Hyundai Azera Tires and Wheels
1246712
  • jaymagicjaymagic Member Posts: 309
    That is correct, some Azera's have the S8 version (like mine) and some have the 4Plus version. From what I have read in reviews, both are very good (and very expensive) tires. I haven't seen anything that tells me one is really any better than the other.
    I am pleased to see that some on this forum understand why I started and stayed with 36 psi in mine (now 16,000+ mi.). I am still AVERAGING 24+ mpg, although I do not have to daily drive in stop and go traffic.
  • derrelhgreenderrelhgreen Member Posts: 234
    Re: # 154
    Glad to see that there is at least one knowledgeable fellow here that can
    and does
    understand the importance of running sufficient tire pressures. ;)
    Have you checked your odometer for accuracy? If your car is the same as mine, and I see
    no reason why it would be any different, you may be getting twenty-four and one
    half (24.5) mpg. Our car is reading short by approximately two (2) percent.
    I believe that one of the reasons that you are indeed getting such good fuel economy is because
    you have your tires properly inflated. At only 2,600 miles, I really cannot say for sure exactly
    what our car will wind up getting fuel-economy wise, but I am keeping very accurate records
    and after ours is fully broken in, I should be able to match your excellent figures.
    Have you noticed how much longer it takes to get your tank really full?
    The last fill, I was able to get three more gallons in after the first shut-off.
    I wish there was some way to fix this problem.
    Over on Freds' VW TDI site, we always did the "Ventectomy" and that really helped on the VWs.
    I occasionally too run into the not quite filled situation. But, I know if you overfill, you can get the check engine light. So, I just go to the automatic stop and am done, unless there is a really important reason to top it off. I have also experienced (on my previous XG and the Azzy) that if you don't twist the gas cap enough to get three clicks, you can also get the check engine light. My dealer explained why once, but I don't really recall the reason, now I just click it at least 3 times.
    Oops, forgot to say that I have checked mileage independently of the trip reading and it is accurate. For whatever reason, virtually the lowest mileage I have seen is 21.5 and that included A LOT of idling and sitting in traffic for a considerable period with A/C. I know it seems I am getting better than most, but that's what it is. (Also using synthetic oil).
  • allmet33allmet33 Member Posts: 3,557
    Jaymagic, I would say that the 21.5 mpg is quite attainable. I mean...with mixed highway/city driving I've been getting about 18.8 mpg.
    I actually believe the car has gotten better with FE as it has gotten a little older ('06 Azzy w/38K miles).
  • floridabob1floridabob1 Member Posts: 1,190
    RE: 155
    If you were to run your car with tires inflated to 50 PSI you would get even better fuel economy, although your ride would be both uncomfortable and unsafe.
    The tire pressures recommended by the manufacturer are not a matter of guess work, but by engineering and test results.
    Hyundai is not the manufacturer of the tires and has no financial gain if the tires wear out faster. It would be to their advantage to be able to advertise lower fuel consumption. Why would you think that they would recommend a tire pressure that was too low?
    I am guessing that they set the pressure at 30psi for one main reason. Ride quality. As we Azzy owners know, it is not a sports sedan and is being marketed more as a lux sedan. The lower psi offers a little softer ride over any highway irregularities. Nothing wrong with that, it's just that I am not bothered by a very slight increase in roughness.
    Having the tires soak up some of the bumps versus having to tune a more sophisticated suspension to handle that, probably saves a decent amount of money per car and Hyundai intends to keep the price on the Azzy down.
    So, I think they have good reason to recommend 30, but that does not prevent owners from going somewhat higher, particularly when the tire manufacturer recommends a higher pressure, if one tends to drive a little faster on a regular basis, or wants a little more economy, longer tire life, or a slightly stiffer handling.
    I am not telling anyone that they should do what I am doing, I am just reporting the results of what I have done. Do what you want, if you want 30 psi, it certainly is not a bad thing.
    Re: # 160
    Again, amen. Well said. ;)
    Of course "they set the pressure at 30psi for one main reason. Ride quality."
    They were after that big Buick/Cadillac boulevard ride. They didn't get it.
    With 37 psi cold, I too find that the our car does feel the "highway irregularities" a
    little more, but control is so much better and the turning response is better also.
    We do "drive a little faster on a regular basis."
    If you don't do so out here on the I-15, you will get killed by those that are 'cruising' even faster.
    I just don't feel that 30 psi cold is sufficient for the highway. The car simply feels to wallowy for my tastes.
    Everyone is free to run whatever psi they want.
    But why not try higher pressures, say in the mid to high 30s, and see if you don't like the feel better?
    On that, I will agree wholeheartedly!!!
    RE: 162
    The type of ride is a personal preference controlled to some degree by tire pressure. Tire manufacturers do not specify the pressure to be used in a particular vehicle. That recommended specification is given by the automobile manufacturer. The tire manufacturer provides a maximum safety tire pressure, They do not know the particular vehicle on which their product will be used.
    Do not confuse maximum tire pressure with recommended tire pressure.
  • scbobscbob Member Posts: 167
    "Why would they recommend a too low pressure?"
    Detroit did it for decades. Toyota has been know to do it. It makes the ride more comfortable. It also wears out the tires quicker as you have less rubber on the road, but then again they don't have to worry about replacing the tires.
    I determine correct pressure by testing tires cold, measuring tread depth and adjusting until depth is wearing evenly across all treads. Of course, this may take a few hundred or thousand miles.
    Bob, you are right about that and that's why the auto manufacturer prints out a suggested tire pressure setting for the tires on their particular vehicle. That does not mean you have to keep your tires at that pressure. As you stated and as others have stated...it's a matter of preference as to the type of driving one may do and the type of ride they may desire. Some take fuel economy and tire wear into account, other's worry more about handling and ride comfort.
    In all the passenger cars I've owned, the tire pressure setting has almost always been around the mid-30's (psi). Right now, with the 20" wheels and tires I have on my Azera, I've been keeping the pressure at 40 psi which accounts for the lower profile of the tire (won't allow the tire to flex in as much over pot holes and such) and increases the handling. Increased tire wear doesn't seem to be an issue, I've put about 20k miles on the tires, thus far...and the tires are in great shape. I'll get good wear on them anyway as I'll be taking them off as the winter months approach and putting the factory wheels and tires back on.
  • cobrazeracobrazera Member Posts: 352
    I have been running 35PSI front and 33 rear in my Azera for about ten days and have to say I just don't care for the jiggly ride over minor surface irregularities or the higher impact on large bumps. The cheap suspension components do not work well enuf to cope with the stiffer tire sidewalls IMO.
    I'm going to drop back a couple PSI. The Azera, notwithstanding the many comments on these forums, is not a sports sedan, it's a near luxury cruiser.
    RE: 166
    Agree.
    Changing the tire pressure is not the solution.
    Improving the suspension is the route to go.
    Waiting to see how the 08 rides, and if is much better, I hope to be able to adapt mine, if change is not too difficult or cost prohibitive.
    Changing the tire pressure does make a difference, however...you are right, better struts could be the way to go.
  • mjclements48mjclements48 Member Posts: 16
    I read with interest your issue with steering wheel shimmy and now progressing to a shimmy in the seats & floors. I have been fighting my Azera dealer for the past 6 months over the same problem. I have dealer installed aftermarket wheels on my Limited and finally took it to a reputable tire shop. Three of the aftermarket wheels are out of round. They showed me how the dealer had installed three and four rows of lead weights around the wheels trying to get them balanced. I'm going into the dealer today and we will see what they do. I still have the OEM wheels (they gave them to me) and probably will try to get my money back from them.
    Wow...the wheels were out of round?!?! Sounds to me like they should be replacing those wheels with some new ones. Either that, or you can find a reputable wheel repair shop and they can fix that problem for you. I had to do that after hitting a pot hole once. Shop charged me $125 to make the wheel look like new again.
    Maybe you should throw that option at them if you really like the wheels and just want the problem fixed. It would cost less than replacing the wheels and defintely cost them less than having to refund your money too. Just a suggestion.
    Has anyone purchased new tires for their Azera Ltd.( oem 17" wheels"
    If so, what kind of tires are you now using?
    I would like a quieter tire while still offering good handling and wet weather performance.
    A good place to start:
    See: http://www.tirerack.com/
    There, you can spend many happy hours trying to decide which skin is
    best for you by reading the ratings, reviews and survey results.
    The most recent Consumer Reports (November, page 58) rated tires, and
    although I don't necessarily agree with what they say sometimes,
    hey do compare different brands, and you will learn from their article.
    They liked the Continental ContiExtremeContact for both low
    noise and low rolling resistance as well as long tread life.
    It is worth buying the magazine as it will help you decide.
    Good luck in your search. I'm glad I don't have to do it now myself, judging from the average tire prices today.
    Now is where you might wish you had the less expensive to replace 16 inch wheels from the GLS.
  • zredsoxzredsox Member Posts: 90
    As we all know, Hyundai recommends that all four tires be inflated to 30 psi.
    If I want to inflate my tires to 32 psi, conventional wisdom say to do this when the tires are cold.
    Now, the only places my tires are cold are in my garage at home or in the parking lot at work when I'm ready to come home. Neither place has an air pump to inflate tires.
    If I go to my garage and check the cold tire pressure and find that the tires are at 30 psi, that would tell me that I need to add 2 psi to the tire. But, I have to drive several miles to get to an air pump. When I get to the pump, my tires are now heated up. Suppose I check the heated up tire pressure again and now find that the heated pressure is 32 psi.
    My logic says that I should add 2 psi to the tire which would give me a heated reading of 34 psi. Is this correct?
    I'm not a tire expert, nor do I wish to become one, so could the tire experts out there help me out with this?
    Am I technically doing it right to acheive a cold pressure of 32 psi or is there something I'm missing?
    Thanks for your help.
    For many years, I have been using a "bicycle" pump to put air in my car's tires. This is the one you can get for $5-10 at most hardware stores or places that sell bicycles.
    You have to pump more and it takes about 20 "pumps" to add 2-3 lbs. to a car tire. But, you don't have to pay 50 cents to a dollar for air and hope you get it done before your time runs out.
    Of course you can check your tires cold and then again when you get to a station and just add the correct lbs.
    RE: # 173.
    Two thoughts here:
    Go to Costco where this service is free and have 'em change the air in your tires.
    Yes, I said change. They will, if you ask the right person in the tire section,
    change your air out and replace it nitrogen.
    With nitrogen, among other things, you need not worry about cold and warm conditions due
    to the molecular composition of nitrogen. Because said molecules are larger than
    the oxygen molecules, you will not have the seepage you are experiencing now.
    The other solution should you not like the nitrogen idea is to buy one of those
    battery powered small air compressors to plug into your cigarette lighter
    and air up your tires whenever you desire whereever you might be.
    They're not all that expensive, and if you get a good one, they will last for
    many years thus spreading the cost out to almost nothing per year.
    I'm only on my second one, as the one I inherited from my father finally
    gave up the ghost and rejoined him after thirty plus years.
    The replacement only cost about $20 and it is a good one,
    but I don't think it is available any longer.
    That's better than dropping quarters at the local gas station isn't it?
    RE: 175
    Air is made up of 78% Nitrogen
    There has been much hype for the use of nitrogen in tires, although most tests that have been performed have shown little difference in the performance of air or oxygen
    Re: 176.
    Your first statement is true.
    As far as "much hype" is concerned, I would ask you why the military
    goes to all of the trouble to install it in their aircraft tires?
    Why do businesses like Costco and others go to the expense of using nitrogen if there are no benefits?
    I do know from personal experience that your passenger car tires will not need
    their pressures corrected as often or at all when you install pure nitrogen.
    Good tires will not loose PSI when inflated with nitrogen like those same tires will when inflated with air.
    Tires using nitrogen will last longer because nitrogen does not retain moisture as air does.
    Tires won't have increases in PSI when they are driven (warmed up) like those using plain old air either.
    There may be other reasons, but for me, the few that I've touched on briefly
    are sufficient to lead me to believe that nitrogen is for me!
    Should anyone care to delve further, see:
    http://www.straightdope.com/columns/070216.html
    Your mileage may vary . . . :D
    Carry on.
  • jlindhjlindh Member Posts: 282
    I can answer the question as to why aircraft use nitrogen in their wheels. Sorry, Darrel it has nothing to do with leaks. Most, if not all jet aircraft have magnesium wheels in order to save weight, Unfortunately, magnesium burns wonderfully! Removing the combustion supporting 21% oxygen in the air is the reason that nitrogen is used.
    so, you're implying that there is no good reason to nitrogen-up at Costco and other tire stores for our automotive needs? It's mainly an aircraft reason and not needed for our car's tires?
    Plain old air will do us fine, eh. I found a station(Mustang)in town here that does not charge for air and also has the lowest gas prices in town, to boot.
    RE: 177
    There is no need for argument on this issue.
    The use of nitrogen in auto tires is fine and might in fact have some benefit. There is certainly a question as to the amount of benefit provided.
    Tire retailers use nitrogen as as marketing and sales factor to obtain additional sales and profit.
    The military does not use nitrogen in land based vehicles.
    As "pure" nitrogen is used only inside of the tires, why would you not believe that the moisture does not harm the tires from the outside.
    There are as many many tests and opinions posted on the internet indicating that the additional cost for the nitrogen is not warranted.
    Costco was smart about building the nitrogen usage into their marketing plan.
    If the nitrogen makes you secure and happier, go for it.
    I wish that I were the one who thought of the marketing plan. It obviously works.
  • dmalliadmallia Member Posts: 7
    You could drive the several miles to get to the air pump and fill them up to 36 psi or so. Drive home and let the tires cool. Then, simply bleed the pressure down to the desired level. Good luck.
    For those individuals who are not so negatively set in their ways, and who might be
    interested in further positive discussion of this issue
    , let's talk privately by email.
  • grayfoxgrayfox Member Posts: 166
    Floridabob, I think we need to find someone who has replaced their noisy Michelins with Good Year Comfortred I think they are called. Supposed to be a very quiet tire.
    The Air Force also buys $750 toilet seats for its airplanes. ;)
    RE: 184
    Wow! Those must be really comfortable.
    dmallia -
    Thanks for the idea. Your response was the only one that tried to address what I was asking. I'll give it a try.
    Bob -
    They are extremly comfortable. They're filled with nitrogen, you know.
    Don
  • oskidunker1oskidunker1 Member Posts: 213
    Am going to need some for this winters trip to Tahoe. Anyone reccomendations would be appreciated.2007 Azera.
    It is very unlikely that you will need tire chains. I have driven my Azera in Denver and Colorado mountains after some MAJOR storms last winter 20+ inches on a few occasions and if the roads were semi passable then I got out and made it thru on the stock tires. The traction control system and the ESC on the Azera are very effective in snow and ice, particularly if this is only for one trip.
    If you live in an area like Denver or Tahoe and don't have an alternate 4WD (like about 80% of the people in my community), then you might want to consider getting Blizzak or studded tires, depending on how often you really see snow and ice. I happen to prefer Hankook winter tires, with studs.
    Do you have 16 or 17 inch factory wheels/tires? In other words, Michelins or Hankocks?
    17 inch tires. They will not let you through on Hiway 80 to Tahoe without chains unless you have 4 wheel drive.Doesn't matter how well the car performs. It is unlikely that I will go if they are required but since I own a condo there, I need to be prepared.
    You might have to look for them, but you can buy a set of radial chains if you need them. There is no reason they couldn't be used on an Azera. Google radial chains on the web. Colorado also has a strict chain law, but studded tires on all 4 wheels of a a front wheel drive car are an acceptable alternative.
  • carbratcarbrat Member Posts: 11
    At about 22,000 miles, the Michelins were cupped and terribly noisy.....dealer finally agreed that there WAS an alignment problem and, after threatening to simply sell the car, got Hyundai to agree to do the alignment.....notwithstanding the 5 yr 60,000 supposed "bumper to bumper" warranty, they wanted to say that since I hadn't had it "adjusted" within the first year, it was not covered.....the michelin tires are "junk" and they won't give any kind of adjustment...beyond being owned by the French, I'll never have another set of michelins.......did a lot of research on Tire Rack.com and finally decided to pick Good Year Touring Eagle Response Edge...they were hard to find....cost me $606 (4) including everything.....they are supposed to be inflated to 44 lbs., my dealer suggests 40 for now, we will try 44 this week when I get my next oil change.......without a doubt, the smoothest, QUIETEST ride of my life.....now my Azera is back to a luxury ride with all the power and feel anybody could ever want....
    RE: 193
    Where did you get the information pertaining to inflating tires on Azera to 44 PSI?
    I have heard of a tire manufacturer recommending inflation pressures that differed from that suggested my the automobile manufacturer.
    He most likely got that 44 psi information off the sidewalls of those Badyear :cry: tires.
    Either there or from the dealer who mounted the tires.
    IF he can stand that harsh ride at any pressures above in the high thirties, I will be surprised! :(
    I wonder if anyone pointed out to him that those tires are 'H' rated, not 'V' rated as are the factory Michelins?
    I believe that his problems with the factory Michelins were caused by the vehicle
    not being aligned properly and the wheels not being rotated regularly.
    No one should blame any tire for that!
    RE; 195
    It is hard to believe that a tire dealer would recommend the maximum tire pressure for the tire advised by the tire manufacturer.
    While as a practice, it is better to over inflate rather than under inflate, too much pressure, while increasing MPG will definitely hinder quality of ride and overall performance.
    Some tires do have softer ( or stiffer ) sidewalls than others.
    I replaced the original tires, on a car I had years ago, with Yokohamas. I aired them to the vehicle's recommended PSI, and they were absolute mush. I had to increase the pressure by 10PSI to approximate the ride and handling that the original tires had.
    IMO, one would have to experiment with tire pressure on any tire other than what came with the car.
    I start off two pounds above car manufacturers recommendations and then measure the tread wear every so many thousands of miles and adjust accordingly. Treads should wear evenly.
    There is a big difference between adding a couple of extra pounds of air pressure and adding 14 pounds over manufacturer specification.
    I would have to agree there. I mean...I just took off my aftermarket wheels for the winter, but by them being low profile tires...I kept the air pressure in them at 40 psi. With the factory wheels back on, I've got them set at 37 psi to account for the slight loss that will take place with the lower temps we are having now, so it'll even out to about 35 psi which is a very comfortable ride here in the DC area.
    Mike, try straight nitrogen and see if the outside fluctuations in temperatures change the psi at all.
    With regular air, this happens bigtime. Every drop of ten degrees looses one psi? :confuse:
    In fact, the Impala SS group I belonged to so many years ago would have people complaining
    of psi loss, the seal at the sidewalls being lost and the tires going completely flat.
    (255/50-17 on factory 9 1/2 inch wide wheels.)
    You know...I was toying with the idea of going with nitrogen. I certainly do hate the weekly psi checks! LOL
    It's not so bad when the temps stay consistent, but fall is the worst one since it's usually mild during the day and chilly at night. Our temps fall 20+ degrees at night around here now.
    CNN reported today that Consumers Union has released the results of a year long test comparing the use of nitrogen vs. compressed air in automobile tires.
    The results indicated only a minuscule difference in the pressure retained in the tires after one year. They also addressed the expansion issue explaining that under non extreme driving conditions, such as NASCAR racing, there would be no noticeable difference in tire pressures.
    In conclusion, they felt that if you could get it for free, accept it, but spending extra money for the Nitrogen inflation is not warranted.
