Nissan Altima Hybrid
1246789
    hiwaymanhiwayman Member Posts: 98
    Thanks! EPA numbers are generally unobtainable (even when they're correctly stated ;-) ). I was very pleasantly surprised to have our new Altima Hybrid nail the numbers on the highway within 1/2 MPG or so, even with my aggressive driving. Still hoping to get into at least the mid-30's on the city side of things. We live in a suburban area that leans toward rural, so there's not a lot of stop-n-go driving as there would be in, say, Manhattan, so I'm guessing that's why our city mileage isn't very good. The place where the Toyota-style hybrids shine is in that stop-n-go driving....
    I have heard mention of a particular way to drive a hybrid with a CVT (something about fluttering the gas pedal) but haven't been able to find a specific description on how that technique is used... any idea what these people are talking about? :confuse:
    sonny19sonny19 Member Posts: 2
    I have roughly 2,500 miles on my new Altima Hybrid. I got 39.7 mpg on the first 1,000 miles and then 41.3 on the second 2,000 miles. I am averaging 42.3 right now. I got 743 miles on my last tankful. Here's the secret. You need to use your accelerator as if there is an egg on it. Gentle acceleration and gliding to stops is the key in keeping your mileage up. Your accelerator really is the only way to control which engine(s) are working. On the highway if you are doing 60-70 mph and you are approaching a decline, you can back off your accelerator slightly so that only your electric motor is doing the work. Your gas engine will be in idle mode anytime over 42 mph. I have gone over 2 miles keeping my speed over 60 mph at times. I do have the technology package which makes it easier to see which engine is running. I also draft behind 18 wheelers when I can to reduce draft and improve mileage. Two other things that can help. Make sure your tires are pumped up to close to the max. Check your tires to see what the max is. My tires are rated at 44psi. So I have them at 42psi. The ride may be a little stiffer, but fully pumped tires will improve your mileage. Reduce your use of A/C if you can. It really drains your battery and when you are stuck in traffic your engine will have to run to charge it up. I do notice that it takes 5-10 minutes in the morning to get the engine warm and get the full benefits of the EV mode.
    johajoha Member Posts: 7
    I have had the same experience. My guess is that the power button is very sensitive to the length of time it is held down and rebels if your thumb is too light or too heavy. I have always been able to try again and get the car started.
    Well, I tried a little experiment. I went out and quickly punched the button, rather than a PRESSSSSSS. About the third try, the "boot-up" freeze happened. That's gotta be it! Whew! Just have to be more casual when starting the car.... I'll have the dealer check the trouble codes next time we have the car in for service, but I think your solution is what the problem is!
    saabgeorgesaabgeorge Member Posts: 22
    Comsumer Reports doesn't believe that tire pressure is that big of a factor with fuel economy - more important for safety:
    http://autos.msn.com/advice/CRArt.aspx?contentid=4024120
    IMPORTANT DRIVING TIPS THAT HAVE LITTLE EFFECT ON FUEL ECONOMY
    Keep tires inflated. Our tests show that driving on moderately underinflated tires is more of a safety concern than a fuel-economy issue. We set the pressure in all four tires to 10 psi below that recommended by the automaker. This reduced highway fuel economy slightly, by about 1 mpg for the Camry and by a much smaller margin for the Mountaineer. But more importantly, underinflated tires provide much less grip for turning and stopping and run much hotter. Overheated tires wear faster and can lead to a blowout. Check the pressure of your vehicle's tires at least once a month, when the tires are cold. Also check the tires before and after long road trips. The recommended tire pressure is found on a label inside the car—usually in a doorjamb, inside the glove-box lid, or inside the fuel-filler lid.
    I can't remember which packages of the NAH have it, but I do know at least those with the Technology Package have it. It is the low tire pressure alert system. It doesn't tell you how much your tire(s) are low, just that they are. If one or more of your tires' pressure falls below a pre-determined threshold, the system will illuminate a warning light on the dash, and "ping" at you...
    townboy325townboy325 Member Posts: 37
    TPMS, all package has it on Hybrid... make sure when u change your wheel u take the TPMS too or else u have to pay dealer like 100 a piece
    gripperdongripperdon Member Posts: 17
    Any resources to assist me in doing this?
    esomer_q45esomer_q45 Member Posts: 4
    I'm ordering a dark gray hybrid with charcoal leather. Is the beige headliner the exception or the rule?
    langjielangjie Member Posts: 250
    it's the rule. all altima's have the beige headliner. it's not that bad, not the best either though
    We've purchased the same color scheme as you. Beige headliner. We thought there'd been a mistake at the factory and contacted the dealer. They took us out to their lot and showed us 3 other cars with the same beige headliner. The reasoning is that it is cooler than black/grey (I think the reality is that it's just cheaper to manufacture). You get used to it pretty quickly, since it's out of your line of sight (at least when you're sitting in the front seats).
    It's more than just "installing a plug". The computer needs to be reprogrammed so the car will stay in EV mode longer, and you'll need to purchase more batteries. Then there's the cost of installation. And you'll void your warranty. This is done quite commonly on Priuses on the West Coast (same technology as a NAH), but the cost is significant, and you lose a great deal of storage space. I've heard this costs in the neighborhood of 5K to have done.
    ighigh Member Posts: 60
    I also have a NAH with Tech Package which has 3500 miles
    on it now. It has gone through the first oil change. I have
    done all the above that you said but cannot seem to get
    over 38 mpg. I do not draft though but my highway driving
    is minimal.(20%)
    I have a couple of questions for you:
    - The mpg that you are getting - is it hand calculated or
    taken from the dash? I find the dash mpg to be always
    2.5 more than actual.
    - How long is your commute? My commute is 20 mins. All the
    people who get low to mid 40 mpg in the Camry Hybrid seem
    to have commutes in the 40 - 90 min range. Since the
    initial 5 mins of the drive only yeilds about 20-22 mpg
    due to warm up, I think to negate that, one needs to have
    many 40 mpg+ segments to pull overall mpg into the 40s.
    My last tank was 701 miles but it took me 18.8 gallons
    for an mpg of 37.3. The dash read 39.7 mpg. I took me
    1 month to get through that tank based on my driving
    pattern.
    the camry engine is a little more efficient due to the atkinson cycle and a 9 less hp
    i like the way my car looks though, that's why i got the nah over tch
    The MPG has been hand calculated. However, it is almost exact to the dash. The only variance is how much do I over fill it. an extra 1/2 gallon will throw things off a little. My commute is 32 miles, mostly on highway, but it is almost always jamed up for nearly 5-7 miles which I love. It is stop and go which allows me to use the EV mode but enough movement to keep the battery charged.
    I hit 734 miles on a recent tankful.
    When I am on the highway doing 60-65 mph, I always back off the accelerator enough on declines to use only the electric motor. I can go up to 2 miles at times. That helps my mileage as well.
    In the morning, while the engine is heating up, I still try to glide as much as possible to charge the battery and leave the gas engine in idle mode. I have about 1 mile before I get on the highway. I also only get around 20 mpg during the first 5 minutes. But after that I can get 40-43 mpg the rest of the way to work.
    jaxs1jaxs1 Member Posts: 2,697
    When you use EV mode, it drains the battery, then the motor has to run later to recharge the energy that was used. Is this less energy used than if the motor was moving the vehicle directly?
    Are you sure Nissan does not use the Atkinson cycle in
    its hybrid?
    The regular Nissan 2.5S has the same 2.5L engine which
    produces 176 hp. In the hybrid it is 158 hp. Nissan must
    have done something to the engine to make it more fuel
    efficient at the cost of power. The highway mpg which is
    mostly due to the ICE component does go up from 31 mpg
    to 33 mpg (2008 EPA estimates).
    The engine is bigger than the 2.4L engine in the Camry though and this may account for the slightly better fuel economy on the highway for the Camry. For the Camry the power of the engine reduces from 158 hp to 147 hp in the hybrid due to the Atkinson cycle. The highway mpg goes up from 30 to 34 (again 2008 EPA). So definitely the tweak is more effective here.
    It is interesting to note that the regular Altima, inspite
    of a bigger more powerful engine than the Camry gets better
    highway mpg than the regular Camry. This might be due to the
    CVT though.
    I think my fuel economy will not be much better than 38 mpg
    due to my short commute of 8 miles. The initial 5 min poor
    mpg is not being adequately compensated before I stop
    again and the engine cools down.
    yes, i'm sure it's not an atkinson cycle (read it in one of the reviews, maybe edmunds actually)
    i think the power drop came because some parts of the engine needed to be downsized.
    38 is nothing to complain about...i'm at 36 after 5500 miles
    happy_hybrid_1happy_hybrid_1 Member Posts: 41
    So what is the deal with Nissan bumping the financing up to 1.9 APR/36 months from 0.7 APR/36 months for August. Sure they are offering an additional $1000 rebate, but that is at the expense of having to finance through NMAC at default rates, which makes the $1000 rebate idiotic to take. I don't understand the reasoning here; aren't 2008s on the way for September, why de-incentivize the remaining 2007s by uping the rate :confuse:
    kannikanwokannikanwo Member Posts: 19
    I thought this was strange too. But, I would go for the 60 month/2.9% anyways because this turns out to be a greater savings than the 36 month financing.
    emgremgr Member Posts: 109
    I believe you can also select bimonthly payments which effectively reduces the interest paid and pays the car off earlier on a 60 month deal. At least that is what my dealer told me.
    bcp01scu05bcp01scu05 Member Posts: 19
    That depends on the interest rate you'll receive on the money you keep in the bank/market while the loan is being paid off.
    If you think you'll earn about 6.5% (post-tax) or greater, then you should (have) opt(ed) for the 2.9% 60-month financing instead of the 0.7% 36-month financing. Anything less than 6.5% and you should take the 0.7% financing.
    Using the new 1.9% rate, the changeover point is more like 4.5% instead of 6.5%.
    That calculation assumes some potentially unrealistic things (ie, you have no problem paying off the principal, you don't need the money for other things, etc), but should serve as a decent guideline for how you choose.
    coolguy6coolguy6 Member Posts: 4
    What limitations can be found on a Nissan Altima Hybrid when compared to a conventional vehical? For instance are after market rims supported by hybrid systems?
    I don't see why you couldn't have after market rims.
    I don't think you can do much in performance upgrades for the car though, like putting in a new intake as the space is very limited in the engine bay. but if you're buying a hybrid, I have no clue why you would want performance upgrades...
    For HID's, you are stuck with the direct harness if you want to put on aftermarkets (no relay type because the battery is in the trunk)
    Well i was mainly looking to put on aftermarket rims but i heard that it may mess with the braking system that recharges the batteries...
    I'm intrigued by what you are saying here, but I'm not sure I understand. Can you explain in more detail what you are talking about? I don't see how the "changeover point" drops from 6.5% to 4.5% when the amount of interest you would be paying to Nissan goes up?
    I put aftermarket rims on my Civic Hybrid, and it hasn't affected anything other than my gas mileage. If I were you assume a drop of 5-10% in gas mileage from whatever you are getting with the stock rims. The car is specifically engineered to be most efficient with stock parts. When you put on aftermarket rims, you will affect the gross weight of the car, the aerodynamics of the car, the drag and vortex swirling in the wheel wells, etc. This will all lead to a decrease in fuel economy. It is less likely that the increased weight will result in an increase in the possibility of fatiguing the suspension linkages, but it just depends on how much margin Nissan designs into these parts. Most likely there is plenty of margin available to allow aftermarket items to be added. Personally, the stock rims on my Civic Hybrid were so ugly that I literally replaced them within 1 month of buying the car.
    It's a measurement of the present value of the payments you'll make under the different financing options, using different interest rates. Basically, it's looking at whether the additional interest you can earn from the bank/market by delaying the repayment of the principal (and therefore leaving that money in the bank/market for longer) will exceed the additional interest you pay to Nissan by having a higher financing rate.
    I think it'd be easiest to explain in an example. The amount of money you actually finance has no effect on the result of the calculation (the payments, present values, etc, all move proportionately with the loan amount), so let's use 10K as the loan amount.
    Under the July options, you would pay $280.79/month for the 36-month financing ("Option 1") and $179.24/month for the 60-month financing ("Option 2"). The new 36-month payment in August ("Option 3") would be $285.99/month.
    Now let's assume the interest rate you can earn in the market is 3.9375%--this is the 5.25% rate offered by Eloan's savings accounts with a 25% marginal tax rate taken off. Using this interest rate, the effective cost (ie, the present value) of the $10K loan is about $9,520, $9,748 and $9,696 for each of the three options, respectively.
    In other words, because both of the 36-month loans "cost" less than the 60-month loan, it makes more sense to take the 36-month loan, regardless of whether you got the July or August rates.
    The next step is then to start playing with the interest rate you get in the bank/market to figure out when the present value of the 60-month loan equals the present value of the 36-month loan. At an assumed rate of 4.5%, the present values of options 2 and 3 (the August rates) are virtually identical. Same thing with 6.5% for options 1 and 2 (the July rates).
    Since the rates in August are closer to each other than the rates in July, you don't need to earn as much when keeping your money in the bank in order for the longer repayment period to outweigh the fact that you pay more interest, hence the lower "changeover point" that I referred to.
    I should add that this is a purely money-driven calculation, and makes some assumptions like assuming that you have the full $10K in the bank/market at the start of the loan. There will likely be other factors that impact the decision, such as whether or not you need the longer repayment period to be able to make monthly payments. All these are perfectly valid considerations, too.
    lol,
    yeah, i think that getting a heavier rim will hurt your economy...a lighter one however, might be better, i'm not sure though
    stevehybridstevehybrid Member Posts: 4
    Has anyone come across a NAH with:
    pebble beach exterior
    blonde leather interior
    Connection package w/XM
    Moon roof
    Wind deflector
    It seems this combination does not exist here in SoCal.
    Also, if you have bought this package recently, please share your final price.
    Steve
    Forget what Nissan says the options and color combinations are. They produce what they want. I am still waiting for a jade NAH with tech package and blond interior with no sun roof. All supposetly available. None on the east coast. Even though I ordered it on June 12th I have to order it as an 08 which may not get here till September or even October. I think that is retarded.
    agreed...the problem is it really isn't a mass produced vehicle so the dealer picks and chooses the options for the higher end and they also get random base ones or ones with convenience packages
    If you are a long-term hybrid owner, our Senior Editor, John O'Dell, would love to hear from you! A short email with your maintenance experiences and concerns would be great. Please send to John at jodell@edmunds.com by close of business Wednesday, August 22, 2007. Be sure and include your Forums username.
    Karen_SKaren_S Member Posts: 5,092
    A freelancer aims to talk with owners of the following hybrid models: Accord, Altima, Camry, all Lexus hybrids and all pick-up truck hybrids.
    Please respond to Chintan Talati at ctalati@edmunds.com no later than Wednesday, September 12, 2007 with your daytime contact information and the hybrid model you own.
    tomscot2tomscot2 Member Posts: 33
    My wife and I returned from a Labor Day weekend trip to find a dead NAH in the airport parking lot. At first we thought the cellphone had erased the key memory, but when we went to call a cab the parking lot guy said that our headlights had been left on. My wife did leave the headlight switch in the Auto position. However,that doesn't stop them from turning off in the garage every night. The only thing we could figure is that in her hurry to get the shuttle that she didn't turn the car off. (This is a terrible feature in this vehicle: you can walk off with the key in your pocket and the vehicle stays on). In that case, the Auto function will still work when it gets dark!
    Once we figured out it was the dead battery, the lot attendant wheeled over the portable jump start cart they have and we tried to jump start it. We had a heck of a time. First, we had a hard time getting it to go to Ready mode. After reading the manual a few times we found that there is a special procedure to follow if it doesn't happen right away. It involves cycling between On and Off in 5 second intervals.
    Once we got the Ready light to come on the engine would come on, but then die. It did this several times. I finally tried to back the car out of the space and it died. We re-jumped it and got it to go a little farther. We drove a couple of hundred feet without dying and pulled into a space to try to let the engine charge the battery more. I found that I had to put it in Drive with the parking brake on to get it to charge. After about 10 minutes, we finally got the needle a quarter of the way into the blue and drove home.
    The owner's manual does not describe at all the post jump start procedures. It assumes that you just get to the Ready light and it works.
    that's a pretty bad experience, =T
    That's a terrible experience, especially after spending a few hours in a cramped plane, and all you want to do is get home. When stepping us through the details of our new car, our sales guy was very specific, and repeated several times that we should NOT let the battery go flat. We asked him why and he just said, "It's a real problem, if you do." Now I know what he was warning us about. Thanks for the detailed explanation of how you resolved the problem. When we inevitably let the batter run flat, now we'll know what to do.
    It's interesting that the car would start and then stall. I'm trying to understand the logic of what might have been going on. There are two batteries in the car. One for the hybrid electric drive and a 12-volt to start the motor and run the accessories. The charging systems for the two batteries are linked (but I'm not sure exactly how), so perhaps each time the charging system tried to charge the hybrid battery, there still wasn't enough juice in the 12-volt to support the gas engine and accessories. Just a guess, but who knows what was really going on. These things are COMPLEX!
    I left my car on and did not know it. I got out closed the door to the garage and came out a bit later to find the car running. THe HV battery had depleted so the engine started. Nice Garge full of stink and CO. Way to Go to kill a family, STUPID STUPID, How about a ring a ding ding if you try and leave with the car still in ready and open the door on the drivers side. Might save a big recall and a hell of a lawsuit. Hey NISSAN FORWARNED all the lawyers in the world will reference this if you have a problem. You could even have the car turn off if not moved for an 1/2 in neurtal or park! :mad:
    You walk up with your Intellegent key and hold the button on the key and the windows go down.
    Problem you can't get the up unless you get in press the brake and start button and use the windown switch oon the door. Stupid again. They should go back up with the lock button on the intellegent keu or at least the window swith with out having to get the car in ON and then use the dooe switches. :confuse:
    If you use the actual key in the door you can roll the windows up or down depending on which way you turn the key. FYI.
    OK,Thanks, Just like I didn't pay for a dumb intellegent key.
    You can put your Hybrid in park, Get out, close the door and press the lock buton on the door handle and walk away.
    DANGEROUS? YUP the car is still on! No warning Beeps or anything. Do that in your garage and maybe kill the whole house. :mad:
    I reported this to the NHTSA !!!
    Does the Toyota Hybrids operate the same way or is their a warning?
    Not completely Positive but I think they have a warning!
    palaboypalaboy Member Posts: 2
    how hard is it for you to push the button off? only dumb people would leave their car without turning it off!
    this is what i know for certain, it's dangerous for dumb people to have an intelligent key.
    gagricegagrice Member Posts: 31,450
    cars have given warning when lights were left on and the key was left in the ignition for 20 years. How come the hybrids are so far behind? Another good reason not to buy one. I say outlaw the keyless ignition. It is a STUPID option in the first place. Only for people too LAZY to put a key in the ignition.
    If the ICE were running you would know it's on. With the electric motor waiting to run the dumb thing is completely silent and I thought it was off! Dummy.
    I loved the story about the couple that left theirs, locked the dumb car at the airport and went on a two week vacation and returned to find it out of gas and the cranking batter run down completely. So I guess it is too hard to push the button if you forget to.
    They should make it beep if you leave the drivers seat while it's still on, thats my solution for the half smart half dumb key. :P
