2001 - 2006 Honda CR-Vs
1205206208210211314
    Both last generation CR-V and Forester got 3 stars in that static test done by (I think?) the NHTSA. The Forester's score was better but not significant enough to earn it an extra star.
    The new-for-2003 Forester has a wider track and aluminum roof rails, to increase stability lower the center of gravity. So the new one might earn 4 stars, it has not been tested yet.
    My '98 Forester will power slide all 4 tires without even hinting at tilting over. I have a fatter-than-stock rear sway bar and it also tends to wag the tail in the snow, an extremely fun characteristic once you learn to control it. Stock setup is neutral, BTW.
    I'm sure the new CR-V is also wider; I'm not sure about height. My wife tested one last year and it's a lot taller, to be honest there's no way I would drive it the way I drive my Forester.
    Foresters are all made in Japan at a plant in Gunma, and you'll have some of that "New Car Stench" as the undercoating burns off the exhaust. It's applied to make the trip across the Pacific. Happily, it doesn't last long.
    Check out the new Consumer Reports issue, they just tested the new Forester and rated it best in class. They also test an Element, for reference.
    -juice
    Tomsr - Speed costs money. How fast can you afford to go?
    Those extra ponies require upgrades to many engine components. You'd need a new head to get the variable timing, lift, and phase control on the exhaust valves (the CR-V uses those only on the intake). Of course, a new computer would be required to monitor all that. It's possible that you would need to upgrade the entire air intake system from filter to valve. The radiator might need work, and the exhaust system would definately be in need of modification.
    A turbo or super-charger would be more effective for less money. Though, either of those may have a greater negative impact on fuel economy, emissions, and longevity.
    I'm telling you, that's a powertrain for the CR-V Open Air, or maybe an Acura CR-V Type S.
    -juice
  • thelthel Member Posts: 767
    ask yourself if you will be toting anyone around in the backseat. They will be far more comfortable in the CR-V with its generous leg room. CR-V has better cupholders to. :)
  • joey2brixjoey2brix Member Posts: 463
    Why is there so much expectation of an SUV to drive like a sport sedan? Drive stupid and you can probably roll any SUV. If you like wagons then just get the Forester and settle for less interior space.
    The Acura TSX's 4cyl i-vtec does push 200HP but only gets 166ft/lb of torque. How's that going to help speed up a heavy CR-V? You probably get that 200HP @ 7000 rpm.
    Face it: You won't see CRV's in the "The Fast and the Furious 2"
  • reed4reed4 Member Posts: 56
    You won't see ANY small SUV in "The Fast and the Furious 2"!!!!!!!!!!!
    LOLOLOLOL
  • icvciicvci Member Posts: 1,031
    I tested both and went with the CR-V.
    The Forester handles much more like a car. Both have excellent crash test scores.
    Dimensions for both per Honda. CR-V then Forester.
    Curb Weight (Automatic, lbs.) 3347 3140
    Wheelbase (in.) 103.1 99.4
    Track Width Front (in.) 60.4 58.9
    Track Width Rear (in.) 60.6 58.5
    Length (in.) 178.6 175.2
    Width (in.) 70.2 68.1
    Height (in.) 66.2 65.0
    Ground Clearance (in.) 8.1 7.5
    Passenger Volume (cu. ft., mfr.) 106.0 93.5
    Maximum Cargo Volume (cu. ft.) 72.0 64.1
    Headroom (Front, in.) 38.9 39.8
    Headroom (Second-Row, in.) 39.1 39.8
    Legroom (Front, in.) 41.3 43.6
    Legroom (Second-Row, in.) 39.4 33.7
    Shoulder Room (Front, in.) 56.9 53.5
    Shoulder Room (Second-Row, in.) 56.5 53.6
    Hiproom (Front, in.) 54.5 51.6
    Hiproom (Second-Row, in.) 53.5 51.6
    Tow Capacity (Standard, lbs.) 1500 2400
    Tow Capacity (Maximum, lbs.) 1500 2400
    Backseat comfort was a major factor in my decision. IMO the backseat of the CR-V is the best in the class. It's raised so back seat drivers can see out the front. Both seats slide and recline. Foot room in the Forester was, IMO, a joke. The reclining seats in the Forester were odd too, only the middle two thirds recline, the sides stay upright. And I liked the walk-through feature. Granted, it isn't a hallway, it's just a semi-easy way to access the back it you really need to.
    MPG was very similar.
    The only thing I really wanted that the CR-V didn't have but the Subie did are the windshield de-icers. In Michigan, that'd be a big plus.
    Overall, I felt I was getting more with the CR-V in a package that fit my needs best.
    I'm not sure those expecation exists, but it's nice when a vehicle exceeds them, whether it's the handling (Forester) or the back seat space (CR-V).
    BTW, the reclining seats have been gone since 2001 IIRC, so you're talking about a Forester that was freshened in 2001 and then redesigned for 2003.
    The front windshield de-icers are nice, and 2003 models have them even on the rear window wiper, not to mention the heated seats, heated mirrors, rear LSD, weather band radio, and full-time AWD. For snowy climates, those extras are really nice. In Florida you might think they're a waste, which may be why Subarus don't sell many there. Perhaps you've seen both of them. :-)
    The Forester XT (turbo) will be available this month with 235 lb-ft of torque, with an invoice price starting at $23.3k (with freight), and it includes every thing I mentioned in the previous paragraph.
    -juice
    "The Acura TSX's 4cyl i-vtec does push 200HP but only gets 166ft/lb of torque. How's that going to help speed up a heavy CR-V? You probably get that 200HP @ 7000 rpm."
    That's still a few more ft-lbs of torque than the CR-V's 162. And it is spread across the rev band. At 2,000 rpms, the TSX's 2.4 is making more torque than the CR-V's. So, it's not necessarily a high revver, even though the peak output is higher.
    To answer your question, I *think* peak HP comes at 6,800 rpms. The redline is 7,100 rpms (that part, I'm sure of). Both figures are only a few hundred higher than the CR-V.
    Would this engine improve the performance of the CR-V? Absolutely. More power is more power (as long as it makes it to the wheels). Contrary to the belief of some, you simply don't need 300 ft-lbs of torque to move a vehicle weighing less than 3,400 lbs.
    Would using this engine be a good idea? Probably not. It requires premium for max output. I don't think that buyers of an economy SUV will be happy about having to pay full price at the pump (nor do I think they will be drag racing). The UK and JDM Accords use a version of the 2.4L that produces about 190 hp without the need for premium fuel. That's a better option.
    Okay smarty pants, what would you do? I think the best move for Honda would be to modify and use the 5 speed auto and 6 speed manual from the UK Accord/TSX. Both could improve performance, smoothness, and economy without too many trade-offs.
  • tomsrtomsr Member Posts: 325
    I owned a 96 outback and it was very secure and
    forgiving because it was long and low CG.My CRV
    lets you know it does not like being flung around.
    Driven sanely it is OK but no sportscar.If you
    want fun get a Forester and if you want room get
    the CRV.The Forester is coming out with a Turbo
    Charger so you can grin all the way to the Mall.
    If I want to drive fast, I'll hop into my 02 Miata LS LOL.
  • agolynskagolynsk Member Posts: 2
    Gentlemen, my new Honda CR-V 2003, auto, (4) wheel drive purchased in may 2003 and developed annoying clunking noise every time I am using brakes. Noise starting @ approximately 20 mph up to full stop. When I remove foot from brake pedal noise stops, but reapplying brake producing same noise. Please advice is this normal? And what must be done to correct it.
      Thanks, Ark
    Or get a Miata and a Forester, like I have. :-)
    They are the dynamic duo, sun or snow. They complement each other perfectly.
    Ark: park it and make an appt with your dealer asap. You probaly lost a retaining clip or something is wedged between the pad and the rotor. Fix it soon or you'll need a new rotor.
    -juice
    for most insurance companies. I'd check rates before putting a teen into a car with turbo written on it.
    Just a thought. One of the nice things about our CR-V was the low rate in comparison to other vehicles.
    Matrix
    Forester
    RAV4
    Jetta TDI Wagon
    Outback
    All were at least (I think) $300 more per year.
    Ark - This issue has been discussed on several forums. The problem is related to the bracket which holds the brake pads. Effectively, the brackets hold the pads loosely. This allows them to shift back and forth a bit.
    Some speculate that this is normal. When the brakes heat up, they expand a bit and fit the brackets more securely. Others claim that explanation is bunk.
    Whether you consider it a "problem" or just a "characteristic" is up to you. All I can tell you is that the brakes are not failing.
    For us the difference was under $100, compared to our Legacy L, and we pay less for our Forester. YMMV, so it's worth getting your own quote from your agent before deciding.
    -juice
    After 20k miles the drivers armrest is getting
    frayed.To prevent further fraying I put a pair
    of socks on the armrests.I just happen to have some red/white/blue with stars on them, looks cool.Hindsight being 20/20 I should have gotten the black interior, the tan shows dirt too easy.
    I checked - the Forester costs us $300 semi-annually for full coverage, married 34 year old male commuting in it to DC. That's hardly so much that it would turn anyone away from one.
    My Miata costs more, and it's "recreational use only".
    My little sister just bought one and she's 19, the delta between that and a 4 cyl Camry or Accord was insignificant, something like $20 per year.
    So...buy what you prefer, I guess.
    -juice
    you only pay $600 a year for full coverage on a newer Forester? WOW! You owe your agent a case of beer for that.
    Our old 95' Neon with plpd was over $600. With no tickets or accidents in 7 years.
    I pay around $1000 a year for the CR-V.
    33 - married - 14,000 miles a year.
    Well, YMMV, different state, etc. I do fewer miles but you have to be under 7k to qualify for light use discounts, so I don't. I'm with Costco's AMEX program. It's a '98 but rates don't really come down much with age in my experience.
    I think you brought up a good point, though, get a quote from your agent just in case.
    An XT will surely cost more, maybe 10-20% more than an XS, but...you gotta pay to play. It also uses premium fuel. I think the target demographic won't mind much as long as it's quick as Subaru of Canada has claimed. Only the Saturn Vue Redline (Honda engine, to bring this sorta back on topic) can keep up in this price class.
    -juice
    And it won't need premium fuel. If we got a turbo I'd have to install an engine timer. I don't think my wife would be keen on letting the oil drain for 60-120 seconds after reaching her destination.
    I'm with USAA and have shopped for rates. I can't get anything lower. Actually, using insweb.com my rates would jump significantly with Kemper or Progressive. Almost another $1000 with Kemper. Of course, now I do have an accident to report...&^#$@%*&@^!!!!!!!!!
    You sure about the fuel requirement? The Vue's 3.5l makes 250hp, half way between the Odyssey and the MDX engines. Doesn't the MDX require premium, the Ody just 87 octane, something like that?
    Maybe the Vue Redline will require mid-grade. LOL!
    Modern turbos are supposedly better and don't require the same kind of cool down, the WRX for instance hasn't had any occasions where the turbo got cooked. If it were mine, I tend to drive slowly the last mile or two because I'd be in a residential area, so it's not a big concern any way.
    Bummer about the accident, was is the P5 or the CR-V? If it's under a grand in damage you might want to consider paying out of your pocket, you don't want that dreaded "C" (for claim) on your record.
    Hope noone was hurt.
    -juice
    On the way to my office Christmas party I found the back of a Toyota Landcruiser in my 00 Civic hatchback. $5,300 in damage. OUCH! If the bags had gone off it would have been a total loss. I sold it to buy the P5.
    Now the P5 is more costly to insure than the V.
    I was only going 5-8 mph but, it was an older Cruiser with a big chrome bumper and a big trailer hitch. The hatch still ran fine, it just looked like heck. New hood, fenders, headlights, bumper cover, and A/C. If you would have seen it after they were done fixing it you would have never known. It was the best repair job I've ever seen.
    Same thing happened to my last car ('91 Escort GT) but in my case they totalled it and I was happy! LOL
    -juice
  • glycinemaxglycinemax Member Posts: 74
    http://www.hwysafety.org/vehicle_ratings/ce/html/side/s0307.htm
    Wonder what the results would have been with side airbags? Aren't most (70%?) CR-Vs sold of the EX variety? Do the side airbags protect the head? http://www.hondacars.com/models/safety.asp?ModelName=CR-V Anyone have a pic?
    No, I believe only the Forester and the Saturn offer head protection.
    The Forester's are standard side air bags that stretch up to protect the head (apparently well, it earned a "Good" rating").
    I think the Saturn Vue has curtain bags, but optional. Without them it did "Poor". I'm sure it would be better with them.
    The real disappointment is the Element, they added all that weight to beef up the side structure and it got a lousy score. :-(
    -juice
    Allow me to correct myself - the Santa Fe also has side air bags that protect the head. But the structure didn't hold up as well, so it didn't earn a "Good" rating.
    Escape has them optional, and they also protect the head. The scores improved drastically with the bags. Ford paid for the test, else IIHS would not have done it.
    I guess Honda didn't offer to help fund the test like Ford did, so the EX was not tested.
    -juice
    IIHS buys the cars for the first test. If a manufacturer wants a retest, then the manufacturer has to pay. Ford paid for a second test for an Escape equipped with side air bags; no one else chose to do so this round.
    I don't think the IIHS faq says, but I'm guessing that the IIHS buys the cheapest testers they can find - base models mostly w/o side air bags. So the CR-V tested was an LX w/o the optional air bags.
  • wmquanwmquan Member Posts: 1,817
    Adding side airbags to the tested CR-V would have definitely improved its score. Moral: don't buy an LX without side airbags.
    Honda only had to pay IIHS about $22k to test a CR-V with side airbags. Ford did this, and as a result, there were two Escapes tested.
    Why didn't Honda do it? Part of it could be that even with side airbags, the CR-V wouldn't have done as well as the Forester or airbag-equipped Escape. Note the "marginal" structure/safety cage score for the CR-V in IIHS's test. Side airbags won't help here:
    http://www.iihs.org/vehicle_ratings/ce/html/side/s0307.htm
    I bet that Honda didn't want the side-airbagged CR-V to be tested. $22k is petty cash for Honda. They also perform their own internal testing, and probably already know the IIHS side-impact methodology (which has been under development for a few years now).
    Perhaps Honda is going to add new side curtain airbags to next year's CR-V, and then pay IIHS to retest that vehicle. That would boost the head injury scores for both the front and rear occupants and would help offset the structure/safety cage score.
  • vickie5vickie5 Member Posts: 12
    Yeah and the new Element took a beating along with the crash dummy. From what they said side airbags aren't even offered as an option.
    It's possible that the seat-mounted bags would not improve the scores, but I don't think the data supports that notion.
    The three areas where the CR-V scored low (marginal) were head protection, torso, and structure.
    "Honda-style" airbags would almost certainly help with the torso scores. That is what they are designed to do. They cover the upper portion of the door panel.
    The score for head injuries may also improve. Though I don't expect it would earn a "good" rating. The dummy used in this test is the size of a 12 year old. So the head is positioned rather low. In the test, the head struck the window sill, which is an area that torso bags may cover. Even if they don't, the bag would help keep the body in an upright position. (I tired to find picks of the deployment path, but couldn't find them.)
    Because of the marginal structure score, I expect the results with airbags might be "acceptable" rather than "good". But that is still an improvement.
    Varmint, I agree that torso side airbags would probably improve the score from "marginal" to "acceptable." The side airbags would certainly help the torso score and the head/neck injury, though it wouldn't make the "head protection" score "good." The only "good" scores in that category went to seating positions that had true head-protection airbags. And, as you said, the structure/safety cage would have held it back.
    So even with side airbags, the score wouldn't be "good" and I think Honda doesnt want to admit that. Else they would have given the IIHS $22k to test a CR-V with side airbags.
    Adding side curtains may well improve the score to "good" despite the structure/safety cage score.
    I saw the 20/20 segment and it's strange that the Escape got a "Good" rating with the side bags. There was a great deal of intrusion into the driver and rear seat. If just having standard equip side air bags helps the rating that much, Honda please just put them on the standard equip list and raise the price 200 bucks.
    BTW, getting back to engines: Doesn't it stink that GM is buying 3.5L Vtech engines from Honda for the Vue and Honda doesn't even try to shoe horn the motor in its own CRV first?
    What you see on the video may be deceiving. Check the IIHS site, and it turns out that the Escape's intrusion measurements were "Acceptable" while the CR-V's were "Marginal" (worse).
    Honda's probably glad that the Dateline segment simply harped on the lack of head protection, and didn't talk about intrusion.
    Also, the Escape's front side airbags provide head protection, which the CR-V's do not. So just testing a CR-V with its side airbags isn't going to match the Escape's score. Though it'll likely improve it.
    How about this, even after the Escape was tested with sidbags, it still didn't get a better recommendation from the IIHS than the CR-V.
    That's 'cuz the Escape didn't do well at all with the IIHS offset frontal crash test. The CR-V did great at it:
    http://www.iihs.org/vehicle_ratings/ce/html/summary_smsuv_overall- .htm
    The overall crash test champ, according to IIHS, is the Forester.
    Joey2brix - The 3.5 spins in the wrong direction for the CR-V and would not mate up to the transmission. It also will not fit under the hood. You'd have to push the firewall back and drive from the back seat. =)
    Remember the old Sterling? It had a Honda V6
    but was British otherwise.Still a piece of...
    Most are in junkyards now.Seems a shame but
    Honda needs money like everyone else.
  • xccoachlouxccoachlou Member Posts: 245
    I thought the Sterling was a Honda (Acura) shipped to the UK where they added leather, and other niceties such as real wood trim instead of plastic wood. I also thought there was some kind of joint agreement between the two companies - Honda and Rover(?) and the Sterling was basically a Honda with a British shell over it.
  • kyfdxkyfdx Moderator Posts: 272,368
    I think this is correct.
    That is correct. The Sterling was based extensively on the Legend. It was little more than a badge-engineered car for Rover.
    At about the same time, Honda was selling a rebadged version of the Discovery. I believe this was Honda's first foray into the SUV market. Had things worked out with Rover (BMW bought them out from under Honda's nose), we may not have seen the Isuzu clones here in the states. Can't say for sure, though.
    Good suggestion. Hopefully tests like these will pressure manufacturers to make them more available.
    joey: not yet! I went to test drive a Saturn Vue Redline, and they said not until next year, probably Spring! I drove a regular V6/auto and was disappointed, in fact the CR-V 2.4l with a manual tranny is peppier. Smoother too.
    But then I drove a Forester XT (turbo) with a 5 speed, and it blows them all away. I would not be surprised if some testers match WRX acceleration numbers. The thing feels like a V8, at least with the manual (the auto wasn't nearly as fun).
    Don't drive one unless you plan on buying it, because now everything else I drive seems painfully slow. Maybe the Vue Redline can challenge it, we'll see.
    -juice
  • rerenov8rrerenov8r Member Posts: 380
    I do remember that there was something like a joint venture/engineering partnership to benefit the Legend & Sterling, but I'd hardly call it rebadging:
    http://homepage.ntlworld.com/william.whittaker1/800.htm
    As to a Honda version of the Discovery, that is a new one...
  • theracoontheracoon Member Posts: 666
    Honda sells a 3.5L VTEC equiped SUV. The Pilot. Why would they want to add the same V6 to the CR-V?
    The Pilot is very nice, but it isn't even remotely sporty.
    The CR-V could be tuned to be sporty, imagine a Type S or an Open Air. That V6 may not be the ideal engine, but the CR-V is certainly capable of being far more sporty than the Pilot.
    -juice
    I think it would be easier to make the Pilot sporty than the CR-V. They already have the fixin's in the MDX parts bin. The engine and suspension are already there. They might shave some weight by deleting the 3rd row. Add some accessory cosmetics to improve the appearance, and it's good to go.
    I'm thinking that an Element Si would be more a interesting package than a sport model CR-V.
    That's still a lot of mass, depends on what you mean by sporty, I guess.
    Does the Pilot use regular fuel? What about the MDX? I'm curious, the Redline is supposed to get a 250hp version of the 3.5l, so I wonder what fuel it will require.
    -juice
    According to this website, the Pilot takes regular unleaded.
  • tm01tm01 Member Posts: 14
    I am considering a crv but I am curious about the low hanging exhaust system. Has anyone found this to be a problem in anyway.
    What about the MDX? Premium fuel?
    tm01: even the low hanging parts of the exhaust are now more than 8" off the ground. It's tucked in better than the 1st gen. CR-V's was, and noone complained about those pipes getting scraped.
    -juice
