Mainly on driver side switches, the door lock not working; cannot control the passenger side window from driver side (but the switch on passenger side has no problem to control its window); even more weird, the light of the shift indicator (indicates if the shift is on P, R, N, D, D2) is light up normally, but if I trun on the car's main lights, that indicator dims down. Seems the whole car's logic in a mess. Please help me!
HELP!! And sorry if this has already been discussed somewhere.
Does anybody have a solution for this electrical problem?
about a week ago one day when I parked the Odyssey (turned off the engine) I couldn't open the sliding doors, not manually nor by pressing the door buttons on the inside. I thought "weird, let me turn on the engine again.." to no avail. As if my battery was dead. No dashboard lights came on, the electrical system seemed dead. About 15 minutes later a friend of mine came and wanted to jump my car, I was certain the battery was dead. But when I tried to turn the engine back on this time it started with no problem. I drove home (no dashboard lights flickered on the way home) and then took the car to the mechanic. He checked the battery and it was fine. What he did was clean out the corroded battery connections. I haven't had any radio resetting, dashboard lights flickering or sliding door problems since. Maybe the electrical system didn't get enough juice at times due to the corroded battery connections.
faulty DRL module
bad contact on driver door switch
I tend to leave the sliding doors open (the car is in our garage and this makes it easier for the kids to get in and out). Even the though the lights go off, could this be draining the battery?
Thanks in advance for your time!
Kristina
A mechanic should be able to put an ammeter in series with the battery terminal (or a voltmeter in conjunction with a known value shunt) and see what is going on. If he detects a real, constant draw, then the next step would be to start pulling fuses one at at time until the offending circuit is isolated. What to do next depends on what circuit is still alive, but step one is to understand why this is happening.
Only other comment is that wet cell batteries can be damaged by bouncing around. Make sure that the hold-down clamp is properly in place.
We love our van, but Honda needs to identify this as a real issue and warn its owners of the problem via a recall. This could result in a catastrophic issue if this syndrome happens on a busy highway with many passengers inside. Let's take this issue to the media and demand an answer from Honda!!!!
Something is terribly wrong with Honda's mechanical system and somehow I feel like I'm fighting a losing battle!!! (Funny how our 2000 Nissan Altima has few to no problems in the 10 years we've owned it and our Honda is causing us grief after 3 years!!!)
I really wish someone would alert the media to these issues so Honda would be forced to answer the same basic question as Toyota..."What's wrong with your vehicles?!? Why are they having electrical problems?!? Why aren't you helping your customers?!?"
After keeping the van over the weekend to 'continue to diagnose' the problem, Honda REPLACED THE BATTERY AGAIN and told me to come pick it up. I did and the van/BATTERY LASTED UNTIL CHRISTMAS (December 25th). Now, the van is DEAD AGAIN.
Sadly, since the 'SNAP POP' I heard in early November, my once reliable Honda van, is no more! I'm afraid to drive anywhere in my van for fear my little one and I will be stranded and left out in the cold (literally and figuratively).
Well, to ALL HONDA OWNER'S WITH ELECTRICAL PROBLEMS, HOPE YOU HAVE A HAPPY HOLIDAY AND DON'T BREAK DOWN IN THE SNOW!!!
(I won't have to worry about that because my van won't start anyway!!!)
VERY odd issue that seemed to happen in conjunction with dead battery: both mornings it was jumped after dead battery, a horrible sound (fast, loud clicking) and some smoke from the right side of the engine was observed. According the technician, this was the A/C compressor pressure release blowing (it should be noted it is below freezing where I live...A/C should not be running.) No indication these issues should be related, but coincidental that it has only happened twice and both times in the past 4 days after a dead battery and a jump start.
Oh, by the way, when I called the Honda 800 Customer service line, they informed me that they were about to go on hiatus for a few weeks. Guess vacation is more important than fixing our vans!!!
Had the same 'snap pop' noise back in November and that's when the problems started and never stopped.
HELP HONDA!!! FIX THE PROBLEM!!!
So the service center tells me this is something they can't fix. They are waiting for a software fix from Honda. When I submitted the case to Honda Corp Customer Care they say that this is not a "known issue" and that they are not actively working on a resolution for it.
I am wondering if anyone else is having this problem? FYI - My cell phone is an LG Quantum smart phone from ATT. I am considering returning the van for a new one, but I don't know what I am supposed to do at this point.
"This is a problem that will be fixed it may take some time. I had a meeting with (Local Honda Service Manger) and was told that Honda has a bulletin and film out to all dealers relating to this problem, the cause is a certain type of phone, ipod, hand held devise and so on. Honda is upgrading the signal (receiver) to correct this problem, this is not a overnight fix and could take 30 +/- days. "
This is what the error looks like. It is triggered by interference from iPhone, Droid and another smart phones. Honda still does not officially acknowledge the problem. When this error occurs the TPMS is disabled automatically. No tire pressure monitoring sounds like a big liability issue for Honda.
I would like to mention my extreme satisfaction with the dealer and their willingness to go the extra mile to find the answer.
I am sorry to hear you are also having a problem with your new Honda but I have to admit it is a small relief to see that someone else is having this TPMS trouble. I wonder if you are having the same problme as me? Do you have a smart phone? They will initially think it is just a real tire pressure problem - and that might be correct. In my case, I have a TPMS error, which is not the same message you get for a true tire pressure problem. My phone is an ATT LG Quantum. If I go to the dealer and allow them to clear the error i can re-trigger the error by having someone call my cell while I sit in the driver seat. Honda still does not acknowledge this as a "known issue" and last week i found that the dealer was mistaken in thinking that a fix was on the way. I told them i was going to give Honda another couple weeks and then i am bringing it in for service. AAAAAAAGHH!!!
What shocks me is the lack of reports on the internet about this issue. It makes me wonder if this is really the epidemic that my dealer says it is or if it is a random defect like Honda Corp says it is.
We need for everyone who has the issue to report it at Safercar.gov so the US DOT can put pressure on Honda Corp to acknowledge the issue. I am starting to believe that Honda's answer to the problem will be "do not carry a smart phone into this vehicle - driver or passengers".
Here is the link to the complaint that I have filed:
http://www-odi.nhtsa.dot.gov/complaints/results.cfm?odi_ids=10384734&SearchType=- QuickSearch&summary=true&refurl=email
