Visitor Agreement.
I am going to mine tomorrow armed with a Sawzall (Bosch reciprocating saw actually with 1 inch stroke) to which I welded up a piece of 3/4" steel rod with a lap joint in it to mount to the saw's reciprocating shaft where the blade used to mount. I was careful to make a good lap joint so that the stress is transferred squarely to the shaft, not the screw holding the two together. Then I welded a flat plate about two inches square to the end of the shaft.I then made tool rest out of a 2x4 so that I could hold the saw upright and support the handle squarely on the floor. The mechanic is going to put the car on a lift for me and let it down until the right front tire just touches the flat plate. This, in theory, should jiggle the tire up and down with any frequency I desire since the tool is variable speed. The mechanic will then put on his mechanic's stethoscope and "go-a-thunk-listening."
I'll keep everyone updated.
I am curious if the two other posters, "kegjeg" and "shadow26" who mentioned that you were also going to local shops have anything to report?
Hyundai called as a result of my opening the first step of binding arbitration with the BBB and we talked about the situation. Their stance is still denial based on the lack of numbers of complaining people. To them the lack of great numbers of complaining people allows them to call it "a normal characteristic of the suspension design.
So to all of you with this same problem START FINDING OTHERS WHO HAVE THE PROBLEM AND GET THEM TO CALL HYUNDAI CORPORATE - NOT JUST A LOCAL DEALER - AND OPEN YOUR OWN BINDING ARBITRATION CASE. Read the material that came with your car or go online and get the contact information for the BBB (Better Business Bureau) Auto Line. I'll post that info later in case you can't find it.
Hyundai IS willing to replace the upper mount. I'll update you after that.
Thank you for your interest in HMAService.com service information website. The Feedback page and the HMAService.com Staff are available to assist with issues related to operation and access of this website. All available service information is contained within the website. Staff do not have any additional information available and can not assist with diagnosis or repair of your vehicle.
For concerns related to servicing your Hyundai vehicle, please consult your local Hyundai dealership service department. You can find your local Hyundai dealer with the Dealer Locator link at the hyundaiusa.com website.
If you need further assistance, contact Consumer Affairs at Hyundai Motor America's Consumer Affairs toll-free hotline at 1-800-633-5151 during operating hours from 5:00 am to 6:00 pm MST (Mountain Standard Time) Monday through Friday. Please have your VIN (Vehicle Identification Number) and any other relevant information available for the representative.
If you encounter any issues with operation of the HMAService.com website, please contact us with details of your concern.
I hope this helps solve your issue.
Thomas
WWW.HMAService.com
Sent: Tue 4/15/2008 9:28 PM
To: HMAService [HMA]
Subject: Feedback from Larry Maxick
username: Larry Maxick
sUserIP: 207.200.116.132
sOrgname:
sPhoneno: 805-861-0003
sEmail: lmaxick@aol.com
sStreet: 907 Greensbgoro Rd
sCity: Ventura
sState: California
sZip: 93004
sComments: I have sent you e-mails on the "THUNKING" problem which you continue to ignore. How about stepping up to the plate and face the fact that you have a serious suspension problem that exists, I sernt you articles from the Edmonds forum. NOw do something about your problem.
Two notes of possible interest:
1) The 2008 Sonata LTD loaner car they gave me to drive home(a carbon copy of my car but a year newer) with 6500 miles on it (mine is 13,000) DOES exhibit the problem just as loudly as my car did before getting the strut mount replaced; and
2) I drove a 2006 Sonata LTD that a friend of mine has and it makes less noise than mine ever did and less than mine does now with only one side "fixed." If mine only did as much as his does I would never have started this forum. So that gives us hope that this could be a poor/inconsistent parts issue, or an assembly problem leading to a parts failure coupled with the rather poorly designed suspension by Hyundai engineers.
What the dealer (Hyundai of Tempe, AZ 480-961-4800) did which is printed on the service invoice:
"Replace the right front strut mount, bump stopper, dust cover, mount rubber as per DSPM, service manager and parts manager."
Parts replaced:
54626-3K000, BUMPER-URETHANE
54628-38000, COVER-FR SUSPENSI
54629-3K000, CUP ASSY-RR SHOCK
54630-3K000, INSULATOR ASSY-ST
54641-3K000, pad-FR- SPRING UPR
Mechanics diagnosis: "Found the right front strut noise reducers distorted/clearance too loose."
I am to be scheduled to take it back in to have the left front done next week. I will update everyone after that visit.
Hyundai, however, is still in denial. Although they were willing to replace the parts under warranty they wrote on the service ticket this time (as opposed to last time) that they were replacing the parts "at customer request as a good will gesture" and no specific mechanic diagnosis was noted. Lame, huh?
On the way home I immediately noticed a change for the better in something unrelated to this forum: that the car was rock solid on the freeway. From the dealer lot as a new car it had what I interpreted as "high susceptibility to wind currents" from other vehicles and the elements -- something normally reserved for older cars as steering parts begin to age. It must, however, have been strut related (unless there is now a ton of toe-in from lack of aligning the car after strut work), because now it goes dead straight and is not influenced nearly as much by the wind deflections of other vehicles. I now just hold the steering wheel still for the most part instead of constantly moving back and forth to stay in the same place in the lane.
I intend to withdraw the binding arbitration case against Hyundai as I no longer feel that the reduced noise of the same nature as previously mentioned is bad enough to win a judgment against them. I do, however, think that Hyundai has some suspension work to do to alleviate this issue as I imagine I would be revisiting this problem in another 14K miles as it again becomes louder and something that will negatively affect its resale value. My advice: buy another brand until they redesign the suspension unless you are the type of person who says, "What noise?" - and I won't hold by breath for them to redesign anything. I probably will sell the car next year before it again gets too bad. It just goes to show that the best warranty in the business is only as good as the original engineering. I'm guessing I'll be back to being a Toyota guy after this experience and will be reporting my findings to Consumers Union.
Good luck to everyone in getting your parts replaced. I'll stay on the forum to find out how you all are treated and how your car acts after getting it fixed. Don't forget you have specific legal rights. Contact the Better Business Bureau's Auto Line to open a case if your local Hyundai dealer will not replace your struts and upper mounts from this evidence.
Everything at corporate is documented. So there is more at work than simple "never heard this before." The consumer is up against the "deny everything until proven undeniable" policy increasingly being adopted by all American businesses. It has been shown to be cheaper than to try to actually fix problems - even ones known to exist. I laugh when I hear and read Hyundai's advertising. The sad thing is that it will work on the majority of the public because the public is getting dumber and dumber. I'm no brain child, but I didn't stay at the 8th grade level that advertising has been shown to be aimed at.
Also, you point out lack of basic understanding of the product by the service personnel. Isn't it interesting that there are so many people in jobs nowadays who do not know nearly as much about their own job as one would expect. Even doctors are not an exception. If I told you what I've been through in the last 7 months due to motorcycle accident injuries and the failure of the hospital, orthopedic surgeon and radiologist to find broken bones that were indeed broken, you would again "be astounded." Get this... I had to tell them about them after looking at my own xrays on the computer comparing them to "stock" photos available on the internet .I am just now taking off the last cast after surgery to screw together bones due to their inability to read xrays. Lawsuit? You bet.
The moral of the story is that nowadays the consumer MUST be educated (more than the "expert"), diplomatic and respectfully persistent.
Take the previously posted parts list with you to the dealer and tell them you want the struts replaced including the upper mounts.
bksss
Manitoba, Canada
If you have another dealer in the area to go to instead of the one you just went to who obviously has a "can't do attitude" rather than a "can do attitude" it might prove more useful as a dealer to use after Hyundai corporate contacts you and then contacts the dealer of your choice to get the matter resolved. Look them up before responding to Hyundai's answer to your initial email complaint. If you do not have another one in your area you might want to indicate your lack of confidence to Hyundai corporate in the dealer you just used because of the negative response you received. That should generate a little corporate pressure on the dealer.
Also, scout out a piece of road surface reasonably near the dealer you plan to pursue the matter with so you can reliably replicate the thunking (or the dealer can on their own).
Last, read all the posts on this matter, not just the last few posts, as it details the evolution of this issue and will provide you with valuable information, diagnostic work and mechanical work already authorized by Hyundai as well as dealer references that can be contacted by your dealer to confirm Hyundai's authorization of the parts replacement.
At the risk of repetitiveness, be courteous, business-like, diplomatic but unrelenting.
Thanks again for your help.
I'm no fan of Toyota at all, especially given how they mishandled their terrible engine sludge problem where properly maintained motors were literally seizing up and suffering catastrophic failure, requiring total replacement. It took a lawsuit by the California Attorney General to finally get them to own up to it and fix it.
Having said that, the Sonata suspension noise is so outside the realm of normal for a modern day midsized sedan, let alone any car, that it is totally unacceptable. I wouldn't even expect this kind of noise from the most basic car sold today, such as an Aveo or Sephia, and you know what? Neither of those cars suffers anywhere near this level of suspension noise.
The issue mars the whole driving experience. It gives a very insecure feeling that there is something mechanically wrong with the car.
That Hyundai can't seem to fix the problem, and has dealerships that refuse to acknowledge that it's an unacceptable and abnormal problem, is a black eye for Hyundai.
Drive a new Malibu, Accord, Altima or Accord, and you will hear NO SUSPENSION noise at all, over any kind of road surface.
I plan on extensively testing an '09 Sonata, to see if they resolved the issue with their revised suspension. If so, I may purchase a new Sonata, despite the bad taste I have over how Hyundai failed to fix the current generation's issue.
If they haven't resolved it completely, I will immediately go and buy the new Mazda 6 that is due to be released. The car is getting rave reviews in all trim levels.
Consider joining PrePaid Legal after opening a case with the BBB. It's cheap and gives access to attorneys for advice.
So, does one notice this issue within a few days or have to drive for a year or so and the problem surfaces? Thanks.
My 2008 with 12,000 kilometers on it has a distinctive thump up by the right wheel. My 2001 Oldsmobile Aurora, and my 1993 GMC 1/2 ton truck made no sound driving over a strip at work that causes a fair thump in my Sonota.
You had to train your wife to hear a thunk? How noisy could it have been if you had to train her to hear it?
"Drive a new Malibu, Accord, Altima or Accord, and you will hear NO SUSPENSION noise at all, over any kind of road surface".
I agree you have a legitimate beef with Hyundai and hope you have luck getting it resolved.
with what year did this problem start and if anyone has an '09 have they had this problem. I have gone on Hyundai's web and brought up the TSB'b and lo and behold ther is a TSB on the ENTOURGE and one other of their vehicles with the identical problem we are haveing. I WILL NOT GIMVE UP ON THIS PROBLEM , I THOUGHT I WOULD BUT THE MORE I HEAR IT THE MADDER I GET. So I will continue to bug even if I have to go as far as the CEO. Th's it for any answers to my enquirey will be appreciated so I can have additional info for the people who call.
Everything I know is contained in the previous posts of this thread:
Others complaining of 06,07,08;
Me: noticed it real bad in 2002 Sonata service pick-up/drop-off Hyundai vehicle;
Me: noticed it in 6 out of 7 varying mileage Sonata's driven (07's and 08's) and the 7th one (an 06) had it just a little - like mine does now that the struts and upper mounts have been replaced.
I know nothing of 09's but you can go test drive one any time you want. Just make sure you have a road surface scouted out near the dealer that will faithfully reproduce the problem before you go "test driving a new Sonata you're thinking of buying for your wife." Hopefully the sales dept doesn't know you as well as the service dept does at your local dealer. Good luck.
Advice: don't get mad. It doesn't last. Get persistent as a climber climbing Everest.
Is this the same problem/sound that others are experiencing?
The noise is , however, sensitive to the speed at which the vehicle encounters the pavement depression as it is only generated by a sudden extension, and seems to do nothing during the compression phase of the suspension of the bump.
Like all of us so far, expect the denial from Hyundai - like this is brand new to them, or "it is a normal part of the suspension in a Hyundai". Then start binding arbitration through the Better Business Bureau's Auto Line. That is the only way I got the strut assemblies and upper mounts replaced. Expect a drastic improvement, but not a 100% improvement. Steering wander will be improved too. Good luck. Keep us posted.
So it could be that there is a level of suspension noise on the Sonata that is normal, for the car. Some folks may not be sensitive to it and don't notice it. Others do. I've driven about a dozen 2006-8 Sonatas, some for a week at a time, and have not noticed any exceptional suspension noise. I have noticed a tire "thump" over expansion joints etc., but not suspension noise. Then there may be, on some Sonatas, more-than-normal noise that is addressed by the TSB that has already been discussed here.
Just a thought.
I bought an 09 Limited V6 and the car is a little stiff over bumps. That is to be expected, as I understand with the 09 Hyundai tuned the suspension on the sporty side. It's a fair trade off for the wonderful handling of the car. However there is no abnormal noise from my suspension at all over any bumps. Granted I don't drive quickly over bumps either. Maybe whatever issue existed has been fixed for the 09 model?
That seems to be the consensus.
Still waiting for someone to describe this "thunk" sound. If no one can do that I'll assume it's in their head rather than a real sound. Cars make noises going over bumps, that's just the way they work. I suppose unless you're driving a Rolls Royce, which I understand makes no noise going over bumps, for the rest of use working class stiffs, our cars will not be silent driving over rough patches of road.
Well this thread seems like a whole lot to do about nothing. I think people are way too paranoid and just need to drive the car instead of worrying about every little noise they hear. These are $25,000 cars and under, thus any noise I hear will be viewed from that perspective. You want perfection. spend $350,000 on a hand built Rolls. If there is some serious suspension design flaw with the Sonata that could affect it's safety, I'm sure we would have heard about it by now.
If so, that is really depressing me.
In an era where the roads seem to be getting worse and worse, I was looking to get into a vehicle that has a smoother, less firm, less noisy ride. Although I can not stand the Toyota Camry, and think it's far more boring than the Hyundai on the inside and outside, I do have to give Toyota credit for giving the Camry a true luxury car ride with luxury car quietness.
Maybe I'm just getting old, or maybe the roads really are getting worse, or both. But I'm wanting more insulation from the crumbling and cratered roads in the U.S. lately, not less.
