As soon as I get them on and put some miles on them, I'll post some feedback.
When we bought the Azera, we gave our 2002 Mercury Grand Marquis to our daughter. I had put Goodyear Assurance Tripletred tires on it when I replaced the original tires. She just replaced them last week with 80,000 miles on them. I am 71 and have used a lot of different tires, these are the best I have ever used. They give top notch traction in all conditions, are relatively quiet, have great responsivness, and tread life is fantastic.
I recently purchased 4 General Altimax HP tires (tirerack.com) for $372, took them to a local gas station to get them mounted & balanced for another $80. Anyway, since they've been on I've driven roughly 1000 miles on them and I must say, the ride is remarkably better than with the OEM Michelins. I never had any complaints about how the car rode over rough surfaces, but with the Altimax tires...it's even better. The ride is much more quiet and smooth, the handling is markedly better in both dry & wet conditions. I'll have to wait till this winter hits to find out how the tires fare in the snow here in the DC metro area.
I wish I could give you some feedback on these tires in regards to fuel economy, but I was unable to get them installed before an impromptu trip to NY. I can say, on the OEM Michelins (with about 40k miles on them) I averaged about 25 mpg (round trip) cruising at about 70 with the A/C on the whole time.
At any rate, I'm very, very satisfied and pleased with the Altimax HP's. My initial impression of them would have me recommending them to others. I'll post again at a later date and see if my opinion stays the same.
Maybe when the alignment was done, they didn't tighten everything back down correctly. I've had my Azera since Mar. '06 and I haven't had a single alignment done on it yet. The car has just over 71k miles on it, with about 40k on the orginal Michelins. I have started getting a slight vibration from the front end, so I guess it's time for mine to be done as well.
Let us know if the problem is corrected.
71k miles? Wow! Yours is probably one of the Azzys with such high mileage!! Since you reported that you haven't faced any issues(major), I feel confident about the longevity of my Azzy (now with 24k miles)
I got tired of the OEM battery, so I went to Wally World and got one of theirs and it's been a champ, my light dimming issue went away when I put it in. Other than that, it's been preventive maintenance...brake pads, wiper blades, bulbs, oil changes, transmission flush and now...a new set of tires.
I've been extremely pleased with my Azera.
1. Quiet ride
2. Tread Life
3. Handling
It came up with Goodyear Assurance for $123.00 PER TIRE. In reading the reviews of all the other tires, the all seem to get reviews of "gets noisy after 20,000 miles or premature tread wear." I do not see these negative reviews for this tire so I may try it.
51k miles a year?? Good god man, are you a truck driver or something?? I am sure you are pretty high on Al Gore's enemies list!! Lol!!
Joke aside, before I lived in Texas, I never understood how anyone could put so many miles on their cars. Now that I am in Texas, even a trip to Costco would put some miles on my car.
Miles and mile of Texas......
Yeah...51k a year for 4 years!!! No...not a truck driver, just someone that loves driving. I ran into a guy this past weekend with an '06 Azera and he had 96k miles on his already!!!
I've driven through Texas once and you're right...miles & miles of Texas!!! :sick:
The standard tire pressure for these tires is 35 lbs. For the trip, I had them bumped to 37. A little better mileage they say, but also a slightly rougher ride.(BTY I am still on the factory shocks, now at 57000 miles). The big thing I notice about these tires is the amount of grip. It seems significantly higher than the original Michelin's. I will take the pressure back to 35, now that I am back in town..
Personally, I will never go back to ANY over-priced, over-rated Michelin product again. They came on my '02 Sonata and my '06 Azera and in both cases...were far from being tires worth buying again.
as they got older. A tire dealer told me it was probably due to too much
weight on the front end and light on the rear making the tires bounce like a trailer
and cupping them. After rotating them I guess I made it worse by bringing the
bad ones up front and then the bouncing screwed up the rear tires. He suggests rotating more often but mine have gotten so noisy I need to buy a new set.
The wife says "just turn up the radio!"
Also the sunshade gear went bad and fixed on warranty and the other day
a plastic shield under the passenger side came loose and dragged along the
ground when the wind hit it then popped back up when I stopped to check the
noise. Took me three stops to figure out what was happening. Luckily I had a
small bunjee cord that I could use to hold it up.
I purchased the Yokohama YK520's in the stock 235-55/17 size. Ran me $145 each but I parted with a little over $700 when all the road hazard and fees were added.
I have driven over 6500 miles since on these tires, here is my feedback: They are quieter that the stock Michelins even when the car was new. I had nose from the OEMs on grooved pavement more than on the Yokos. I have driven through two fairly heavy downpours and had no problems with grip or stability. Also got a 4 wheel alignment as soon as they were installed to minimize any unusual wear.
Handling is good, and distance driving is quieter and even driving on the rough. bumpy LA freeeways was no problem.
This is a good alternative tire. I think only discount sells this model, which could be a downside if you are in an area where they do not have stores.
Im upgrading to 18s for a sportier look, and I want to try to sell my OEM 17s that came on my '06 Limited.
Im posting on Ebay and Craigslist, but was curious if anyone knows any other place to sell used rims. Whenever I am looking to buy or sell something for my Miata, there is a great Miata website...so I was hoping for something similar for Hyundai/Azera specifically, but if its out there, I don't know what or where it is.
Any info would be helpful...my email is chrisa222@yahoo.com.
Azera Forum
I never had the cupping issue with the Michelins, but maybe that's because I didn't ride on them exclusively. I think I put about 35K miles on them before swapping out for my 20" wheel package, then when winter came...I put the OEM wheels back on. After the end of spring, I took them off again...so it was a constant swap out.
I'll keep my eye out for the Evertrek when I go into Walmart to see if they have it here in my area. I didn't have a problem ordering them from Tire Rack, free shipping and they got to me in 2 days. Took them to a local gas station and they mounted & balanced them for $15/ea.
Good thing with getting them at Walmart...you can buy them and get them installed while you shop. Not a bad deal to be honest.
And, these are with cheap tires (Nexxen 7000s) which were reccomended to me by my tire shop. I was leary since I never heard of the brand, but they are extremely quiet compared to the Michelins and the handling is far better.
If I could only sell my OEM rims!! lol
Not sure where you live, but if you get snow in the winter time...you may want to keep your OEM wheels and put them on in the winter time and then you won't have to worry about messing up your aftermarket wheels. Just a thought.
P.S. The N3000's are really good in wet weather too!!!
Are the Nexan and/or Lexani import tires??? Do they make 17" tires?
I was under the impression that the 7000s are all-season, and that the 6000s are the summer-only tires. At least I hope that is the case, since I live in CT and we get some nasty winters! haha.
About Nexen Tire
In regards to your other question, yes...they do make 17" tires.
If one were interested in long tread life, the N5000 comes with a 60k treadwear mileage warranty, on top of being an ultra high performance all-season tire.
However, I can vouch for the N3000's as being tires you don't leave on for the winter (unless you deal with mild winters). I have a slight incline to drive up to get into my neighborhood and one winter with about 2 inches of snow on the streets, I couldn't make it up the incline. So...I simply put my OEM wheels on in the winter which extends tire life & limits the chance of messing a rim up by sliding into a curb or something.
So far, (one rotation) virtually no wear apparent. I like having the higher speed rating than the Altimax HP. These are W rated, even though I will never be going that fast.
I think the trend we are seeing is that almost any above average tires are better than the OEM Michelins that come on the Azera, and...folks are consistent in reporting that the ride, handling and comfort are improved. :shades:
I think it is about time someone stood up for the blue collar workers in this country. Too many jobs have been shipped out of this country.
(Yes, I see the irony of my response in a forum about Hyundai Azera, a car made in S Korea)
Have been hearing a thump,thump noise for several weeks. Tire dealer showed me flat spots all around two tires on inside of tread that had been recently on rear. I had the wheels religned, front and rear. No significant alignment problems found. Had to put the two tires back on rear as the noise is too loud on front. Now I cannot rotate the tires as I don't want these noisey ties on front.
Is this a tire problem, or is this a problem with the rear suspension? If it is a suspension problem, shouldn't it be covered under warranty. And do I have any recourse from Hyundia for the ruined tires?
I would have gone back to the dealer & complained about the tires. They might have replaced them under warranty. But bear in mind that tires are considered consumables & aren't covered under warranty. But the replacement tires might have been covered under Michelin's warranty. (Just a guess)
I have an 07 with about 28k miles on it. I can't wait to get rid of the Michelins on mine. They're noisy, harsh & are expensive to boot. I rode in a friend's Azera on which he had swapped OEM tires with Goodyear Comfort Tread & they rode so much better.
