for much longer stopping distances, no sudden movements, and drive (very) defensively.
Bob
Alan: the auto trans is pretty robust. I'd find a place that can flush the ATF completely, i.e. with one of those machines that forces new fluid in and sucks the old fluid out.
My Miata had 26k miles when I changed the rear differential oil. It was like chocolate milk with lumps. Totally nasty.
Gear oil is thicker than engine oil, and engine oil gets replaced several times per year. Gear oil has to hold up for much longer than that.
If a CEL cleared, don't worry about it. It does get stored in the ECU's memory if they need to look at anything in the future.
-juice
The new advanced search might turn up some of those posts, if you want more detail.
Suffice it to say that the Forester performs as advertised. It's not a full-sized pickup, but it will do what Subaru claims with aplomb.
We tow a 16' Coleman pop-top (10' box + 2' storage compartment = 12' frame + bumpers and trailer tongue), which is class I (GVW = 2000#) at altitude (Rockies - 5k to 9k above sea level).
We have an '01 Forester S+ MT. I added the OEM engine oil cooler, the performance gauge pack (oil temp, voltage gauges) and an electronic brake controller for towing purposes. Your AT should have the oil cooler already.
Fully loaded in 3rd gear, our Forester will climb "straight up" (8-9% grades) at 50+mph over 9000' passes towing our camper. You really couldn't ask for more. Performance is fine.
On a trip to the Black Hills last year (385 miles each way), we got 22 mpg going 75mph while towing. No issues with the clutch so far (30k). The owner's manual mentions some speed limitations on very hot days when hauling up extended grades for AT models. YMMV.
I am VERY careful not exceed Subaru's stated specs, to the point that I use a bathroom scale to confirm the tongue load. I also run higher pressure tires on the camper than req'd to reduce rolling resistance (grade C at 45# instead of grade B at 35#).
Trailer brakes are absolutely essential in these parts (lots of 15 mile long 6-7% grades). Braking distance is still longer than without the camper, but acceptable. Engine braking in third with the stick is actually pretty good. It'll hold 50-55 on a 4% grade without touching the brakes.
Never had any sway, even in stout cross-winds (50 mph gusts), but our trailer has a low-profile (less than 4' tall).
Hope this helps,
-brianV
CR tested the 2001 Forester S and reported a stopping distance of 141 feet with the automatic.
The 2002 WRX Sport Wagon, also tested by CR had a stopping distance of 136 feet with the 5 speed manual, while the 2002 Honda CR-V EX automatic was reported to have a stopping distance of 135 feet.
FWIW, CR downgraded the Impreza to "average reliability" because of "squeaks and rattles".
Len
Engine coolant is picked up at the thermostat housing (bottom radiator hose mount - the kit contains a replacement thermostat housing with an extra hose connection on it), routed through a short steel pipe, the oil cooler and into the block at the passenger side drain (remove the plug and install a hose connector).
I got mine from Teague's auto. Cost was around $325 as I recall, which was $100 less than my local dealer. The kit was complete, hoses, clamps, the whole bit, and all original Subaru parts. It increases oil and coolant capacity slightly, but not enough to be worth talking about.
Forester AT models have one standard. It's only the MT that might need this mod. I can't speak for other Subes with the 2.5.
Installation is a cinch, because you've got great access. Drop the plastic spray shield under the engine and everything's right there. Because my Forester was still nearly new, I reused the coolant.
-brianV
This Forester can haul some colossal potatoes.
Ken
I don't want it.
The shift knob is crooked, sort of twisted to the left. I worry about what this could mean, aside from poor workmanship.
The vehicle made a low level (hard to hear) high pitched whine, which got louder as the speed increased. I don't remember the other Foresters I drove having this. I also couldn't tell whether this sound came from the engine or somewhere else - maybe the transmission or gear box?
The clutch was very touchy going from a stop into 1st gear, by which I mean it jerked almost every time it didn't stall. The clutch didn't engage until the pedal was almost at the top of it's movement range. Yes, I do know how to drive a stick shift, we used to own one, plus I test drove several other Subaru sticks in the past week with no problems. Are these problems a matter of adjusting the clutch and maybe the idle, or could they be a symptom of an underlying problem, possibly related to the crooked shift knob and/or the whine?
Also, looking at the vehicle from both the front and back, the driver's side is almost imperceptibly lower than the passenger side. I've experienced this before, with our 99 GMC Savana - it only got worse, and is now noticeably lopsided.
It had 144 miles on it when I got in, about 40 or so explained by the drive from the other dealership. So, that leaves about 100 miles. Even without the things I've just mentioned, I am uncomfortable with what I feel is high mileage on a new car. What does Subaru say about vehicle break-in? Is 100-150 miles a big deal when I don't know who drove it, how many people drove it, or how they drove it?
So - what do you guys think? I'm definitely not getting it, but I would like opinions on what you all think might be going on here.
Also, any opinions on the mileage? Too high, or within the normal range for a new car?
The final price I negotiated with options is about $550 above invoice, or about $700 less than Edmund's TMV. What have your experiences been?
Thanks, and thanks for everyone's input on the options that I asked about before.
If this is posted in the wrong place, please forgive me...
p.s. I don't think the dealer would be willing to get another blue one in, so if I really want that color, I may have to go to one of the other dealers that I turned down, which already feels awkward...
Absolutely! And you don't know what scared is until once bounces off the vehicle approaching you on the highway!
Walk away from this one and try another and/or another dealer. I'd bet your current dealer could find you a replacement...try it!
I bought a new Legacy in 1990. Mechanically and cosmetically it was very sound. However it made several alien sounds that bugged me endlessly, one of which was wind seeping in through a flawed door seal. I ended up selling the car in less than two years.
spuds
I do, however, think you may have exceeded the Forester's 150 pound roof rack load limit with that mutant tater.
Bob
mashed!
In topical news, check out recall info if your automatic Forester is a new one: Subaru recalls 163,000 vehicles
Bob
I LIKE it!
Had the Spudmobile (aka Spudster) for over a week now and still no regrets or second thoughts which is unusual for me. Bought some 10 foot lengths of PVC pipe at Home Depot and could almost fit them entirely inside. They extended a few inches out the front passenger window which was fine by me.
First tank of gas only yielded 19MPG. Must be from lugging those big spuds. The ride is fine but in an effort to get a smoother ride I bought a set of Mashelins. I like the look of the Mashelins but the ride is a bit lumpy with them.
Below is a pic of my car with the new tires.
http://spudman28.homestead.com/files/spudmobile3.jpg>
Bob
spuds
--- Lowell
The car was very new on the lot when I bought it. They said had arrived the day before, still wrapped outside in sticky paper. Hardly any miles. Dealership is about 60 miles away so I bought one they had just received. Had been dealing with them a month, so the price was good, or I thought so. We had finally negotiated to just over invoice on a car. They were going to bring in one for me, in the color and options I wanted (or nearly), but didn't want another trip, so took the one that I liked that they had just received.
Now wonder whether they did all the pre testing on it. Was there for hours waiting and needed to get home. Also the inside of the warrenty book didn't get signed by them.
See any problems?
Question #2, I realize it is different driving an automatic, but do these have power on the freeway? No freeway here to test. Seems very low key compared to my previous manual (VW). Is there an overdrive? Have a steep hill to go up at about 25-30 miles a hr. I have to push the pedal harder? Know this sounds strange, but haven't driven an automatic in over 25 years.
Am very happy with the car, love the room, the visibity, feel of it and it turns on a dime! Just need to know a couple of things and maybe how to drive it!
Also how is one supposed to drive with a new engine? To break it in gently? No info in the manual that I can see, but lots of info on warnings! Would never have learned to drive if I had had to read one of these at 15!
From the Pacific Coast
Brooks
Congratulations on your Forester purchase.
By any chance, was your Forester warmed up when you heard the "whizzing" noise? Automatics can be noiser than manuals when cold.
If you have any concerns regarding your vehicle, you should set up an appointment and have the dealer document your concern and try to address it.
As for the break in process, you should be very gentle on the engine for the 1st 1000 miles. Try not to rev the engine over 4000RPM unless in an emergency. Also, try not to keep the engine RPM at one particular level for too long (such as on the highway). The whole idea is that you want to give the engine internals a chance to seat themselves without over straining it. After the 1000 mile mark, you can slowly start going above 4000RPM.
The automatic transmission in your Forester is controlled by a Transmission Control Unit (TCU). The TCU will "learn" your driving habits over the next few thousand miles. On your "hill", just apply enough gas to keep you at the speed you want. The TCU does the rest in downshifting to the right gear you need. If you don't feel you're getting to the right gear, you can always manually select a lower gear. 4th gear is overdrive. There is also a torque converter lock that engages when you're crusing in one gear for a period of time to maximize fuel economy.
Enjoy.
Ken
