If you did not take it apart, then I can't see how dirt got into one of the sensors. As far as the computer is concerned, I really don't think the computer just decided that it was going to fail. Usually, when the computer is failing, you will have more problems than just an idle issue. Has the car been sitting long in the garage? There is however, one possibility to look at. How many miles are on the car. Check your oxygen sensor. If your oxygen sensor is clogged it will tell the computer to adjust the air/fuel mixture and that will cause the RPM's to go up. When the engine is running at the high RPM, does it seem to be running smooth or does it seem to be running rough? Oxygen sensors do have a habit of failing quickly. Refresh my memory, does that have dual exhaust? If so, I believe there are 2 oxygen sensors.
There is, however, one other possibility. There is a gasket between the air intake body and the fuel intake that bolts to the top of the engine. That gasket could be cracked. Also, remove the air ducts that attach to the front of the throttle bodies from the air cleaner. There you will see a metal baffel on each throttle body that closes off the air to the engine. Make certain that each one is free from dirt and carbon build up. Make certain they travel full range from closed to open. I have seen the dirt and carbon build up so much that it does not close all the way. And again, make sure that there is not a loose or busted vacuum hose that attaches to the throttle bodies.
I want you to understand, these are just what comes to mind. They are merely suggestions. If I had my hands on it, then I would be able to give you more difinitive answers. Let me know how you make out with it.
I hope this helps,
Daniel
Up till now I havn't been able to get any engine codes because I disconnect the battery when I put it away, So yesterday I went for a hell ride aparintly it's idling at 70mph anyway I came up with a code 15 my manual tells me it's the coolant sensor so I'm going that route today. To answer your questions it has been sitting a long time and it has duel exhaust and ran smooth after it cleared out a little. the baffles you talking about are they the throttle plates or the air cleaner baffles? I'll lit you know how I make out,
. Thanks again for your time.
Tony
s the coolant sensor so today i'm taking that route.
Yes it has been sitting a long time 95,000 miles duel exhaust. according to the manual this sensor can effect the idol. I appreceat your help I've worked on alot of cars in my 56 years never ran across something like this oh I almost forgot she ran smooth as a whistle once it cleared out a little. Thank again I'll let you know how I make out.
Tony
The baffles I am talking about are the throttle plates. Yes, Please let me know how you make out with it. Now that you mention it, you are correct about the coolant temp sensor. If it is telling the computer that the coolant temp is too high, it will adjust the RPM's to make the coolant circulate through the radiator quicker.
That sounds about right 1900 RPM's in that car is about 70 MPH.
Daniel
I'm having a hard time typing today my hands are shaking from my medication. Life's a [non-permissible content removed] then you buy a old vette then you have it smashed at the junk yard.
Tony
Any one else seen this break before?
These have a magnet on the cam sprocket, these magnets tend to fall out of the little plastic retainer. If the coil pack is good, and the ignition module good then it will prob. be the cam sensor pick up magnet. Unfortunately the timing cover will need to come off in order to access the gear. While all of this removed might as well replace the timing chain. Before tearing all this down have someone diag it to check the pulse width of the cam sensor, if you have no pulse then the magnet fell out. You may further verify by pulling the cam sensor and turning the engine until you can see the magnet or where it supposed to be, through the hole where the cam sensor goes.
The cam sensor is located below the water pump.
Seems that engine is not getting gas when starting. Sometimes it starts fine, sometimes takes about 5 times. I can hear the fuel pump, then I start it, sometimes this works most of the time it doesn't.
The worst: driving in traffic and the car just stops, no warning just stops.
So far we have replaced fuel pump, filter, gas lines.
Also "Service Vehicle" light comes on when the car is started in a darker lit area, but does not come on if started in daylight???
Cannot get "Low Tire Pressure" light to go off after resetting.
This is a nightmare!
I've probably driving the car all together for maybe a month and have owned it for 8 months.
Any help or ideas on how to fix these things is appreciated.
Interesting screen name, but any how, here are my thoughts on your issues.
After reading your post, and thinking about it for a little while, here is what I came up with. (KEEP IN MIND THESE ARE MEERLY ONLY SUGGESTIONS AND THOUGHTS). First of all I don't know how mechanically enclined you are meaning if you work on it yourself or have a repair shop work on it. But here it goes, you did not mention that you tested or replaced the ignition switch. As you may or may not know, the ignition switch is a multi-layer switch. Judging by what you said about driving down the road and all of a sudden the engine quits, It leads me to believe that one of the switch plates is loosing contact. It probably could be just dirty or just plain worn out. The cost of a new ignition switch is about $200.00. You could remove the switch and get some good contact cleaner (Home Depot has the best stuff) and clean the switch contacts. If you decide to remove the switch, be VERY careful not to break any wires off of the connector that plugs into the switch. Because your PASS LOCK security system also goes to the ignition switch. Another thought is have you checked the fuel pump relay? That too could also be the culprit. Also check to see if the relay wires are tight in the socket. As far as the "Service Vehicle" light issue, Could the light be on all the time but you can not see it during the daylight? As far as the "Low Tire Pressure" light, I really don't know what actually tells the computer that the tire pressure is low. I don't know if it is a level switch or something else. By pushing the "reset" switch, it should toggle through the "Change Oil" and the "Check Tire Pressure" lights.
These are just my thoughts and I hope it helps. If I could put my hands on the car, I would be able to tell you where the problem is
Daniel
That was a lot of info and I appreciate it. I will share this with the person who is trying to figure out what is wrong with the car.
As far as the "Service Vehicle Light", it definitely goes out when started in an area which is brighter (who knows why?) We tried resetting "Low Tire Pressure Light" after checking tire pressure but just it won't go off after following the instructions in the book.
This car has a mind of it's own.
I beginning to think I should name it Christine!
Maria
I have a Alero 1999, V6 with 130,000 miles. This car was not started for 2 months but running great until then. When I started it after two months, I noticed the battery was dead. Replaced with new battery. Now it starts and stops within 2 seconds or so. I think the fuel pump sensor is acting up.
Any suggestion to get my beauty to run again without towing to dealer and paying thro' nose is appreciated.
- Positive that I will get gong with your help
I hope this helps,
Daniel
I would like to follow your advise. I would like to check the fuel pressure. Where to attach the pressure guage? Any help is highly apprciated.
Best
Positive
OKAY, On V6 models, Remove the cap from the fuel pressure test port. It is located on the fuel rail at the front of the engine (by the serpentine belt) between the alternator and the Power Steering reservoir. It is a schrader valve. It looks like a tire air pressure valve. When you attach the fuel pressure guage all you need to do is turn the key to the "ON" position with the engine not started. It should read 41 to 47 PSI. You will want to check it several times over the course of about 30 to 45 minutes. Don't just turn it on and leave it on for that amount of time because once it pressurizes it will stay. So you will have to pressurize it and relieve the pressure several times. The reason why it takes several times to do this is because it actually tests the integrity of the fuel pump. All your tests should be between 41 and 47 PSI. Make sure that you use a high pressure guage.
I hope this helps
Daniel
I have located the test port. I need to get a fuel pressure gauge. If possible, please do recommend a model that would fit this port and measure the pressure suggested by you.
Best,
Positive
I would suggest an Actron fuel pressure guage. It should come with all the fittings. The guage is good for 0 to 100 PSI. Most auto parts places have them for about $45.00. If you do some research, you may be able find it cheaper. Also some Auto Parts houses rent them.
Daniel
Hi , my name is Shaun and I have a 2004 Alero Oldsmobile. It has 97,000 miles on it and it had about 55-60,000 on it when I purchased the vehicle . The problem that I'm having is that when I'm in gear and I'm driving there seems to be a dull humming noise coming from the front of the vehicle . A shop said it might be a barring or something . It almost sounds like something is rubbing . Also , I change the breaks back in June , it's not August and they are already going on ! What's going on ? Anyone else having these problems ? Let me know ! (:
Since you asked, I just replaced the front rotors and brake pads on my 2000 Alero. I can't remember if it was a 12 or 13mm socket that I used to remove the caliper. I would strongly recommend that you use a large "C" clamp to push the caliper piston back. Look at the rotors and make sure that they are not chewed up. That is where I went wrong. I let my brakes go too long and the pad was gone and the metal backing plate of the pad tore into the rotor. I ended up replacing both rotors. If you have to replace the rotors, that is real simple as well. There are 2 bolts that hold the caliper mount to the wheel assy. I think those were either 14 or 15 mm. Outside of the "C" clamp, there are no special tools required. It took me almost an hour to replace my brake pads and rotors.
I hope this helps
Daniel
Took it to my mech and he poked around a little. Told him I was working on radio. He immediately removed console cover, fished around inside and found a pair of eyeglasses. The had fallen in and partially blocked the shifter from going all the way into park hence could not remove key. Did anything get under the console cover???
I went home and brought my 1985 f150 back and jumped it again, same thing, wouldn't start unless I held the gas down, but now when it started, it ran very very rough, engine bouncing around like it was going to pop out. (not really).
Towed it home, replaced ignition coils, spark plugs, cat converter, and battery. Tried to start it, nothing. Just turnes over and makes the dumping sound from the intake. Only difference is now it wont even start when I hold the gas down. Bought the CP9125 OBD II Pocket Scan, ran the scan, 2 codes returned, p0107, and p0107pd. , went to Advance auto and bought map sensor and the vacuum hose for the map sensor. Installed..Same thing, no start, I pour gas into the intake and it still dont try to start, it will act like it wants to start sometimes indicated by the engine turning a bit faster from time to time, but no start at all. At this point I re ran the scanner and it returned with 0 codes. Anyone have any idea what to test,check, try?
Also I have to take my daughter to chemo everyday which is an hour away. I have noticed on these recent trips my car is struggling to go up hills. If I push on the gas to accelerate it revs up to 4000 RPMs and still will not accelerate. It acts as though it isn't wanting to shift. What could be causing this?
P.S. I can't afford for my car not be be working right now with my daughter's medical so any DIY info you can give me would be much appreciated. Thank you!!!!
My Oldsmobile alero will stop working while I am driving it. This has happened to me twice now, even though it has at least half a tank of gas in it. Eventually, it will start back up, but I really don't want this to happen when I am on the way to work one day. When it stops, it usually takes 20+ minutes before it will start again. After this happens, the car will work fine for a couple of weeks, then it happens again. Also, some of the dashboard lights are always on, but the dealership told me that they couldn't turn them off but not to worry about it. Anyone else have a similar problem, and find a way to fix it?
stuck thermostat (these can often be removed and tested on the kitchen stove!)
cooling fans not kicking in when required
other blockages in the cooling system --sludge, collapsed radiator hoses, clocked radiator, debris on radiator
defective water pump
hard to see coolant leak is compromising cooling
head gasket problems
