Chevy Camaro Maintenance and Repair
I just bought a 85 Camaro and it is Idle is too slow. How do I adjust that? My family only knows how to adjust carburated motors. (please excuse spelling errors)
If anyone has any advice to offer I would greatly appreciate it ........thanks becky
No, you dont need to put anything on the metal, thats whaty the primer is for. As long as it is sanded down well all you need to do is add the primer. If you really want to do something before primering, you can wipe the body with a very thin coat of water. This will heplp the primer set in smoother, and will also pull up any dirt hat is still left on the car.
What exactly is that piece called? I could probably order a replace ment cover/case/column if I just knew the technical name for it.
I've changed out the spark plugs and fuel filter but it hasn't helped.
Anyone have any ideas
Kathy
Visiting Host
1. Putting back the right kind of anti-freeze
2. Bleeding the system properly of air
3. Replacing other parts that are now easy to get at. (belts, hoses, thermostat, water pump?)
4. Capturing spilled fluids, like automatic transmission fluid if your car is automatic. (cooler lines from trans to radiator).
Visiting Host, just dropping in :shades:
Any help will be appreciated, thanks to all and Happy Thanksgiving
thanks,Tim
i am not aware of a good way to test the optispark without swapping it.
for a starting problem, avoid anything but lowest recommended octane gas -
premium gas makes it harder to start.
for the door issue like that, probly ya gotta take off the inner door panel and maybe see what's disconnected/broken ? personally i am unable to remove a panel without significant unintended entropy resulting, but hopefully you will do better.
if your a/c relay is the same as the fuel pump relay swap them. if your extended crank time goes away. replace the relay that you put in the a/c slot. gm has a fail safe system like if you are low on oil it won't start up right away. it also limits off the fuel pump. the reason it cranks so long is because it takes a moment for the oil sender to see oil pressure. when it does see oil pressure the relay opens then the motor wil start.
Just bought a 1992 Camaro RS 3.1 v6, and am going to have to some serious work to it. Thought I'd join the forum for tips and advice as I go....i'm the purest of definitions of "backyard mechanic" so any and all advice is welcome.
Question 1 for the day: The car was apparently in an accident at some time, and the front end is shifted approx 3/4 of and inch to the right. What's the best way to replace / repair this. can it even be straightened out? My understanding of the build is with the uni-body frame, I'm probably just looking at fender supports. (The engine and components except for the radiator appear perfectly in line, right where they should be....) Suggestions?!?
If the car can be aligned, then your problems are strictly sheet metal, and strange as it sounds, some basic wrench work and a short handled 3 lb sledge hammer will do the job---presuming you know better as to not start hammering on plastic or thin metal bracing, but rather only on main, hidden, structural supports such as bumper braces or radiator sub-framing. Another alternative is to rent a portable hydraulic tool that has attachments for bending, pushing, etc. this way and that, and is able to get into small spaces.
Thanks for the info! Now I'm a bit nervous, but still optimistic. As best as I can by eyeballing it, the underframe itself appears to be in a straight line, so I'm hoping it's as you said, sheet metal, a hammer, and a few new parts should do the trick. I'd hate to think that I paid for something that I'm just going to have to get rid of. I'm taking it to the shop to get an alignment this week, so I'll post and let you know the outcome.....
Thanks for replying! I think I'm going to like it here!
Sean
Chintan
Corporate Communications
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
Shouldn't it be 12V in that case?
And with engine running, shouldn't it be about 13.8V ?
If you agree voltage is too low, maybe consider why. Swap in a new battery to see if problem disappears?
Also there could be voltage drop across a corroded wire. No idea if recent camaros are susceptibles, but 3rd-gens could experience corrosion of the wire that goes from battery positive post to starter/solenoid. if there is excessive voltage drop across that wire or on the battery-post or starter-solenoid-post, I understand that will cause the entire electrical system of the car to see reduced voltage at startup-time. If this is what's happening, running a parallel wire (one jumper cable) from battery positive post to starter positive post may be a workaround. careful with that - you'll be handling a "hot" lead in that case.
